Sleeve Bearing: still the quietest
  • weirdlookinguy
    • Sep 2007
    • 1638
    I had some "main rig mayhem" of my own this past week. As some of you may know, I like my computers QUIET! and will not tolerate even the slightest fan noise.
    My computer has 4 fans in it:
    -Stock Intel cooler Nidec fan, PWM. Fairly quiet.
    -Turbine fan in my graphics card, it is a Magic ProTechnic. Fairly quiet.
    -120mm Yate Loon fan in my Delta PSU. Silent.
    -120mm Cooler Master sleeve bearing fan for rear case exhaust. Silent.
    Well, this last week, the cheap Cooler Master fan started making some horrid grinding-type sounds. I would wiggle the fan blades a bit and it would go away. It would only do this at power-up, and it didn't do it every time, only sometimes. Looks like the bearings are just starting to pack up their things and get ready to go out.
    I figured it was time to deep-six the Cooler Master and put a new one in. So out came the Cooler Master and in went this lovely thing:
    Enermax HYDRO BEARING! With BAT-WING DESIGN. DETACHABLE BLADES. SUPER SILENT. 100,000 HOURS MTBF. Holy shit batman! Someone call the cops, this sounds like an awesome fucking fan!
    I put it in and hit the power button.
    This thing is LOUD. Sounds like a howling wind tunnel.
    I don't care how much air the damn thing moves. I let it sit in there for a few days and it drove me up the wall. I had to shut off my PC at night because I couldn't sleep with a tornado next to my bed.
    Today I took the old Cooler Master, removed the sticker, removed the rubber plug, cleaned the original grease off the spindle with a q-tip and put a drop of Auto Tranny Fluid in there. I put it back together and popped it back in my PC.
    Silence. A relief to my ears.
    Hopefully my ATF thing will keep the Cooler Master running for a while. I know its a cheap Sleeve Bearing POS. I don't care. It moves air, and it is quiet.
    The Enermax is going back to Fry's in a few hours.
  • yyonline
    • Jul 2009
    • 692
    Re: Sleeve Bearing: still the quietest
    I'm with you there on the quiet PCs. I suffer from recurrent ear infections and tinnitus, so I don't deal well with any sort of droning background noises. My current main system uses an abit board and every fan header is voltage controlled with user-defined temperatures. It's near silent most of the time, but will make some noise if I'm doing something CPU intensive, which is fine. I don't do CPU intensive things when I'm trying to sleep, so it's silent then. Currently my PC has 4x Scythe 120mm fluid dynamic bearing fans. More or less "sealed" sleeve bearings, so they're quiet, but have longer lifespans. They idle at 6V or about 800rpm. If the PC gets hot, they'll ramp up to 1600rpm which is rather noisy. I'm using a Thermalright Ultra120 Extreme CPU cooler, which was the best CPU cooler on the market when I built the thing. I'm running a 130W Core 2 QX6800, so the thing does indeed put out some heat, but it doesn't seem any hotter than other Core 2s at idle.
    I'm really going to miss abit when it comes time to retire my current PC, as I haven't found another manufacturer out there with the same degree of fan control. Yeah, I know there are manual controllers out there, but having to remember to turn it up and down is a pain. Plus they're usually ugly with LEDs on them. (On a slightly related note... I strongly dislike LEDs in computers as well...I unhooked all my case LEDs and spent $50 on the only card reader I could find without an annoying power LED.)
    Sleeve bearing is techincally the quietest, but I stopped using them a few PC builds ago as I got sick of changing them out every time they started making funny sounds. Since you relubed your fan, how did you get the sticker on the back to re-stick? I've never had much luck getting them to stay on after removing them. An ordinary paper sticker isn't impervious to oil... So I'm curious how you dealt with that.
    • willawake
      Super Modulator
      • Nov 2003
      • 8457
      • Greece
      you can see its going to be loud by the shape of the blades
      • ratdude747
        Black Sheep
        • Nov 2008
        • 17136
        wlg- that os a overclocker's fan, not a quiet fan. notice the lack of pwm.
        i might be getting an arctic cooling hydobearing fan, but it has pwm, so it should only be loud if there is a high load.
        sigpic
        (Insert witty quote here)
        • acstech
          GrumpyModerator
          • Jul 2007
          • 1432
          I am sure your atf will work fine. It is a good that you chose a thin oil rather than a thick one or a grease. Placing grease on a noisy fan will only work for a short period of time. However, I still say that Hoppe's lubricating oil is the best stuff for re-lubing sleeve bearing fans.
          http://www.hoppes.com/products/lubricating_oil.html
          A man convinced against his will is of the same opinion still.
          • Krankshaft
            • Jan 2007
            • 2328
            My comp has 5 120mm low speed Yate loons that includes one I put into the power supply. They were still too noisy for me so I undervolted them to 5 volts.
            The stock Intel coolers are noisy when the speed kicks up I used an Arctic Cooling Freezer 7 Pro. PWM controlled and even at full speed whisper quiet. Mainly because it uses a huge heat pipe based heat sink with a larger surface area which allows a quieter fan rated at a lower CFM instead of a smaller ingot of aluminum and using a noiser fan at a higher CFM.
            http://www.newegg.com/Product/Produc...82E16835186134
            Arctic cooling makes some quiet standalone fans too but they're a bit pricey around 14 bucks a fan too rich for my blood.
            I'm glad I'm not the only one who finds the whooshing sound of a wind tunnel in a comp from noisy fans maddening.
            • ratdude747
              Black Sheep
              • Nov 2008
              • 17136
              I am considering a $10 pwm arctic cooling 92mm fan with a fluid dynamic bearing for my main rig... if what you are saying is true, then it might be a good buy (since my fan needs pwm to stay quiet without weird speed fluctuations).
              sigpic
              • delaware74b
                • Apr 2009
                • 628
                I have a small bottle of 3-in-1 oil for small motors that I use to relube fans. In a pinch, I use Wahl's clipper blade oil.
                Stupidity should be a crime, especially for drivers. I have NO patience for them.
                • kc8adu
                  • Nov 2003
                  • 8832
                  • U.S.A!
                  http://www.iqproducts.com/pf_primis/primis_lubegel.htm
                  best fan lube there is.
                  i suspect that a fresh drop of any good oil once a year in these fans will make them run forever.i do this and have 10 year old case fans that run 24/7/365 and no signs of wear.
                    master hoarder
                    • May 2008
                    • 12175
                    • Bulgaria
                    And if you take them apart (remove c-clip/locking washer and take rotor off), clean thoroughly, lube, then put back together, they'll last even longer and won't need to be re-lubed every year.
                    For fans that have gone completely seized, I even resurface the sleeve bearing. It's quite simple, actually - just take a small screw driver and scratch the sleeve parallel to the shaft. Clean thoroughly afterwards. The tiny scratches will remove any grinding noise and make the sleeve retain oil for much longer.
                    • Krankshaft
                      • Jan 2007
                      • 2328
                      I've used their graphics card and CPU coolers which had their fans mounted to them because I got sick of the stock ones throttling up when gaming.
                      They also use rubber isolation bushings on the motor cage to isolate it from the fan housing which dampers vibration.
                      • TheLaw
                        • Jan 2011
                        • 477
                        I use Scythe S-Flex fans for intake (800RPM), exhaust (800RPM), and CPU (1600RPM). Yate in the PSU. Passive video card heatsink.
                        Excellent combo. Cost more than I would have wanted but it's a perfect balance of airflow to noise. And the fluid bearings will last just about forever unless you get something in the liquid part...which is pretty difficult.
                        And all of them are running at max speeds. I hate when fans suddenly speed up and slow down. More annoying than constant noise imho.
                        • weirdlookinguy
                          • Sep 2007
                          • 1638
                          The Cooler Master had a foil sticker and a rubber plug behind the sticker, so I had no problems with it leaking. The fan has been running for 48 hours now and is still smooth and quiet, so it looks like the ATF took well.
                          The packaging for the 12v Tornado - erm, sorry, ENERMAX ADVANCED HYDRO-BEARING with DETACHABLE BLADES! said the fan produced 18dB max.
                          *flips off Enermax*
                          • Wizard
                            • Mar 2008
                            • 2296
                            Sleeve bearing fans are quiet when new like ball bearing fans does but for long term ball bearing are good especially if using quality brand of fans instead of what you get with the generic stuff. With some exceptions: like Intel retail cpu with heatsink have premium fan.
                            Cheers, Wizard
                            • nnname
                              • Jul 2010
                              • 20
                              I own three Enermax' Cluster fans that mostly run at 580—650 RPM. Although they are older than one year with spinning at least 10 hours a day, their bearings do not seem to tear at all. Normal sleeve bearnings do clatter after a certain period of time.
                              • Colt45ws
                                • Jan 2009
                                • 174
                                I had one of those exact enermax twister fans. Locked up tight after 2 months of use. Didnt flow any air at all either. Its too bad I cant find the ceramic bearing ones I already have again. They seem to last forever, quiet and move air decently.
                                • Topcat
                                  Cooler Master ATC-S + Some other CoolerMaster Case - 2-fer in 1 Thread
                                  by Topcat
                                  This is a Coolermaster case double-header.... The reason this one didn't get added to my 'misc build' thread is becasue the Cooler Master ATC-S aluminum case....That case is a class-act way above & beyond anything in that thread! However, we have to get through a mediocre build to get to the treasure!
                                  ...but here's the two Cooler Master cases in question; both of which were drop-offs for recycling.... The one on the left, I'm not really sure what model it is. It's nothing overly special, but it is well-made. The one on the right is an ATC-S solid aluminum, best I can determine...
                                  03-12-2022, 10:58 PM
                                • anikin73
                                  Cooler Master 500W atx psu repair. Total cannot start at all
                                  by anikin73
                                  I am attempting to repair this. Circuit is quite simple, but i a quite stuck at it for a long time. so today i try to ask for new ideas. my challenge is to under stand what mistake i made. I had repaired not lesson than 50 pcs of various brands ATX psu . main pwm chip is Cm 6805 Sip 9 .
                                  5VSB is fine. When I short Pson, totally nothing happen. I check , the Cm 6805 VCC pin2 did have 16v, But totally nothing happen. I changed to a good chip from another good PSU. Same thing.
                                  What other pin should I check such that it will result in no start up at all ?
                                  07-07-2024, 07:06 AM
                                • dariolana
                                  ATX PSU Cooler Master RS-700-pcaa-e3 shutting off after 5 seconds
                                  by dariolana
                                  Got this from my kid with a fault on primary side. Main power supply here is AC 220V. All caps were Ok, testing with 2 series lamp of 70W each, got a bright lamp . Checked main heatsink one by one with my component tester and found one 3 leg buddy MDP18N50 that passed away. Got same replacement after a week, tested, short was gone, now I got 310V on primary.
                                  Happy as a dog, added one case fan for some load and the fan of the PSU. Tested purple wire, got 5.1V, great!. Shorted green and black, fan spins and after about 5 seconds shuts down. I was able to measure doing several iterations...
                                  02-26-2024, 07:47 PM
                                • stomanata
                                  Problem with PSU Cooler Master MPX-5501-AMAAB
                                  by stomanata
                                  Happy new year.
                                  This PSU use WT7527V supervisor.
                                  On purple cable i have 5V, but on #4 of WT7527V i have 0.21V.
                                  If i try to start PSU with short between green and black it star for a second and stop.
                                  For what other to check? I now that is needed more info but i don`t know what else to share
                                  01-07-2024, 11:48 AM
                                • tony359
                                  Cooler Master 1200W Silent Pro Gold - Bad power switch
                                  by tony359
                                  The PSU in question had a bad power switch. There was not physical feedback when switching on and - if memory serves - it was always ON even when in OFF position.
                                  I researched a bit and got some replacements.
                                  The replacement "got stuck" at first power up - as in "it's now always on".
                                  It looks like this PSU has a pretty large inrush current as my lights flicker when I turn it on with no load.
                                  Probably the switches I got are bad quality but I was wondering if someone could recommend a good replacement?...
                                  06-18-2023, 11:42 AM
