PS5 CFI-1016A DISK shuts down only when playing ps4 games error ce-108262-9
  • amigo744
    • Oct 2016
    • 21
    Hello there,
    ps5 cfi-1016a disk console
    Problem: ps5 shuts down when playing ps4 games after cold boot with error code ce-108262-9.
    After the shut down the console boots up normal and then the ps4 game functions without a problem.
    ps5 games run allways without any problems after cold boot.
    Thats absolutely curious....
    I have already rebuild database, clean cache and reinstall latest firmware with usb stick in safe mode.
    That doesen´t help
    Furthermore i have opened console and renew liquid metal on gpu.
    This all doesn´t help....
    i have played with settings... disable hdcp, lower resolution, disable rest mode...
    nothing helps
    any help appreciated ????
    Best regards
  • Mario875
    • Jun 2023
    • 15
    • Far Away
    Re: PS5 CFI-1016A DISK shuts down only when playing ps4 games error ce-108262-9
    Does this happen on all PS4 games or are you testing the same game every time? If you are only testing with 1 game, try another one and see if its any better / worse / different.
    Which game(s) are you trying to run?
    • amigo744
      • Oct 2016
      • 21
      no on all ps4 games i have tested
      tekken7 and so on
      • Mario875
        • Jun 2023
        • 15
        • Far Away
        According the the PlayStation website this error code means "There may be a problem reading the system software or application data"
        So first step would be a total format of the console and start fresh with install of the latest SW, if it still happens then I would be looking at the SSD / SSD Controller, because other than that it is likely to be something with the APU itself where certain specific PS4 cores / features are utilised within the APU and the pipeline is stalling as it tries to pull data from the SSD or render parts of the game, thus bringing up the error.
        Can't say I'm too hopeful on this one, but hopefully I am wrong and someone with more experience of this issue can weigh in, but start with the basics and do a full system reset (not just database rebuild) / SW update.
        • amigo744
          • Oct 2016
          • 21
          Thank you for help
          i have found one solution to use this console......
          After cold boot i have first to start a ps5 game, only start it and then cancel the ps5 game.
          And then all ps4 games runs without a problem...
          Very curious this console,, i don´t think this is a hardware failure.....
          If the ssd or ssd controller or the apu have a failure, no ps5 games will function without a problem...
          if you always start first a ps5 game and then a ps4 game the console runs without a problem then with ps4 and ps5 games.....
          Furthermore i have already done a full reinstall of firmware from safe mode...
          Very very curious this console, never have seen such failure before....
          • goodpsusearch
            Sony RCD-W3 Deck A (Playback only) not playing CDs (Disk Error) repair
            by goodpsusearch
            Recently I was given for free a Sony RCD-W3 with the following symptoms, CD recorder drive reads CDs without any issues (haven't tested recording function yet because I don't intend to burn CDs on that machine) but the reader drive shows disc error after some seconds of it trying to read CD. Tried both CD-Rs and commercial audio CDs with same results.
            First thing to do was to clean the lens but that didn't change anything. Googling the issue revealed that this is a common issue on several Sony CD recorder machines and the culprit is SMD electrolytic caps located on the PCB bellow...
            05-05-2024, 02:04 PM
          • welp
            PS5 Disk Tray issues.
            by welp
            I have a PlayStation 5 CH-1215A with a Disk drive not reading disks anymore. (accepting and ejecting very slowly.)
            Knowing the PS5 has a married daughter board for the disk drive I made sure to use that and replace the rest of the disk tray as it* was owned previously by an indoor smoker.
            Once the job was complete and put back everything together, I tried to insert a disk with no luck at all...
            So, I checked voltage going from the ps5 to the daughter board and am only getting the 5V rail.
            With that knowledge I preceded to check all the fuses for the 12v rail on the main...
            12-19-2024, 02:04 PM
          • DynaxSC
            ASUS ROG STRIX B550-I GAMING - M.2_2 port not working correctly with SAMSUNG SSD980 1TB NVME SSD
            by DynaxSC
            I have an really very weired issue with ASUS ROG STRIX B550-I GAMING.
            Some NVME (PCIe) SSD's are not working correctly in the second M.2 socket. An example of it is the SAMSUNG SSD980 1TB NVME SSD.
            Some other NVME (I have only smaller ones) disk do work without any problem, also SAMSUNG disks, eg an MZVPV128HDGM-0000.
            The behaviour is also really very strange, i.e.:
            • The disk shows always up in BIOS - so it is recognized, so far so good
            • POST-ing with this disk with fresh Windows 24H2 installation (done in the M.2_1 socket) in the M.2_2 socket
            02-23-2025, 01:33 PM
          • Stanley1843
            Windows 11 disk no boot
            by Stanley1843
            I tried to install Linux on a secondary disk in my PC and after a failed Linux grub installation my PC didn't boot in Windows 11. I saw the message (Reboot and select a proper Boot device).
            I made a bootable USB windows 11 and I run the below commands on the cmd but with no succeed.
            DISM /Online /Cleanup-image /Restorehealth
            The DISM.... command shows me the error 87.
            sfc /scannow
            chkdsk
            bootrec /FixBoot
            bootrec /ScanOs
            bootrec /RebuildBcd
            For some reason it writes(Total identified installations 0) like there no...
            10-18-2025, 04:41 AM
          • chth96
            LG GCC-4521B cannot read any disk
            by chth96
            I bought 6 second hands odd $5 at a flea market and I found that 2 odd(GCC-4521B,TS-H192) won't read any disk.
            But I measured all ESR value of SMD capacitor which is located on the TS-H192's PCB and replaced two capacitor which has higher ESR value.
            And To My joy,this TS-H192 odd finally recognized burned CD as well as pressed CD.😂
            But there was no more good fortune for GCC-4521B..In order to dead GCC-4521B back to life, I replaced three capacitor which has higher ESR value and I rubbed silicon grease on the every glides.I even brushed lens with cotton swab which was soaked...
            02-13-2024, 07:31 AM
