Computer is slower after upgrading CPU
  • pfrcom
    Oldbie
    • Jun 2006
    • 1230
    Re: Computer is slower after upgrading CPU
    Probably time to download disk diagnostics from the manufacturer of the HDD that's in it, and run their drive verification tool
    A K6/2-500 should be noticeably faster than any Cyrix MII
    If it's getting slower every time you use it, sounds like a different link is breaking up somewhere in the performance chain
    better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
    • lti
      • May 2011
      • 2557
      Would a bad hard drive cause games to run slower? Loading times for all programs have not changed. They are only slow when I am trying to use them.
      • Th3_uN1Qu3
        Believe in
        • Jul 2010
        • 6031
        • Romania
        Have you checked the BIOS for any settings that got reset to defaults? But agreed with the others... get a PIII and call it a day. SiS chipsets are... not worth bothering with.
        A working TV? How boring!
        • pfrcom
          Oldbie
          • Jun 2006
          • 1230
          Originally posted by lti
          It curently has 256MB. I never noticed a performance hit.
          Did you use software tools to measure performance with 128mb or less memory, versus more ?
          When building with a SiS 5598 based board a while ago, I found exceeding the cache limit slowed compute performance to 60% or less
          Have you measured disk performance, or checked the disk in any way ?
          Do you know how much your games use disk, or whether they use lots of virtual memory which also needs disk performance
          Seems to me you're judging subjectively rather than objectively, and hoping someone on this and other forums where you've posted similar, will provide a magic bullet for you
          • Evil Lurker
            Warranty Voider
            • Feb 2011
            • 454
            Make sure you got the "turbo" button pushed in lol...
            The only logical reason I can think of that someone would want a machine that slow is because they have a q-basic "gorilla" fetish and want to watch the bananas fly thru the air whilst they wank off in anticipation before they hit... well either that or they are running 98 as an antivirus machine (many of the newer trojans and viruses supposedly won't work on them).
            I have discarded 20+ perfectly functioning PII-PIII systems this year alone simply because they were too slow. In fact I have a huge pile of 128 and 256mb SDRAM dimms laying around with no home to put them in.
            Get an early P4 motherboard that is capable of using SDRAM if you really want a performance boost and insist on reusing your existing components. But honestly, with a machine that old its little more than a mother-humping-time-vampire trying to get it do what you want. Upgrade to a fast socket AM3 board and CPU and you will wonder why you were ever tilting at windmills to begin with.
            • Th3_uN1Qu3
              Believe in
              • Jul 2010
              • 6031
              • Romania
              #26
              If you had 512s i woulda grabbed them in a flash.
              He already said he has a better computer and this one is just for old games. If that's the case at least do it properly. A decent board, MMX 233, 256MB, S3 Virge and Voodoo II. That's what i had as my first computer. Just that at first it only had 32MB RAM and no voodoo.
              • Uranium-235
                Comrade Glimmer
                • Aug 2007
                • 5045
                • US
                #27
                I have a set of 512's I found at my old work. they have a custom thermaltake heatsinks on them too!
                for sale, $5000 each mwahahahahahahahah
                my first computer = Pentium 133, 64M, and a PCI Blaster Banshee on all on the wonderful windows 95. Tribes played so good, only if you were looking at the ground, but if you weren't, your framerate went waaay down
                • lti
                  • May 2011
                  • 2557
                  I have another socket 7 motherboard, but it won't turn on. After forcing the PSU on, the single MOSFET in the VRM gets burning hot, but the CPU heatsink is cold. The CPU works in this Compaq, so it isn't fried.
                  • lti
                    • May 2011
                    • 2557
                    It isn't that old.
                    Compaq Presario 2286
                    Unfortunately, this is the only computer I have that is capable of running these games. The newer computer that I have is a laptop, and it has so many hardware faults that it isn't worth repairing. Also, I would have to install Windows 98 on it.
                    • Wizard
                      • Mar 2008
                      • 2296
                      #30
                      Replace board with a good Asus mainboard based on HX chipset and 512K cache, and have dual voltage support (revision number is next to the model # on mainboard). This will support 512MB cacheable range means your 256MB memory is covered.
                      Oh I forgot, K6-2 500 is supported on this HX with dual voltage support too. I had one and trialed a K6-2 333 in it. Not bad.
                      PS: P/I-P55T2P4 rev 3.x and higher. (dual plane voltage and uses PWM DC-DC converter instead of linear regulator). Make sure you get this with 512K cache installed and dual tag cache chips too.
                      Cheers, Wizard
                      • lti
                        • May 2011
                        • 2557
                        Unfortunately, replacing the motherboard would require me to purchase a new case and PSU as well. Look at the link above. I might be able to adapt the current PSU to work with a modern ATX motherboard.
                        I would like to solve the problem that this computer is having. If this is impossible, the next step would be to repair the old Gateway motherboard that won't turn on. If both of these fail, then I will take advice on replacement hardware.
                        • pfrcom
                          Oldbie
                          • Jun 2006
                          • 1230
                          Cheers, Wizard
                          I'm still using one of these, a very late revision with sticker saying OK for K6-233 (a big deal in those days)
                          And have TAG SRAM chips installed to allow board to cache 512kb instead of default 64kb
                          Running a K6-3/450 underclocked to 400, at 6x 66mhz FSB, using undocumented settings for the CPU's 2.2v requirement
                          It's an all SCSI setup, so no overclocking to keep the controller (Asus SC-875) happy
                          The drawback of a HX chipset is that it supports only 72 pin RAM - so not easy to get larger memory capacity
                          • Wizard
                            • Mar 2008
                            • 2296
                            #33
                            And unfortunately the other boards that supports SDRAM and still use socket 7 do not exist with good chipset *at all*. HX was the good one.
                            I suggest jump to PII 300 (512K cache) on P2B or socket 370 board 815 chipset. All of these have no issues as long as you have plenty of PCI slots for old video cards and these boards still have floppy interface and slow enough that is compatible with old games.
                            Cheers, Wizard
                            • lti
                              • May 2011
                              • 2557
                              Nobody understands what I'm trying to do.
                              This isn't my only computer or my fastest computer.
                              The games I play aren't old enough to require a slow CPU.
                              I'm not trying to make the computer slow.
                              I can't bring in more computer crap. Stop telling me what hardware I should have used. I don't have much to choose from.
                              There is nothing wrong with the hard drive or the memory.
                              • weirdlookinguy
                                • Sep 2007
                                • 1638
                                #35
                                Is there any chance you set the drive mode to PIO in the BIOS?
                                I did that once on an old PII machine I had. I have no idea how, it just happened. It ran like a piece of shit for months until one day I was poking around in the BIOS and noticed. Switched it back and all was right in the computer world.
                                • mockingbird
                                  • Dec 2008
                                  • 5488
                                  #36
                                  Can't you just run Virtualbox in Windows and install Windows 98 on it?
                                  • toastygoodness
                                    • Jul 2005
                                    • 813
                                    yeah i would agree with this. full vesa capabilities too. even Virtual PC is supposed to work.
                                    and if limiting your ram to 128MB doesn't speed it up and you're absoutely sure your PSU, RAM, HD and VRM are okay, then well, you can't really do anything other than change the limited bios settings you have, since its a compaq bios. SiS is very finicky.
                                    • Per Hansson
                                      • Jul 2005
                                      • 5895
                                      • Sweden
                                      #38
                                      www.dosbox.com
                                      www.scummvm.org
                                      • Agent24
                                        I see dead caps
                                        • Oct 2007
                                        • 5086
                                        • New Zealand
                                        #39
                                        Have you checked for a BIOS upgrade?
                                        Have you reset BIOS and checked the options as someone else suggested?
                                        SiS 5598 is pretty old, so the capacitors would be too - maybe they are bad - don't forget what site this is!
                                        (What about PSU too?)
                                        I have also noticed with older computers is that sometimes old hard drive cables etc can fail - OK when they're sitting there but when you move them when you're playing around with upgrades, suddenly they don't work properly.
                                        -David VanHorn
                                        • lti
                                          • May 2011
                                          • 2557
                                          There are no BIOS updates and I reset all BIOS settings to defaults.
                                          Could a timing cap or some component in the clock generator circuit be bad? I have a dead board that is identical to the one in this computer. I could swap parts between boards.
                                          I'm not sure if the caps on the motherboard and PSU are good or not. I don't have a way of testing their ESR. I can only check capacitance.
                                          Do any of those VMs and emulators support 3D graphics at a reasonable speed? I remember hearing that DOSbox emulated a Voodoo card, but it required a faster CPU than anything currently available.
                                          • TuanTongbadcaps
                                            Change CPU multiplier through BIOS editing
                                            by TuanTongbadcaps
                                            Is there a way to change the CPU multiplier through editing the laptop's BIOS. I have a Latitude 7300 using Intel core I7-8665U CPU which has default multiplier settings between x4.0-x48.0. The problem with the device is that as soon as Windows boots up, the processor temperature is always high (usually in the range of 97-100 degrees Celsius), the multiplier is in the range of x46.0 - x48.0 even though no applications enabled. On a desktop we can change many things related to core voltage, multiplier or base frequency. but on laptop models using U suffix processors this is not available. I would...
                                            07-22-2024, 07:57 PM
                                          • GLISIT
                                            by GLISIT
                                            01-16-2025, 02:29 PM
                                          • kotel studios
                                            Epox EP 85 MVP3C-M - 3.54v Vcore regardless of jumpers
                                            by kotel studios
                                            Recently I got an Epox EP-85 MVP3C-M board from scrap. After fixing the broken caps I powered it on without CPU and the jumpers set to 60Mhz FSB and 2x multiplier.
                                            Sadly, Vcc3 was stuck at 3.54v regardless of jumpers. Vcc2 (Vi/o I think) was also the same voltage.
                                            So, I've returned to the original configuration I got the board in - 100Mhz FSB and 4x multiplier. Voltages haven't changed at all.
                                            What I've tried so far:
                                            replace the original N-MOSFETs with beefier 60V ones for testing
                                            Resolder the resistors near the Vcore Jumper block
                                            Short Vcore...
                                            05-25-2025, 01:46 AM
                                          • eccerr0r
                                            AMD AthlonXP multipliers on old motherboards...
                                            by eccerr0r
                                            Is there a way I can get higher multipliers on old AMD motherboards?
                                            Was looking at an old socket A board that does not support AthlonXP's. It has a BIOS multiplier limit that's not quite high enough, which is fine for the old clock unlocked Athlons. What happens if I stick an AthlonXP that needs a higher multiplier?
                                            If I'm stuck at the highest BIOS set multiplier, is it possible to get a higher multiplier than the limit, or would it work like Intel boards that automagically use the chip locked multiplier regardless of what the BIOS is set?
                                            02-22-2021, 02:13 AM
                                          • GardevoirForEver
                                            Embedded Controller issues, living an absolute H*LL with my ASUS Vivobook Pro 16X OLED
                                            by GardevoirForEver
                                            I've been dealing with so many complications for months, trying to find and then fix the root cause of the issue I really need help and I have to solve this on my own (Going to Asus headquarters isn't an option for me. First, because I'm very stubborn and want to insist that I can fix this sort-of-myself somehow, and second, the location is too far away for me anyway).
                                            Right now I'm desperate trying to put an end to this nightmare, but OK, I'll do my best to be somewhat brief in explaining and relating the entire situation and context.
                                            The motherboard of my ASUS...
                                            Yesterday, 04:30 PM
