Scythe Fuma 3 or Cooler Master MA620M
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5044
    • US
    I have a 5900x to replace my 5800x (actually a fair bit of performance difference). It came with the CM. I can't actually find any article of a direct comparison between the two. The Fuma has a Higher TDP but the CM looks to have a more solid build. Fresh AS5 either way.
    1
    Scythe Fuma 3
    100.00%
    1
    0%
    0
    • 31258
    fuma 3 fans can move more air if they need to.
    both are huge - thats why i switched to AIO water cooling.
    • Uranium-235
      Comrade Glimmer
      • Aug 2007
      • 5044
      • US
      Yeah the CM has one quiet fan in the middle, but the entire heatsink is connected (vs two seperate fin arrays). I can always increase the fan curve.
      I would love to use an AIO but I have these two, and I don't want to spend any $$$.
      • Topcat
        Cooler Master ATC-S + Some other CoolerMaster Case - 2-fer in 1 Thread
        by Topcat
        This is a Coolermaster case double-header.... The reason this one didn't get added to my 'misc build' thread is becasue the Cooler Master ATC-S aluminum case....That case is a class-act way above & beyond anything in that thread! However, we have to get through a mediocre build to get to the treasure!
        ...but here's the two Cooler Master cases in question; both of which were drop-offs for recycling.... The one on the left, I'm not really sure what model it is. It's nothing overly special, but it is well-made. The one on the right is an ATC-S solid aluminum, best I can determine...
        03-12-2022, 10:58 PM
      • anikin73
        Cooler Master 500W atx psu repair. Total cannot start at all
        by anikin73
        I am attempting to repair this. Circuit is quite simple, but i a quite stuck at it for a long time. so today i try to ask for new ideas. my challenge is to under stand what mistake i made. I had repaired not lesson than 50 pcs of various brands ATX psu . main pwm chip is Cm 6805 Sip 9 .
        5VSB is fine. When I short Pson, totally nothing happen. I check , the Cm 6805 VCC pin2 did have 16v, But totally nothing happen. I changed to a good chip from another good PSU. Same thing.
        What other pin should I check such that it will result in no start up at all ?
        07-07-2024, 07:06 AM
      • dariolana
        ATX PSU Cooler Master RS-700-pcaa-e3 shutting off after 5 seconds
        by dariolana
        Got this from my kid with a fault on primary side. Main power supply here is AC 220V. All caps were Ok, testing with 2 series lamp of 70W each, got a bright lamp . Checked main heatsink one by one with my component tester and found one 3 leg buddy MDP18N50 that passed away. Got same replacement after a week, tested, short was gone, now I got 310V on primary.
        Happy as a dog, added one case fan for some load and the fan of the PSU. Tested purple wire, got 5.1V, great!. Shorted green and black, fan spins and after about 5 seconds shuts down. I was able to measure doing several iterations...
        02-26-2024, 07:47 PM
      • stomanata
        Problem with PSU Cooler Master MPX-5501-AMAAB
        by stomanata
        Happy new year.
        This PSU use WT7527V supervisor.
        On purple cable i have 5V, but on #4 of WT7527V i have 0.21V.
        If i try to start PSU with short between green and black it star for a second and stop.
        For what other to check? I now that is needed more info but i don`t know what else to share
        01-07-2024, 11:48 AM
      • tony359
        Cooler Master 1200W Silent Pro Gold - Bad power switch
        by tony359
        The PSU in question had a bad power switch. There was not physical feedback when switching on and - if memory serves - it was always ON even when in OFF position.
        I researched a bit and got some replacements.
        The replacement "got stuck" at first power up - as in "it's now always on".
        It looks like this PSU has a pretty large inrush current as my lights flicker when I turn it on with no load.
        Probably the switches I got are bad quality but I was wondering if someone could recommend a good replacement?...
        06-18-2023, 11:42 AM
