486DX2-66 worth keeping?
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    #41
    Re: 486DX2-66 worth keeping?
    Originally posted by acstech
    Wouldn't that be 250MHz? The 200MMX had a 3x multiplier. 83.3*3 = ~250.
    Did you actually have a 233MMX?
    The MMXs had unlocked multi. If you had a board that could set multipliers manually you could run a 3x multi chip at 3.5x. I still have screenshots somewhere to prove it. The 233MMX i had would not run past 266.
    With a peltier on it cooling it down, along with a giant heatsink, it would run at 300MHz on a 100MHz bus! The real surprising thing was that, at that speed, it was faster than the K6-2 that replaced it!
    You got lucky, few boards could run at 100MHz stable. Then again, my Asus P55T2P4 was a regular Socket 7 not Super Socket 7. It had jumper settings for 100MHz but it would not even POST at that frequency.
    A working TV? How boring!
    • acstech
      GrumpyModerator
      • Jul 2007
      • 1432
      You must have been the lucky one then. All the ones I've seen have been locked. Believe me, I tried setting mine to 3.5x more than once, and always it just ran 3x like it had always done.
      Did yours have the large ceramic case, or was it the black one with the metal IHS?
      Edit: Maybe the unlocked ones were a regional thing? Meaning, those sold in the US market might have been locked, and those elsewhere might not have been.
      Edit2: Mine wouldn't run past 250MHz without the peltier cooling it down first. It wouldn't even post unless it was very cold. How cold I don't know, but I do know that it was starting to frost before I shut it down. Once it started it was perfectly stable though.
      A man convinced against his will is of the same opinion still.
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        The MMX's were locked. (Except -possibly- for QS which were very rare.)
        The motherboards that used them allowed changing the FSB.
        Mann-Made Global Warming.
        - Dr Seuss
        • weirdlookinguy
          • Sep 2007
          • 1638
          #44
          Ah man guys, I ended up having to throw the thing away to make room for a G4 Power Mac and LCD that I found. Now I'm reading through this thread and I think I may have made a mistake. Oh well, it's gone now. At least I tinkered with it for a bit and took pictures.
          • Topcat
            The Boss Stooge
            • Oct 2003
            • 16958
            All of mine were always locked. My 233's would run 100% rock solid stable at 266/75. They would POST 290/83, but were never stable.
            I have some P3 engineering samples and some 604 xeon engineering samples that are on the fun side though.
            <--- Badcaps.net Founder
            Badcaps.net Services:
            Motherboard Repair Services
            http://folding.stanford.edu/
            Team : 49813
            Join in!!
            Team Stats
            • PCBONEZ
              Grumpy Old Fart
              • Aug 2005
              • 10661
              As I recall 'unlocked' didn't show up until P2.
              Those still carried the 'MMX' tag so that's probably where the confusion comes from.
              I have some Xeon socket 771 QS around.
              Don't actually use them though.
              - Dr Seuss
              • Scenic
                o.O
                • Sep 2007
                • 2642
                I've got an embedded Pentium MMX 300MHz somewhere (Tillamook core in normal socket 7 package)
                Always wanted to try and OC that thing to see how it would keep up with a K6-II or 3 but never got around to do it. I do have a bunch of actually quite nice Tekram (remember them?) Super Socket 7 boards to play with..
                • PCBONEZ
                  Grumpy Old Fart
                  • Aug 2005
                  • 10661
                  YES I remember TekRam.
                  They made pretty good boards.
                  I used to buy them in 10 packs for resale when I had the store going on.
                  They were good sellers too.
                  - Dr Seuss
                  • lti
                    • May 2011
                    • 2553
                    I have a working Pentium MMX 200 and a Cyrix MII-333GP (the 83MHz FSB version). They both perform the same at their stock clock speed. I never tried overclocking them. The Pentium runs warm enough at its stock clock speed. The Cyrix came from a Compaq, and (of course) they decided to run it on a motherboard with a chipset that was only designed for up to a 75MHz FSB. That board was picky about RAM (using RAM it didn't like gave typical "bad caps" symptoms), but I am still using it with a K6-2 and 128MB of RAM that only this computer likes (the stick only has four chips, so my only other boards that use SDRAM only detect 64MB).
                    As for really old computers, my dad has an AT clone that has been sitting in the basement untouched for the past 18 years.
                    • Hemingray
                      KABOOM!
                      • Jul 2010
                      • 143
                      Random thought, one may be able to load up a small Linux distro (DSL, Puppy, etc) and get some use out of such a beast.
                      • bluto
                        • Oct 2007
                        • 560
                        #51
                        While possible, there is not much practical use for a linux box of such lowly specs these days. Believe me, I had a 486 setup as a linux nat router for a time. But that time was over 10 years ago. Anything less than a P3 now days is just wasting your time and electricity trying to accomplish anything useful with linux. The occasional DOS game is about all a 486 is good for in 2012.
                        • ratdude747
                          Black Sheep
                          • Nov 2008
                          • 17136
                          the only graphical distro that will run on a 486 is DSL.
                          sigpic
                          (Insert witty quote here)
                          • Clydeuk
                            • Jan 2012
                            • 193
                            #53
                            I still have an Amstrad 286 machine somewhere, it was my first PC. I ran MS-DOS 3.3 and Windows 3.0 on it. I remember enjoying playing Elite on it (it had built in VGA graphics and looked awesome compared to the PC/XT's with CGA). I know I should junk it (the CRT monitor got thrown years ago after the CRT wore out), I just can't part with it.
                            In the late 90's I remember bunging in my old 28.8 ISA modem and using some DOS software managed to get on the internet and send an email to a friend.
                            • hardwareguy
                              • Jun 2006
                              • 405
                              See that extra row of pins around your 486? That's for a P24T...aka Pentium Overdrive Processor! An 83MHz PODP will eat that DX/4 alive when the FPU is loaded. Performance is similar to a Socket 5 Pentium 75 due to the PODP being on a 32 bit memory bus that is partially offset with a double sized L1 cache.
                              A P75 will play MP3s just fine.
                              https://en.wikipedia.org/wiki/Pentium_OverDrive
                              • Agent24
                                I see dead caps
                                • Oct 2007
                                • 4981
                                • New Zealand
                                #55
                                Funny, that Wiki article seems to say the opposite:
                                When the Pentium OverDrive 83 MHz launched, significantly later than the mere 63 MHz version, it did so at $299, an exorbitant price compared to other upgrade alternatives.[2] The AMD 5x86 and Cyrix Cx5x86 processors were usually faster and were considerably cheaper[citation needed]. Even Intel's own DX4, based on an older chip architecture, was typically faster. Only on some applications, where floating point arithmetic was used, could the Pentium OverDrive outperform its predecessors.
                                Go AMD!!
                                -David VanHorn
                                • BigTroll
                                  • Sep 2010
                                  • 1317
                                  • LAMBDA SOND
                                  #56
                                  First of all... I wanted to tell you about my "AWARD WINNING" Packard Bell Legend 10CD. Its got a 66mhz 486 DX2!!! was a SX2 50.
                                  PACKARD BELL "America grew up listening to us. IT STILL DOES!" oh btw i can't do a 83mhz overdrive, requires a damn interposer in these PB450 boards.
                                  My Computer: AMD Ryzen 9 3900X, Asrock X370 Killer SLI/AC, 32GB G.SKILL TRIDENT Z RGB DDR4 3200, 500GB WD Black NVME and 2TB Toshiba HD,Geforce RTX 3080 FOUNDERS Edition, In-Win 303 White, EVGA SuperNova 750 G3, Windows 10 Pro
                                  • RJARRRPCGP
                                    • Jul 2004
                                    • 6304
                                    The RAM symptoms sound more like today's boards. Pre-2000 or at least pre-2003 boards actually seemed less picky, I dunno why...
                                    It sounds highly likely that the contact with the springs were poor... This seems more common with boards made in this century!
                                    On recent boards, it seems I have to reseat the RAM a gazillion times before it will even boot, when I installed a known good Corsair 1 GB DDR 2 SDRAM stick on to the eMachines T3516A Celeron D 352 box, which only had 512 MB of RAM and only 384 MB for Windows!
                                    No wonder why even XP lagged! Much less a normal Windows 7 being tolerable! You could forget about running a default Windows 7 reasonably!
                                    Maybe 7 would work a little better than XP for videos with the Corsair 1 GB DDR 2 SDRAM stick...
                                    ASRock B550 PG Velocita
                                    Ryzen 9 "Vermeer" 5900X
                                    Arc A770 16 GB
                                    eVGA Supernova G3 750W
                                    Alienware AW3423DWF OLED
                                    • Elysarian
                                      • Mar 2013
                                      • 200
                                      #58
                                      Good lord... I had one of those BITD...
                                      Gave it to my dad when I upgraded to a Pentium MMX, if I recall it ran well enough with win95OSR2 (I think there was 16MB ram in mine and I filled those empty DIL sockets with cache ram I salvaged off another (dead) 486 board.
                                      Very clean insides for a machine of that vintage (reminds me of a box I saw recently at a clients site, no idea what's in there but it's of the same vintage as the OP's machine and looks like it's never been booted up!)
                                      • Lupin3
                                        Is this Samsung UN70NU6070FXZC 70 inch TV worth keeping?
                                        by Lupin3
                                        Have a UN70NU6070FXZC that I finally got working with the tape trick (youtube video) covering some of the LVDS cable connections. Picture was great for a few months then I went to turn it on one day and got no image. Background LEDs and sound work ok but I tried many combinations of the tape trick but couldn't produce an image this time. Could I have just been extending the death of the panel? From what I researched, is it the video driver that may be toast?
                                        Any input would be appreciated...
                                        05-15-2022, 01:50 PM
                                      • survivalbloke
                                        Xbox Series X - crashing to dashboard shortly after launching games
                                        by survivalbloke
                                        Hey all! I've got a XBOX Series X which came in with the complaint of games crashing to the dashboard after launch. I've tested a few games so far. Red Dead Redemption I observed will load up fine and sit on the menu no problem, but once I actually load into the world, it will not complete the load-in, and crash, stating something about an error must be sent to Rockstar, etc.. Truck simulator seemed to work fine. Minecraft loaded up and zoned into a world, but within a few seconds, it too, crashed to the dashboard. Where are the logs stored? What should I check?​
                                        09-18-2024, 11:54 AM
                                      • amigo744
                                        PS5 CFI-1016A DISK shuts down only when playing ps4 games error ce-108262-9
                                        by amigo744
                                        Hello there,
                                        ps5 cfi-1016a disk console
                                        Problem: ps5 shuts down when playing ps4 games after cold boot with error code ce-108262-9.
                                        After the shut down the console boots up normal and then the ps4 game functions without a problem.
                                        ps5 games run allways without any problems after cold boot.
                                        Thats absolutely curious....
                                        I have already rebuild database, clean cache and reinstall latest firmware with usb stick in safe mode.
                                        That doesen´t help
                                        Furthermore i have opened console and renew liquid metal on gpu.
                                        This all doesn´t...
                                        06-19-2023, 05:02 AM
                                      • EvazX
                                        ASUS ROG G513QY – RX 6800M powered but not detected intermittently + random crashes (Motherboard: 6050A3254002-MB-Axx)
                                        by EvazX
                                        I am working on an ASUS ROG G513QY laptop with RX 6800M dGPU.
                                        Originally, this laptop was completely non-functional. I replaced the motherboard (part number 6050A3254002-MB-Axx), and with the replacement board it started working fine.
                                        For a long time, the dGPU worked perfectly stable. I played several hundred hours on very demanding games such as Cyberpunk 2077 without any crashes, instability, or detection issues. Performance was excellent and there were no warning signs of failure.
                                        However, after some time, the replacement motherboard...
                                        08-25-2025, 06:09 PM
                                      • paparazzo79
                                        Alienware 17 R3 freezing in games
                                        by paparazzo79
                                        Hi guys.
                                        I own Alienware 17 r3 6820HK GTX 980M.
                                        I purchased it recently tried some gaming (Rise of the Tomb Raider, Serious Sam) and after 10-15.min games freeze, but I could hear audio from game.
                                        Now I am not yet at home, but when it happens I do get separate window error message and will post it later.
                                        Then again there are moments when I could play for like an hour and no errors.
                                        From my experience reading about this issue, this means my GPU is dying, correct?
                                        I installed most recent nVidia drivers.
                                        Temp of GPU while gaming is max 76 C, but usually around...
                                        04-19-2024, 12:07 PM
