JVC Fire TV or any other Android based firmware
  • jczarniak
    • Oct 2015
    • 179
    Is there available any Android Fire TV ROM backup ( Fire TV Firmware ) which I can download, save on USB stick and then load into the TV ?
    I have got JVC LT-50CF810 Fire TV with firmware not working properly.
    Thank you very much for any support.
    Regards.
  • Diah
    • Feb 2013
    • 6499
    Re: JVC Fire TV or any other Android based firmware
    could you explain.. how did you know the firmware issue?
    • jczarniak
      • Oct 2015
      • 179
      After switch on I can see JVC logo for a second and TV reboots and again logo and restart.
      • Diah
        • Feb 2013
        • 6499
        one second .. need to check first LED BL. if they are took high current at start up
        • jczarniak
          • Oct 2015
          • 179
          TV started doing this thing after I opened Android Recovery Mode and wiped data/factory reset . Prior to that TV was working fine just smart functions has been very slow.
          • Diah
            • Feb 2013
            • 6499
            what are yours mother boards No?
            • jczarniak
              • Oct 2015
              • 179
              Originally posted by diah
              what are yours mother boards no?
              17mb180e
              • Diah
                • Feb 2013
                • 6499
                okay... i cant find any at my archive ...
                so as i understand. Tv was very slow at apps and smart.. then you did factory reset from Recovery.. so think about 2 points
                1- slow down at TV apps or smart... mean the sector life cycle of the NANDclose to end or dead... in this case its NAND issue.. try freezing it then turn on... hope it will pass at least the first startup.
                2- at Factory Reset from Recovery... bring the TV to first shipping state.. include the LED BL setting as first time full bright.. consider it could happen too the LEDs get issue at this time... so we become confuse as we thinking they was working fine before the reset. so checking them are priority too.
                • jczarniak
                  • Oct 2015
                  • 179
                  Good point thinking about backlight LEDs
                  I'll check the backlight first.
                  • sabriTech07
                    Acer B3-A30 Firmware - RV02RC07 WW GEN1 (Android 6)
                    by sabriTech07
                    I'm looking for the official stock firmware for the Acer Iconia One 10 B3-A30 tablet with the following version:
                    • Firmware version: RV02RC07
                    • Region: WW GEN1 (WorldWide)
                    • Chipset: MediaTek MT8163
                    • Android version: 6.0
                    I've searched various sites but couldn't find this exact version. If anyone has a working download link or can share the firmware, I'd really appreciate it.
                    Thank you in advance!
                    05-15-2025, 05:52 AM
                  • mon2
                    Hisense 55Q9G Android reset / factory firmware reload
                    by mon2
                    Hello. Have a 55" Hisense TV that starts to load the Android OS (no backlight issues) -> reaches the app screen where you can view the assorted icons including Netflix and always crashes at the same point just after this launch. If I quickly press the cursor buttons, the cursor can navigate to the settings menu but will power off just after a few seconds of this activity. Do not believe it is power related since the crash is very accurate in the boot cycle.
                    After the OS 'crashes', the power does go off and the from white LED goes dark for about 20 seconds and then ON again....
                    01-03-2024, 10:25 AM
                  • zklgfs
                    Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
                    by zklgfs
                    I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
                    08-11-2025, 02:14 PM
                  • TheUser
                    Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
                    by TheUser
                    Hello to everyone ,
                    This is my first post here, and i would like to share with you a small story in case you can help me.
                    Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
                    All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
                    I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
                    02-10-2024, 02:07 PM
                  • gurj1979
                    Ubiquiti firmware help. US-8-150W POE
                    by gurj1979
                    Hi guys.
                    I've got a Ubiquiti US-8-150W POE switch which has issues with updating the firmware.
                    Turned out to be a bad EEPROM chip. It would read the firmware and work as normal, but failed to write new firmware to it.
                    So I took off the chip and read on EEPROM and saved it. Wrote to old chip and failed to write
                    Got New chip and writes good.
                    THE PROBLEM...
                    It fails to fully load the firmware, POE lights fail to work during g firmware test during load. I'm suspecting bad EEPROM Read.
                    Does anyone have a Good Firmware I can have?...
                    07-22-2024, 05:13 PM
