Computer is slower after upgrading CPU
  • lti
    • May 2011
    • 2557
    Re: Computer is slower after upgrading CPU
    Yes, DMA is enabled.
    I wasn't expecting the hard drive to be bad since programs didn't take longer to open. With less RAM, some programs now take longer to load, but they run at almost the speed I was expecting when I upgraded the CPU.
    • Agent24
      I see dead caps
      • Oct 2007
      • 5086
      • New Zealand
      #82
      Oh right, well to be honest I haven't been reading this thread thoroughly, but someone else suggested you should run the HDD diagnostics so I just assumed that there was some kind of issue with it
      -David VanHorn
      • pfrcom
        Oldbie
        • Jun 2006
        • 1230
        If my computer was inexplicably going slow, and I saw its disk Seek Error Rate exceeding 30 BILLION, I'd try another disk
        Your ST38410A is an ancient drive by consumer computer standards where old means not this week's model
        And it's a U8 series as well - not renowned for performance
        Maybe high seek error rates are explicable with current perpendicular recording drives, but I doubt it applies to an old longitudinal recording drive
        BTW, the disk in the first computer I worked with was an IBM 1405 RAMAC - try Googling that
        better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
        • Agent24
          I see dead caps
          • Oct 2007
          • 5086
          • New Zealand
          #84
          That huge number is just the RAW data from SMART. It could mean anything. It could be a decimal coded hex value of the checksum of something (Yes that probably doesn't make sense but it probably makes sense from the point of view of what I am trying to say). In my experience ALL Seagate drives report a "high" RAW number for those values, and it is normal.
          Maxtor on the other hand is normally 0 for those values, until there is an error.
          The "official" description says: "The raw value has different structure for different vendors and is often not meaningful as a decimal number."
          (http://en.wikipedia.org/wiki/S.M.A.R....T._attributes)
          For this drive, what you really should look at is the threshold value and current value, when the current value (in this case it is 66) drops below the threshold (which is 30) then you can say the disk is outside of SMART health levels and is failing.
          -David VanHorn
          • pfrcom
            Oldbie
            • Jun 2006
            • 1230
            There's theory and there's practice
            If it was me, I'd be using Seagate's diagnostics rather than a third-party tool
            I'd go for SeaTools for DOS, and try to get an older version commensurate with that drive's vintage
            The OP's problem is mysterious slowness, and to me the drive shows abnormal
            If LTI really wants to use third-party tools, I'm quite fond of MHDD which can remap sectors if their performance is abnormal
            • Agent24
              I see dead caps
              • Oct 2007
              • 5086
              • New Zealand
              #86
              Seagate's diagnostic tools are rubbish in my opinion, I stopped using them a long time ago because they generally only say your drive is failing when it's on fire and the heads have all fallen off.
              I have had multiple faulty Seagate drives (mostly the problem was bad sectors which increase steadily with use) scanned with Seatools, and it found nothing wrong. On one drive it commented that some sectors were bad and would I like to fix them, when I said yes it told me it had done so, then prompted to do another scan. When it did, it came back telling me more sectors were bad... ad nauseum.
              All the drives failed SMART status on HDAT2 and Speedfan noted that there were high numbers of reallocated sectors and that the drives should be replaced (which is the same conclusion any sensible person would come to if their drive has over 600 bad sectors with many more pending and more failing every day)
              Why did Seatools not say the drives were bad? I have no idea. Perhaps Seagate wants to pretend your drive is OK hoping the warranty runs out before the drive completely dies and you realise Seatools is useless. I don't know.
              -David VanHorn
              • TuanTongbadcaps
                Change CPU multiplier through BIOS editing
                by TuanTongbadcaps
                Is there a way to change the CPU multiplier through editing the laptop's BIOS. I have a Latitude 7300 using Intel core I7-8665U CPU which has default multiplier settings between x4.0-x48.0. The problem with the device is that as soon as Windows boots up, the processor temperature is always high (usually in the range of 97-100 degrees Celsius), the multiplier is in the range of x46.0 - x48.0 even though no applications enabled. On a desktop we can change many things related to core voltage, multiplier or base frequency. but on laptop models using U suffix processors this is not available. I would...
                07-22-2024, 07:57 PM
              • GLISIT
                by GLISIT
                01-16-2025, 02:29 PM
              • kotel studios
                Epox EP 85 MVP3C-M - 3.54v Vcore regardless of jumpers
                by kotel studios
                Recently I got an Epox EP-85 MVP3C-M board from scrap. After fixing the broken caps I powered it on without CPU and the jumpers set to 60Mhz FSB and 2x multiplier.
                Sadly, Vcc3 was stuck at 3.54v regardless of jumpers. Vcc2 (Vi/o I think) was also the same voltage.
                So, I've returned to the original configuration I got the board in - 100Mhz FSB and 4x multiplier. Voltages haven't changed at all.
                What I've tried so far:
                replace the original N-MOSFETs with beefier 60V ones for testing
                Resolder the resistors near the Vcore Jumper block
                Short Vcore...
                05-25-2025, 01:46 AM
              • eccerr0r
                AMD AthlonXP multipliers on old motherboards...
                by eccerr0r
                Is there a way I can get higher multipliers on old AMD motherboards?
                Was looking at an old socket A board that does not support AthlonXP's. It has a BIOS multiplier limit that's not quite high enough, which is fine for the old clock unlocked Athlons. What happens if I stick an AthlonXP that needs a higher multiplier?
                If I'm stuck at the highest BIOS set multiplier, is it possible to get a higher multiplier than the limit, or would it work like Intel boards that automagically use the chip locked multiplier regardless of what the BIOS is set?
                02-22-2021, 02:13 AM
              • GardevoirForEver
                Embedded Controller issues, living an absolute H*LL with my ASUS Vivobook Pro 16X OLED
                by GardevoirForEver
                I've been dealing with so many complications for months, trying to find and then fix the root cause of the issue I really need help and I have to solve this on my own (Going to Asus headquarters isn't an option for me. First, because I'm very stubborn and want to insist that I can fix this sort-of-myself somehow, and second, the location is too far away for me anyway).
                Right now I'm desperate trying to put an end to this nightmare, but OK, I'll do my best to be somewhat brief in explaining and relating the entire situation and context.
                The motherboard of my ASUS...
                Yesterday, 04:30 PM
