Reduce the size of photos please..
This is a sticky topic.
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4535
    • Italy - Milan
    Hi all, i'm asking all to reduce photos to a more comfortable resolution before post, the better like around 2000x2000, otherwise many PC / Tablets / phones refuses often to load them or has strong defection... today's digital cameras integrated in phones especially are a mockery because them saves photos at enormous resolutions with much less the real definition, so reducing them is only a good deal.. THANKS!!
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4535
    • Italy - Milan
    Hi, for the answers comfort watching circuits on boards photos, keep please in mind the better is not to use camera's flash or any other spot lights, light the more the better, for this the direct sunlight is often the best.. bye
    • smort
      • Mar 2025
      • 16
      • us
      I think people upgrade devices far too often because basic functionality is destroyed by manufacturers with "updates." But, if no device you have is capable of viewing larger than 2000x2000, I hate to say it but it might be time to look for something with more RAM and/or more VRAM. I'm on a Celeron laptop from the windows 8 era, soldered 4GB RAM, but large photos don't seem to be as much a problem for my laptop as my internet connection.
      I personally think it's helpful if someone uploads a large image then chooses a medium thumbnail so we can click on it if we want more detail.
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4535
        • Italy - Milan
        Think about how much costs a web space, for a near zero ads..
        2k x 2k with low compression is a lot of space and a good resolution..
        • howardc64
          by howardc64
          Problem
          08-04-2024, 10:36 PM
        • m1ch43lzm
          Notice to users of XGecu TL866II Plus / T48 / T56 / T76 programmers regarding BIOS backup file size
          by m1ch43lzm
          Hi everyone
          I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
          Programmer models: XGecu TL866II Plus / T48 / T56 / T76
          Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
          There's also an extra OTP Secu.R...
          09-06-2025, 05:47 PM
        • dragometin
          Hitachi 40HYC42
          by dragometin
          TV Model: Hitachi 40HYC42
          Power Supply: 17IPS71
          MainBoard: 17MB95M
          Panel: VES400UNDS-2D-NO3
          When the set came in it was dead. Fuse was open primary side and the power mosfet was shorted. So I ordered a new power supply. Now it turns on, only displays "Hitachi" and then power off red and blue led flashing.
          I had to modify the 0ohm resistors in the led backlight of the new PS like the original power supply.
          Is there any variants on 17IPS71 power supply's?
          UART output pins 10 and 12 on scart connector:
          Code:
          12:24:04.595
          08-08-2024, 05:53 AM
        • saimom
          Asus FX507ZC4 DANJLFMBAB0 REV B I need photos
          by saimom
          Hello everyone!
          Please help me determine which microcontroller was in this place.
          Logically, I guess that this is a ddr4 PWM memory controller and some kind of Richtek, but which one?
          Thise motherboard came after another service, where they say that water got on the controller and it burned down and they dismantled it.
          They did not take photos before the intervention
          The DANJLFMBAB0 REV B board, schematics, boards and photos of the motherboard were not found on the network, but I may have searched badly-((
          Maybe someone has a photo of this piece,...
          12-17-2024, 08:51 AM
        • alltvrepairs
          Jvc Lt-65VU3000 reduce backlight from service menu
          by alltvrepairs
          I have just replaced led set of this vestel tv due to age.
          I would like to reduce backlight from service mode. I have tried menu 4725 but in the menu i can't change anything.
          Any help pls? I don't want to change from electronics inverter feedback resistor ideally.
          Thanks again....
          09-20-2025, 05:03 AM
