Fire starter PC cables
  • goodpsusearch
    • Oct 2009
    • 2850
    • Greece
    Ok, this is getting very irritating...
    I have a bunch of computer cables and lately I had 2 of them suddenly catching fire!
    My explanation is that 1 of the 3 wires got very thin or was completely cut and then it made sparks and melted the plastic.
    This is very dangerous because if the cable is sitting on a carpet or wooden floor it can start a big fire and.... burn the house...
    Does anyone have a similar experience?
    I found out that those cables usually have several logos and marks on them and some technical info I am not familiar with. The cables that caught fire have only the name of the company Fan-Jet Enterprise Co. LTD, model names FJ-002 FJ-013 and the typical cable rating 10-16A 250V~.
    Do you think I should toss any FAN-JET cables that I have, even if they still work (and haven't caught fire)?
  • weirdlookinguy
    • Sep 2007
    • 1638
    Re: Fire starter PC cables
    I'm going to go look through all my power cables, and if any are Fan-Jet I am going to cut the plugs off and throw them out.
    • seanc
      • Nov 2008
      • 1319
      Post a picture of the design? I have loads of different types power cables...
        master hoarder
        • May 2008
        • 12175
        • Bulgaria
        Interesting. Cut the burned cable where it wasn't damaged and see how it's constructed inside. Perhaps they used an insulation that was too thin or the wire was too thin? Also look on the side of the cable, and see if you can find any specs, like voltage and temperature rating, as well as gauge/thickness.
        Most of the PC/IEC cables I use around here are UL certified, 3x18awg.
        • dood
          Deputy dood
          • Mar 2004
          • 2462
          I had a laptop power cable burn up the other day. Nothing wrong with the adaptor, this was just the cable from the brick to the wall (straight AC). It actually created a little volcano in the plastic between the hot and ground on the plug and was spewing smoke from there. Grabbed it by the end of the cord and yanked it out. Very cautiously tried another AC cable with the same adaptor and have had no issues on the bench.
          Ludicrous gibs!
          • kc8adu
            • Nov 2003
            • 8832
            • U.S.A!
            no ul,csa,ce,ect logos?
            toss em!
            not that their presence means much on some stuff as they are often forged....
              • 31067
              i just had an xbox360 cable go, it went at the back of the inlet connector.
              not the fault of the manufacturer, it was the owner constantly wrapping the cable up - caused a kink in the cable.
              same as we'v all seen on vga cables behind pc's that get jammed against a wall.
              • goodpsusearch
                • Oct 2009
                • 2850
                • Greece
                Here are the photos... I put a random power cable near the jet-fan to compare...
                Notice the complete absence of logos and specs/ratings on the cable, socket and plug of the fan-jet.
                Other than that, I cannot find anything strange.
                That is exactly what happened with my cables too! A volcano ejecting fire and smoke
                • Shocker
                  Banned
                  • Dec 2011
                  • 635
                  Apart from Fan-Jet, I've seen two other types of counterfeit power cords. One was branded "DHT Electrical" (for the record, their AS plug has the L/N closer to the outside edge than the E ), with fake ratings (I don't remember what they were) and one was completely unbranded, with "18AWG" and "6-10A" markings. Before I knew they were fake I left two in use at someone else's place. Better go and hunt them down, before something terrible happens .
                  • c_hegge
                    • Sep 2009
                    • 5219
                    The Fan Jet cable does seem thinner than the other one.
                    FWIW, I have had a cable burn up years ago, although I have no idea what brand it was.
                    • Shocker
                      Banned
                      • Dec 2011
                      • 635
                      Also note the gap between the L and E wires in the Fan-Jet - unlike the neatly bundled wires in the real power cable. The Fan-Jet is actually about the same overall diameter as a real cord of type H03VV-F 3G 0.75mm².
                      This does look like a serious safety hazard. I'm glad you made the thread goodpsusearch - have to make others aware of the problem. To some extent they get away with crappy construction because PCs generally only draw about 150-200W. Of course it's only a matter of time before someone plugs a kettle into one of those...
                      I can bet that there would be a LOT less fires if strict quality standards were enforced on electrical equipment. I just thought up a good way to test IEC leads for safety - wire up a small electric heater with a C14, and insert the lead under test in the middle. If the lead goes poof, you have your proof.
                      • Shocker
                        Banned
                        • Dec 2011
                        • 635
                        Oh and by the way, the Fan-Jet cables are aptly named. They need a jet-fan cooling them to survive high wattages.
                        • Mad_Professor
                          A Mech Warrior
                          • Feb 2011
                          • 1587
                          The great solar storm of 2012-2013?
                          Source:
                          http://en.wikipedia.org/wiki/Solar_storm_of_1859
                          Telegraph systems all over Europe and North America failed, in some cases even shocking telegraph operators.[5] Telegraph pylons threw sparks and telegraph paper spontaneously caught fire.[6] Some telegraph systems appeared to continue to send and receive messages despite having been disconnected from their power supplies.[7]
                          Further reading:
                          http://www.wired.com/wiredscience/20...150-years-ago/
                          ok I'm coming back from Koo-koo-land.
                          It's most likely defective or counterfeit cables.
                          If the cord is warm or hot, you better change it.
                          • c_hegge
                            • Sep 2009
                            • 5219
                            • stevo1210
                              • Oct 2006
                              • 4156
                              I had a problem with a cable a few years back that would lose ground because the connection inside the hole was crap. I switched to all Kema-Keur cables and have been trouble free ever since.
                              Don't find love, let love find you. That's why its called falling in love, because you don't force yourself to fall, you just fall. - Anonymous
                              • Shocker
                                Banned
                                • Dec 2011
                                • 635
                                Um...Kema-Keur is a certification, not a brand.
                                • japlytic
                                  • Oct 2005
                                  • 2086
                                  Are there any recalls related to IEC-type cables? In the US, I have seen a number of recalls for extension leads; the most common reason is that the wires were undersized.
                                  • b700029
                                    Banned
                                    • Sep 2010
                                    • 640
                                    They sell different thicknesses of cables:
                                    http://www.monoprice.com/products/su...02&cp_id=10228
                                    18, 16, and 14 gauge. They have different ampacities.
                                    • ThePCDoctor
                                      Retired Tech.
                                      • Sep 2011
                                      • 59
                                      Overall, in this topic, it appears that most of the problems are occurring outside the US, where the line power is 220-230 VAC.
                                      In 30+ years as a professional tech, here in the US I've never seen a fire from a computer power cable.
                                      I seriously doubt if any of those cables are made here,,,,,probably in China.
                                      UL Rated? Forgetaboutit!
                                      Interesting thread!
                                      Cheers Mates!
                                      The Doctor
                                      Experience is truly the best teacher.
                                      Backup! Backup! Backup! Ghost Rocks!
                                      • popeye
                                        • May 2011
                                        • 155
                                        Looking at the picture of the plugs above the copy ones have no safety marks so I would put them in the rubbish where they belong and get supplies from reputable sources in future and always disconnect plugs from the mains when not in use?
                                          Acer TravelMate P214-52-566U+STARTER KIT 15'' Notebook P2 Specification for Upgrade or Repair
                                          This specification for the Acer TravelMate P214-52-566U+STARTER KIT 15'' Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P214-52-566U+STARTER KIT 15'' boardview and P214-52-566U+STARTER KIT 15'' schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                          09-06-2024, 07:20 PM
                                          Acer TravelMate P215-52-56G5+STARTER KIT 15'' Notebook P2 Specification for Upgrade or Repair
                                          This specification for the Acer TravelMate P215-52-56G5+STARTER KIT 15'' Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P215-52-56G5+STARTER KIT 15'' boardview and P215-52-56G5+STARTER KIT 15'' schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                        • jczarniak
                                          JVC Fire TV or any other Android based firmware
                                          by jczarniak
                                          Is there available any Android Fire TV ROM backup ( Fire TV Firmware ) which I can download, save on USB stick and then load into the TV ?
                                          I have got JVC LT-50CF810 Fire TV with firmware not working properly.
                                          Thank you very much for any support.
                                          Regards.
                                          10-18-2023, 01:43 AM
                                        • spleenharvester
                                          GRT60-145410 brick PSU, how much of a fire hazard is this thing exactly?
                                          by spleenharvester
                                          I bought an Alpicool C20 fridge, which is a 60W compressor fridge that runs on 12V or 24V, which can come from either an AC/DC adapter from mains (240V here in UK) or a car battery. The fridge itself is really good quality, so I was surprised to find the power supply (DC14.5V, 4.1A) pretty questionable. Despite being 240V/1.5A the plug was fitted with a 13A fuse - concerning, but not all that uncommon for imported chinese electronics here. But when I felt how light the brick was I immediately said hell no and transferred the proprietary connector to a MeanWell GS90A12-P1M brick (this supply is...
                                          07-08-2025, 06:02 PM
                                        • paulocoob
                                          HP 250 G8 Motherboard GPT52 LA-K201P CPU fire
                                          by paulocoob
                                          Hello forum friends.
                                          I want to ask for help diagnosing this GPT52 LA-k201p HP 250 G8 card (without dedicated GPU).
                                          The motherboard turns on and consumption is 2.2A (CPU fire)
                                          All voltages seem OK.
                                          The coil resistances are these
                                          [FONT="<font style="vertical-align: inherit;"><font style="vertical-align: inherit;">Lucida Sans Unicode</font></font>"]PL302 = 3.2kΩ
                                          PL301 = 30.1kΩ
                                          PLB2 = 10.1MΩ
                                          PLZ1 = 22Ω
                                          PLZ2 = 22Ω
                                          PLG1 = 77Ω
                                          PLM1 = 5Ω[/FONT]
                                          Could...
                                          11-13-2023, 07:54 AM
