ESR / LCR meter recommendations?
  • slybunda
    • Feb 2012
    • 139
    hi all, looking to expand my toolset, i have a multimeter that can check capacitance of capacitors but doesnt check esr. so im after a cheapo meter that can do the job without costing an arm and a leg for someone who only dabbles with electronics now and then. whats good option to go for thats..... cheap??
    • 31255
    look at the component testers on ebay that do est and test diodes/transistors
    • slybunda
      • Feb 2012
      • 139
      am i looking at something like this: https://www.ebay.co.uk/itm/354969669398
      or things like the LCR-TC1 ?
        • 31255
        that looks expensive.
        it's up to you, the T! is cased with a colour display - that also usually tests zener diodes
        this pdf may helf - or make it worse
        • slybunda
          • Feb 2012
          • 139
          Thanks that pdf is perfect
          • slybunda
            • Feb 2012
            • 139
            ordered a LCR-T7 meter for £10 inc delivery, hopefully it does the trick.
              • 31255
              it will be interesting to see inside it.
              they dont all use the same cpu or battery.
              sometimes you can upgrade the cpu to add features
              or fit a bigger battery.
              • slybunda
                • Feb 2012
                • 139
                Yep waa reading up about these not using real atmega324 and some other fake stuff but for the price if it can just do capacitor esr im ok with it. Will deffo open it up and get some photos of it. Ordered from AliExpress so will take some time to come although it did say should be with me in 7 days.
                  • 31255
                  those "fakes" are actually superior in many ways, and they only exist because china needed chips and ST stopped shipping during the ScamDemic.
                  chips from GigaDevice and others arent the issue - the issue is the number of pins on the package.
                  if they use a 32pin package then the maximum size chip you can fit is 32k but if they use the 44pin package you can up it to a 128k device.
                  • Topcat
                    The Boss Stooge
                    • Oct 2003
                    • 16959
                    Hard to beat a Sencore LC102 or LC103....
                    <--- Badcaps.net Founder
                    Badcaps.net Services:
                    Motherboard Repair Services
                    http://folding.stanford.edu/
                    Team : 49813
                    Join in!!
                    Team Stats
                    • JohnCT
                      JohnCT commented
                      Editing a comment
                      I bought an LC75 brand new in the early 80s, then added a 102 later as I opened another location. When I started contracting, I got rid of the 102. Sometimes too much automation is not our friend - the 75 is much faster. It's like trying to change the temperature on my wife's car - I have to scroll through menus where on my older truck I reach over for the temp knob without even looking at it.
                      John
                    • 31255
                    yes, but can it fit in your pocket and cost the same as a beer in a pub?
                    • Topcat
                      The Boss Stooge
                      • Oct 2003
                      • 16959
                      Depends on the beer and the pub...
                      Team : 49813
                      Join in!!
                      Team Stats
                      • slybunda
                        • Feb 2012
                        • 139
                        Anyone build one if these:
                        https://youtu.be/mogaMWEWWlQ?si=3ij6w7viWwfwyJh3
                        Looks very simple to do
                          • 31255
                          post the real link next time.
                          here is one with the adds and tracking blocked
                          https://yt.artemislena.eu/watch?v=mogaMWEWWlQ
                          thats a very reduced version of the comercial ones - not worth the price of the parts.
                          • slybunda
                            • Feb 2012
                            • 139
                            Will avoid that one then thanks.
                            • slybunda
                              • Feb 2012
                              • 139
                              Is this one good:
                              https://pk17r.wordpress.com/2023/12/...boost-protect/
                                • 31255
                                not really.
                                try reading the source of it all:
                                https://github.com/madires/Transistortester-Warehouse
                                • slybunda
                                  • Feb 2012
                                  • 139
                                  i wonder what the origins are of these LCR-TC1, TC2, TC4, TC7 etc is it an original chinese design or based on something some other brand came up with first?
                                  • Per Hansson
                                    • Jul 2005
                                    • 5895
                                    • Sweden
                                    The origins is = Chinese see nice open source design, Chinese copy design and release without source (because they are assholes)
                                    The original is made by Markus Frejek, then continued by Karl-Heinz Kübbeler to this day: https://www.mikrocontroller.net/arti...ansistortester
                                    There is also a fork done by another Markus (madires) and his version was linked by stj above, both of these two later designs are current with some different design goals, both are completely open source.
                                    Here is a current version with a confirmed genuine Atmel processor.
                                    If you choose the "new english" version you get a surface mount processor.
                                    If you choose the "english" version you get a DIP (through hole) processor.
                                    https://www.aliexpress.com/item/1005003678038543.html
                                    Source: https://www.eevblog.com/forum/testge...02/#msg5178402
                                    • Agent24
                                      I see dead caps
                                      • Oct 2007
                                      • 5079
                                      • New Zealand
                                      If you want a really basic and cheap ESR meter, there are analogue designs such as https://ve7it.cowlug.org/esrmeter.html or https://danyk.cz/esr_en.html (and many more examples online).
                                      However, I suspect the AVR based Transistor Tester devices wouldn't cost much more, and they give you a lot more functionality.
                                      I also like that a lot of them are based on the open source design and can be repaired easily, since you have schematics and source code.
                                      I have a "Blue ESR" meter designed by Bob Parker (actually I have two - I inherited an original EA version as well) and while it works great, it's based on a rather old processor and the firmware is not freely available, so repairability is not guaranteed. (Yes you could probably write your own code for a more modern chip if needed, but that's more fun than I wish to have)
                                      -David VanHorn
                                      • chth96
                                        by chth96
                                        03-09-2024, 10:03 PM
                                        12-31-2023, 06:04 AM
                                      • jorpec
                                        by jorpec
                                        Hi
                                        Thnaks
                                        01-23-2023, 10:37 AM
                                        Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the “E” stops and one switching power (24 volt) supply and a transformer...
                                        12-14-2023, 07:45 PM
                                      • Stephan Mathers
                                        EDMI ATLAS MK10 Electronic Meter Discussion
                                        by Stephan Mathers
                                        Greetings, new guy here but always interested in the crazy universe of modding
                                        We just finished construction of around 25 vacation houses, all inside the same private area.
                                        Each house has 3phase power , and we bought an atlas MK10 meter for each house (25 meters total ! )
                                        The metering on a per-house basis is done privately. Its not done by a utility company. The utility company will only charge us for the total consumption of all 25 houses together.
                                        Id like to do a small modification on the firmware of our MK10 to make it easier identify each house's...
                                        05-20-2025, 09:09 AM
