Reduce the size of photos please..
This is a sticky topic.
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4889
    • Italy - Milan
    Hi all, i'm asking all to reduce photos to a more comfortable resolution before post, the better like around 2000x2000, otherwise many PC / Tablets / phones refuses often to load them or has strong defection... today's digital cameras integrated in phones especially are a mockery because them saves photos at enormous resolutions with much less the real definition, so reducing them is only a good deal.. THANKS!!
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4889
    • Italy - Milan
    Hi, for the answers comfort watching circuits on boards photos, keep please in mind the better is not to use camera's flash or any other spot lights, light the more the better, for this the direct sunlight is often the best.. bye
    • smort
      • Mar 2025
      • 16
      • us
      I think people upgrade devices far too often because basic functionality is destroyed by manufacturers with "updates." But, if no device you have is capable of viewing larger than 2000x2000, I hate to say it but it might be time to look for something with more RAM and/or more VRAM. I'm on a Celeron laptop from the windows 8 era, soldered 4GB RAM, but large photos don't seem to be as much a problem for my laptop as my internet connection.
      I personally think it's helpful if someone uploads a large image then chooses a medium thumbnail so we can click on it if we want more detail.
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4889
        • Italy - Milan
        Think about how much costs a web space, for a near zero ads..
        2k x 2k with low compression is a lot of space and a good resolution..
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4889
          • Italy - Milan
          Adding some punctualization, the more the ambient light results in a more sharp and higher level detail picture, practically adds resolution. I learned this in CCTV cameras environment
          • howardc64
            by howardc64
            Problem
            08-04-2024, 10:36 PM
          • m1ch43lzm
            by m1ch43lzm
            Hi everyone
            09-06-2025, 05:47 PM
          • slimmy182
            PlayStation 5 Slim (CFI-2016) – EDM-041 – powers on briefly (blue light), fan spin, video detected, then shuts down
            by slimmy182
            I’m looking for advice on a PlayStation 5 Slim, model CFI-2016, motherboard revision EDM-041.
            Symptoms
            • Console beeps once when pressing power
            • Blue LED turns on for about 1 second
            • Fan spins very briefly
            • Console shuts down immediately
            • No second beep, no error message
            • TV briefly detects an HDMI signal, then nothing . This behavior is 100% consistent on every power attempt.
            Background
            • The console is PS5 Slim, digital model
            • Motherboard has been removed from the chassis for inspection
            • No visible catastrophic damage (no burned components, no cracked silicon)
            • There
            01-19-2026, 03:14 AM
          • Thecio
            Acer Swift 3 OLED SF314-71-74Z2 (N21H3), Huaqin NB2633A_MB_V2, missing ICs, schematic/boardview or reference photos request
            by Thecio
            I am learning board-level repair and have a second-hand Acer Swift 3 OLED that does not power on. I could not find a schematic, pictures or boardview for this Huaqin board, so I would appreciate help identifying several ICs that appear to be (from what little I found) missing.
            Machine
            - Model: Acer Swift 3 OLED SF314-71-74Z2 (also N21H3)
            - S/N: NXKAVEC001227011CC2N00
            - SNID: 227004556223
            - MFG date: 2022/07/15
            - CPU: Intel Core i7-12700H; GPU: integrated Intel Iris Xe
            - RAM: 16 GB LPDDR5, soldered; Storage: 1...
            10-17-2026, 06:22 PM
          • dragometin
            Hitachi 40HYC42
            by dragometin
            TV Model: Hitachi 40HYC42
            Power Supply: 17IPS71
            MainBoard: 17MB95M
            Panel: VES400UNDS-2D-NO3
            When the set came in it was dead. Fuse was open primary side and the power mosfet was shorted. So I ordered a new power supply. Now it turns on, only displays "Hitachi" and then power off red and blue led flashing.
            I had to modify the 0ohm resistors in the led backlight of the new PS like the original power supply.
            Is there any variants on 17IPS71 power supply's?
            UART output pins 10 and 12 on scart connector:
            Code:
            12:24:04.595
            08-08-2024, 05:53 AM
