Re: SSD recommendations
Let's try to make it simpler.
ISA, PCI, PCI Express, AGP are buses. You connect devices to it. Some accept several devices on the bus (ISA , PCI), some are point to point like AGP (you can connect only one device at the end) or PCI Express (one device per lane or per group of lanes treated as a single wider lane, you have several point to point lanes/groups of lanes)...
These are sidewalks, roads, highways etc...
SATA, IDE, SCSI are more standards of "talking" to devices, ways to group together different equipment into common "languages".
For example, you can have scanners, printers, barcode readers, hard drives talking to the computer through SCSI and you can have optical drives, hard drives, flash card adapters talking through SATA.
These are cars, buses, trucks etc .. they take information and then send it through the roads and highways to the processor and memory.
Let's take the SATA... you have a sata controller which offers you several connectors where you can plug devices - the controller itself talks to these devices at a speed of 1.5gbps (sata1) or 3 gbps (sata2) or 6gbps (sata 3). But between the sata controller and the computer, it uses either PCI or PCI Express or a custom bus within the chipset.
If it uses PCI - this is a 32bit 33 Mhz bus- which means all devices attached to the PCI bus (onboard sound card, network card, firewire, etc) share 127 MB/s of bandwidth. So you may have a soundcard reserving bandwidth, you may have an extra IDE controller, what's left gets used by the sata controller...
With PCI Express, you have 256MB/s for PCI Express 1.0 or 512 MB/s for PCI Express 2.0 , per lane (x1)... you can group 4 lanes into a x4 connection, 8 to create a x8, x16...
