Cap question
  • LEEDASH
    • Dec 2012
    • 481
    • Bedfordshire
    Cap question
    Hello all I need some info I have posted to photos of two caps the green is the defunct cap the black is the so called replacement,but different size,can it be used.
    • 31026
    Re: Cap question
    where did you get the black crap-cap?
    • LEEDASH
      • Dec 2012
      • 481
      • Bedfordshire
      Re: Cap question
      Draw find eBay I think
      • LEEDASH
        • Dec 2012
        • 481
        • Bedfordshire
        Re: Cap question
        Would it be up to the job ? Or need replacing a month down the line
        • comptek
          • Aug 2013
          • 606
          Re: Cap question
          You go by uf and voltage not the temperature get a good make replacement for example 100uf 16v you can go higher on voltage not on the uf
          • LEEDASH
            • Dec 2012
            • 481
            • Bedfordshire
            Re: Cap question
            The are like for like but not in size
              • 31026
              Re: Cap question
              it may work, but cant say for sure without a datasheet.
              and that needs the makers name!
              • vinceroger69
                • Mar 2012
                • 6714
                Re: Cap question
                i brought some of those sd caps from ebay a couple of years ago, they lasted about 6 weeks on a tv inverter circuit before failing again, try and find a Panasonic replacement if i was you.
                • Techgeeky
                  • Oct 2017
                  • 15
                  • Turkey
                  Re: Cap question
                  Both look nonpolar?
                  • R_J
                    • 9535
                    Re: Cap question
                    In the first picture you can see the polarity stripe on both caps. And yes it will work, for how long... Let us know. Or use a name brand like Panasonic if you are worried.
                      master hoarder
                      • May 2008
                      • 12175
                      • Bulgaria
                      Re: Cap question
                      Trash-can them!
                      A good 99% of the caps sold on eBay are either cheap no-name junk like this or counterfeits of big-name brands like Nichicon, Chemicon, and Sanyo/Suncon. Just get some caps from one of the big online component distributors (RS, Farnel, Mouser, Digikey, Badcaps.net, or even member Behemot here).
                      Go with either Panasonic (as suggested above), Nichicon, Rubycon, or United Chemicon and skip the drama of wondering why the device you fixed with those crap caps is broken again.
                      • ayhan yılmaz
                        • Mar 2018
                        • 40
                        • TÜRKİYE
                        Re: Cap question
                        Black kapasitör 1000UF25V ok.
