ASUS ROG G513QY – RX 6800M powered but not detected intermittently + random crashes (Motherboard: 6050A3254002-MB-Axx)
  • EvazX
    • Jan 2021
    • France
    I am working on an ASUS ROG G513QY laptop with RX 6800M dGPU.
    Originally, this laptop was completely non-functional. I replaced the motherboard (part number 6050A3254002-MB-Axx), and with the replacement board it started working fine.
    For a long time, the dGPU worked perfectly stable. I played several hundred hours on very demanding games such as Cyberpunk 2077 without any crashes, instability, or detection issues. Performance was excellent and there were no warning signs of failure.
    However, after some time, the replacement motherboard began to develop problems. Now, the dGPU sometimes disappears (not detected in BIOS, Windows, or Linux). And when it is detected and I launch a game, after a certain random period of time under load, the system will crash abruptly and reboot. After this reboot, the dGPU is missing again (not enumerated until another long EC reset).
    I have also tried DDU (Display Driver Uninstaller) several times. DDU shows the RX 6800M entry, but as explained to me, this is only because of registry remnants, not because the hardware is really being detected.
    What I have already checked:
    - +NVVDD (GPU core) ≈ 0.94 V (present on all R15 coils near GPU)
    - +FBVDDQ (VRAM) ≈ 1.3 V
    - +PEX_VDD (PCIe interface) ≈ 0.9 V
    - VBIOS EEPROM (25xx, 8-pin) is powered with 3.3 V (VCC, CS#, WP#, HOLD# all high)
    - GPU gets warm when powered on.
    - After a long EC reset (holding power button), sometimes the dGPU comes back and is detected again.
    Symptoms:
    - When missing, the dGPU is completely absent from Device Manager and from lspci under Linux.
    - All GPU power rails are present and stable.
    - When detected, the GPU can run games, but after some time under load, the system will randomly crash and reboot.
    - After this reboot, the dGPU disappears again until another reset.
    - This suggests a PCIe sequence issue (PERST# or REFCLK), or possibly instability in reset/clock circuitry, rather than a missing power rail.
    My tools and limitations:
    - I do not have an oscilloscope or thermal camera.
    - I only have a multimeter, a hot air rework station, and basic electronics tools.
    - So I cannot probe REFCLK waveforms directly, but I can measure DC rails, resistances, and replace small components (resistors, MOSFETs, buffers, etc.).
    My questions:
    1. On this board (6050A3254002-MB-Axx, G513QY), where exactly can I measure PEX_DGPU_RST (PERST#) easily (TP or PR reference)?
    2. Could this be a common failure of the reset buffer / pull-up resistor keeping the GPU in reset?
    3. Or is it more often the PCIe REFCLK buffer / ESD array on the REFCLK lines?
    4. Any known weak components on this ASUS board that could cause the dGPU to be powered but invisible, or cause random GPU crashes/reboots under load followed by the GPU disappearing?
    5. Am I going in the wrong direction with my assumptions, and could this problem be related to something else entirely? Has anyone experienced a similar issue (even on different laptop models) that could help point me in the right direction?
    Planned checks:
    - Measure PEX_DGPU_RST (expect ~0 V if held in reset, ~3.3 V if released).
    - Measure NVVDD_PG / PWRGD near U67400 (GPU core VRM controller).
    - Check 3.3 V supply of the PCIe REFCLK buffer.
    - Inspect series PR resistors and ESD arrays on REFCLK and PCIe lanes.
    Any help locating the right test points, confirming typical culprits on this platform, or sharing experience from similar GPU disappearing issues on other laptops would be greatly appreciated.
    Thanks in advance!
  • Isitha_B
    MSI Leopard Pro GP62 MVR 7RFX (MS-16JB1 ) - dGPU not detected
    by Isitha_B
    Laptop started giving couple of bluescreen errors. after a while dGPU (GTX1060) is not detected by the system. Laptop works fine with intel gpu. HDMI port is also not working.
    APL5930 LDO shuts off 1V8_AON rail after 2secs into booting. No any physical shorts found. EN signals present. Any idea what to check next?​
    03-07-2025, 06:59 AM
    ASUS ROG G513QY-HF002T Notebook Strix G15 Specification for Upgrade or Repair
    This specification for the ASUS ROG G513QY-HF002T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the G513QY-HF002T boardview and G513QY-HF002T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
    09-07-2024, 12:10 AM
  • jean luc ferre
    hp g72 b52sf disabling dgpu amd/ati
    by jean luc ferre
    On the pc hp g72 b52sf w10 bios:sp55430 each time that i reboot after an update i have a bsod with "video tdr failure in atikmpag.sys" .That's a problem with the ati/amd chip because when i desactivate the amd graphics in device manager the pc can work on the intel graphics. But that's not a valid solution because each time i reboot i have the bsod.
    I tried several drivers , even sp50704, to initialize this chip, but i have always the same error of bsod ,or error code 31. On my original bios sp55430 it was not possible to switch the Dgpu toward egpu because the advanced...
    01-18-2025, 05:14 AM
  • spacez
    XPS 15 9520 - tpm device is not detected - NO ssd detected
    by spacez
    I have an XPS 15 9520 with a damaged bios so I flashed another one from badcaps. in manufacturing mode I changed the service tag but unfortunately ssd is not detected and also the error -tpm device is not detected- please help me. I haven't changed the tpm chip yet. Thanks in advance
    Service Tag: J2MSHW3
    |Express Service Code: 41518077843
    mother board LA-L402P REV 1.0(A00)​...
    08-18-2024, 10:54 PM
    ASUS ROG G513QY-DH99-CA Notebook Strix G15 Specification for Upgrade or Repair
    This specification for the ASUS ROG G513QY-DH99-CA Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the G513QY-DH99-CA boardview and G513QY-DH99-CA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
    09-07-2024, 06:40 AM
