ThinkPad T470p – CMOS Checksum Error Persists After Main Battery Removal (even with new CMOS)
  • Genghis_Khan
    • Nov 2025
    I’m currently troubleshooting an issue on my Lenovo ThinkPad T470p (Type 20J6) and would really appreciate any insights or solutions.
    Issue summary:
    Whenever I remove the main laptop battery and AC adaptor, then place them back, the system gives a “CMOS checksum error” at next boot, and the BIOS clock resets to its default time/date.
    However, the RTC works fine as long as the main battery remains attached — even if the laptop is unplugged for hours. Same as I remove the battery while the AC is attached, RTC remains. Obviously, the CMOS battery does not supply the NVRAM to store the RTC.
    What I’ve done so far:
    Installed a brand-new CMOS (RTC) battery — polarity confirmed correct.
    Measured 3.22 V on the VBAT/RTC rail near the connector (stable).
    Performed power drain (removed main battery, held power button 30 sec).
    Updated to the latest BIOS version 1.41 (R0FET61W) released 7 Nov 2023 (from Lenovo support site).
    Verified that BIOS correctly holds settings during soft reboots, only resets after full battery and AC removal.
    Despite all this, I still get the checksum error whenever the main battery is detached — even briefly.
    Questions:
    Is anyone else with a T470p on BIOS 1.41 experiencing this issue?
    Does the latest BIOS package include the most recent Embedded Controller (EC) firmware, or could mine be outdated?
    Has anyone found a hardware fix or modification (e.g., cleaning the RTC line or addressing the EC/RTC hand-off issue)?
    Is there an unofficial or engineering build of the EC firmware that resolves RTC retention on the T470p?
    Any detailed guidance would be appreciated. I’ve already ruled out a weak coin-cell, since I've used a few brand new ones. So I’m wondering, if this is a known EC power hand-off fault on certain board revisions (mine is NM-B071).
    And the one that I dread most to ask - Do you think my BIOS corrupted?
    Thanks in advance for your help!
    System details:
    Lenovo ThinkPad T470p (Type 20JN-S30G00)
    BIOS R0FET61W (1.41, 07-Nov-2023)
    EC Version R0FHTxxW (unknown, please advise how to verify)
    CMOS battery: 3.22 V measured
    Board ID: NM-B071
    OS: Windows 11 Pro 64-bit
  • reformatt
    • Feb 2020
    • 1533
    With only CMOS battery connected, check for 3V at RTCVCC. If missing, then check the connector JRTC1, R2501 and D2502.
    • Genghis_Khan
      • Nov 2025
      Dear reformatt,
      Thanks for the lowdown, sir!
      Turns out the JME1 pad was yeeted off the board by the previous owner, breaking the RTC_VCC line right before D2501. So that 3.22V from VBAT never stood a chance of getting there!
      You’re truly a Badcaps Legend!
      Time for a micro-jumper….and a macro-jump of happiness!
      I really appreciate the advice!
      Kindest regards,
      Genghis_Khan
      • Caimano
        hp Pavilion 14 CE-1XXX 5 fast 3 slow blinks or cmos checksum error if restarted immediately after shutdown or suspend
        by Caimano
        MB G7AD-2G DAG7ADMB8D0 REV D
        Processor i5 8265U
        AFAIK schematics or boardview are not available for this MB, but I used a similar board as a reference (G7AL-2G)
        Laptop came in not booting with caps lock blinking 3 fast- 2 slow indicating RAM error. Charging works fine. Found bad soldering on the only ram socket present (2 outer left pins and 2 outer right pins).
        Once soldered the laptop started fine and I was able to install Windows 11, upgrade BIOS to version F30 from Windows without a problem, BUT I found a strange and annoying...
        02-06-2024, 10:14 AM
      • questore
        XPS 13 9370 CMOS battery voltage always low
        by questore
        Hi Everyone,
        I have brought you a mistery item
        This laptop have come with some strange faults.
        1. CMOS battery was flat 0v
        Symptoms:
        - After using the laptop and shutting down and removing the AC adapter for at least 1 minute, the laptop never turned on until EC reset (either shorting RTC or removing battery and long pressing power button)
        Amp drawing was stuck at 0.005 milliamps.
        - Laptop cannot really be turned off because it autostarts about 5 sec-1 or 2 minute. (lid sw is not the problem)
        After inverstigation RTCD1 diode had a low value...
        09-30-2025, 05:47 AM
        Lenovo ThinkPad T470p Notebook T Specification for Upgrade or Repair
        This specification for the Lenovo ThinkPad T470p Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T470p boardview and T470p schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo ThinkPad...
        09-06-2024, 08:23 AM
        09-06-2024, 07:11 AM
        09-06-2024, 06:51 AM
