ATX PSU Cooler Master RS-700-pcaa-e3 shutting off after 5 seconds
This topic has been answered.
  • dariolana
    • Jun 2023
    • 13
    • Argentina
    Got this from my kid with a fault on primary side. Main power supply here is AC 220V. All caps were Ok, testing with 2 series lamp of 70W each, got a bright lamp . Checked main heatsink one by one with my component tester and found one 3 leg buddy MDP18N50 that passed away. Got same replacement after a week, tested, short was gone, now I got 310V on primary.
    Happy as a dog, added one case fan for some load and the fan of the PSU. Tested purple wire, got 5.1V, great!. Shorted green and black, fan spins and after about 5 seconds shuts down. I was able to measure doing several iterations after to short green and black 12V 5V -12V (thru a LM7912 with heatsink) and 3.3V....and every time the PSU shuts off after 5 seconds....Checked secondary side all caps, no bulged at all, anyway I pulled them, check uf and ESR all are fine. No burnt parts or brown...
    With only a multimeter I tested all discrete components on the PCB. There are no shorts across components and all diodes' forward voltages are within expectations. Haven´t checked the switching components at secondary but as I am getting all main voltages I guess that should be fine. There isn´t a TL494 on this board, It has a vertical board with a TNY278PN on secondary side of the board
    Any ideas on how to keep going ahead to bring back this baby are really appreciated.
  • Answer selected by dariolana at 02-29-2024, 08:22 PM.
    CapLeaker
    Leaking Member
    • Dec 2014
    • 8340
    You can't use the light bulb in series trick while loading the secondary. After you fixed the short, you should test the PSU no or very little load on the secondary, while using the light bulb in series trick. After you confirmed all rails are up and running, plug the PSU straight to power mains and load it up if you want. Since the light bulb in series with power mains from the PSU, the lamps will limit the current to the PSU, making the PFC in the primary working very hard. That's not good.
    • harp
      • Jun 2022
      • 643
      • Planet Earth
      Connect this psu with test motherboard and see if it will work.
      I have same issue, see on 15min how psu react... all good few sec and shutsdown.
      https://m.youtube.com/watch?v=d7jXHcYf9wk
      You can check and monitor gray PG wire, powergood while do so.
      • dariolana
        • Jun 2023
        • 13
        • Argentina
        hello, more info to consider, with current PSU of 700W after to short green and black and the fan starts to spin, noticed that one or two lamps of 70W were glowing!!, indicating a higher consumption. So I´ve added the AC current clamp meter and read 0.6A on the 220V line. Scratching my head about this, went to my storage and grabbed another PSU of smaller power, about 400W, connected it with the same fan, and one or two ligth were almost off, got the clamp meter and read 0.3A, so it seems that besides the short is gone, there is higher consumption so I seems that there is another component that is bad or not balanced on the hot side I guess...
        • harp
          • Jun 2022
          • 643
          • Planet Earth
          This look like APFC acting.
          Look on 13:30 behaveour, is the same?
          https://m.youtube.com/watch?v=aMMzu436MBA
          Solution is to use toaster with 700w or so, not lights bulbs, it is on this forum thread about this.
          APFC drow more power for compensating voltage drop...
          • CapLeaker
            Leaking Member
            • Dec 2014
            • 8340
            • dariolana
              • Jun 2023
              • 13
              • Argentina
              Dear CapLeaker, followed your advice and....YES, no smoke and the issue disappear. Also the temperature is equal for both mosfets. Really appreciated.
              • dariolana
                • Jun 2023
                • 13
                • Argentina
                Thanks HARP for the reply. Following your advice and CapLeaker the issue is solved. Today I´ve reassembled the whole thing and the kid is playing again.
                Thanks again for your help with this
                • Uranium-235
                  Scythe Fuma 3 or Cooler Master MA620M
                  by Uranium-235
                  I have a 5900x to replace my 5800x (actually a fair bit of performance difference). It came with the CM. I can't actually find any article of a direct comparison between the two. The Fuma has a Higher TDP but the CM looks to have a more solid build. Fresh AS5 either way.
                  Scythe Fuma 3
                  100.00%
                  1
                  0%
                  0
                  11-01-2025, 02:08 AM
                • pronester
                  Cooler Master 550 watt - fan spins few seconds and then stop
                  by pronester
                  Hi guys,
                  i got this broken computer PSU with model number MPX5501AMAAB.
                  i detected that 1 of the diode (model number: SB2100) was broken and replaced with a new one. but that not solved the issue as the problem is still persists which indicates that other components are also shorted. maybe someone can advice on what to do next?
                  I attached some pictures for reference.
                  on the other hand, i encountered quite a few PSUs with the same problem..i.e the diode is shorted/opened but replacing it not solving the issue..may this be a good indicator...
                  11-07-2022, 03:56 AM
                • Topcat
                  Cooler Master ATC-S + Some other CoolerMaster Case - 2-fer in 1 Thread
                  by Topcat
                  This is a Coolermaster case double-header.... The reason this one didn't get added to my 'misc build' thread is becasue the Cooler Master ATC-S aluminum case....That case is a class-act way above & beyond anything in that thread! However, we have to get through a mediocre build to get to the treasure!
                  ...but here's the two Cooler Master cases in question; both of which were drop-offs for recycling.... The one on the left, I'm not really sure what model it is. It's nothing overly special, but it is well-made. The one on the right is an ATC-S solid aluminum, best I can determine...
                  03-12-2022, 10:58 PM
                • Pygo86
                  Liyama G-Master GB3466WQSU-B1 - Backlight on - Shutdown after a few Seconds
                  by Pygo86
                  Hey Folks,
                  i'm not far into Monitor troubleshooting. It's my first time. Normaly i try to repair Laptops.
                  The Monitor is powering up. And the Backlight turns on. After a few Seconds the Backlight shuts off and the Power LED turns form Blue to Red.
                  I can power it up again, but it's always the same Result.
                  No Matter which Connection is used.
                  I can't see anything obvius after disassembling. No Heatspots with the Thermalcam visible.
                  The Powerboard is looking great. There is 12V and 5V everywhere on the Logicboard.
                  So, i decided to swap that Logicboard....
                  03-04-2024, 11:38 AM
                • Bard_the_Bowman
                  PS5 Disk Edition shutting down 5-30 seconds after boot, can't find any shorts
                  by Bard_the_Bowman
                  I have a PS5 that will turn off after anywhere from about 5 to 30 seconds after power-on. It will sometimes make it to Safe Mode, but won't last long there. The following are steps I have taken:
                  1 - Tested on multiple sources of 12v power including 2 separate bench power supplies. Doesn't fix the issue, which at least to my mind, rules out the power supply as the problem.
                  2 - Visual inspection of board. Absolutely no signs whatsoever of burns or failed components.
                  3- Checked for standby voltages. All seem normal.
                  4 - Added liquid metal and re-spread...
                  04-24-2023, 12:15 PM
