Change CPU multiplier through BIOS editing
  • TuanTongbadcaps
    • Mar 2023
    • 64
    • VietNam
    Is there a way to change the CPU multiplier through editing the laptop's BIOS. I have a Latitude 7300 using Intel core I7-8665U CPU which has default multiplier settings between x4.0-x48.0. The problem with the device is that as soon as Windows boots up, the processor temperature is always high (usually in the range of 97-100 degrees Celsius), the multiplier is in the range of x46.0 - x48.0 even though no applications enabled. On a desktop we can change many things related to core voltage, multiplier or base frequency. but on laptop models using U suffix processors this is not available. I would like to know if there is a similar solution to this problem on laptops?
  • istvanszasz99
    Razer Blade 15 (2022) RZ09-0421 BIOS Modding / editing help request
    by istvanszasz99
    Product ID: RZ09-0421
    Motherboard: CH580
    Bios File Size: 32,768 KB
    Dear Forum Readers!
    !!! MY RAZER BLADE...
    11-24-2025, 05:52 PM
  • zenius
    by zenius
    12-08-2024, 06:13 AM
  • abhorsen
    Help Disabling Flash Protection Range Registers on Lenovo P360 Tiny BIOS
    by abhorsen
    Hey guys,
    Hope you all are doing well. I come here from Win-Raid because I am having issues disabling Flash Protection Range Registers so I can flash my BIOS from within Windows using Intel's IFW tool/using flashrom within Linux, however I cannot due to the above mentioned error.
    Here is my thread on Win-Raid detailing the whole process I went through: https://winraid.level1techs.com/t/re...h-gen/95478/27
    Essentially I managed to boot into Windows while shorting PINs 1+5 of my audio chip to disable the HAP bit...
    07-06-2023, 10:22 AM
  • macabook
    by macabook
    🧩 Initial Issue
    07-24-2025, 02:17 PM
  • cr4zychriss
    by cr4zychriss
    • Rebrand: PC Specialist
    11-14-2025, 04:04 PM
