PSU Main Capacitor replacement tips.
  • naichi2
    • Apr 2015
    • 3
    • Sweden
    I have an Cooler Master m1000 RS A00 ESBA Real power.
    Some caps on the filtering side at the 12v 5v rail has started to bulge (The PSU is over 8 years old) so I am about to change every cap tomorrow. I will go for Panasonic for all (low esr and high ripple res)
    But my two maincaps are 420v 270uf (m) are Nippon Chem-con and can't be found here in my store (Elfa). I was looking into 450v 270uf Panasonic but they cost a lot and are discontinued. Any suggestion what to replace them with ? (those cost around 13 euro each at Elfa in Sweden)
    Best Regards Jonas
    • 30911
    Re: PSU Main Capacitor replacement tips.
    Rubycon and Nichicon are the only other company's making decent high voltage caps.
    Nichi's are cheaper btw, Rubicon cost a fortune for some reason!
    • naichi2
      • Apr 2015
      • 3
      • Sweden
      Thanks for your reply. I will wait with those and just change all other caps since some starts to be in critical condition and order the others next month.
      • chowder
        • Feb 2016
        • 44
        Unless they've tested as bad, the primary caps are probably fine. They rarely fail in PSUs in my experience, certainly nowhere near as often as the ones on the output side. NCC is a good brand too.
        • coreAngel
          • Oct 2014
          • 124
          What about UCC (united chemicon, nippon chemicon ) i have used them and they are good
          Yes i love Nichicon MUSE Audio Capacitors...they would look awesome all over any motherboard
            • 30911
            UCC are good - if you can get them.
            in Europe there arent many suppliers - maybe the u.s. is different.
            • coreAngel
              • Oct 2014
              • 124
              Best Regards Jonas
              Hi i since you are in sweden i found digikey in switzerland i imagine they ship to sweden since it's closer to you
              I found some United Chemicon caps and they are a good price
              I hope this helps
                • 30911
                LOL
                Digikey has a 50 minimum order value or heavy delivery charges in Europe.
                so a lot of us completely avoid them - RS usually has no minimum and Farnell has a minimum of 20
                • Behemot
                  • 4845
                  • CZ
                  You already have Chemi-Cons in the unit as I understand it, why exactly do you want to replace them??
                  • cheeky2
                    by cheeky2
                    05-25-2024, 03:27 AM
                  • Dani_2024
                    by Dani_2024
                    10-28-2024, 05:06 PM
                  • EazyBone
                    75pfl5604/f7 Main board replacement RGB issue
                    by EazyBone
                    Hey y'all, got a 75pfl5604/f7 that was DOA and I diagnosed this to be a main board issue. There was no indicator light, etc etc.
                    Ordered a new one (maybe used) from torres TV parts and installed it. Now the screen cycles the RGB colors only. Hit power and that's only thing that happens. Which is good/bad because it shows the panel/PSU/tcon are running well lol.
                    Anyone know what the deal is and how to get it out of this loop??...
                    12-11-2023, 06:30 PM
                  • iguanar
                    LG G2 OLED - Main board replacement process
                    by iguanar
                    It's my first time posting here, so my apologies in advance if I am breaking any forum rules.
                    Does anyone know how to change the panel info in the service menu for an LG G2 OLED?
                    My G2 83 has had issues powering on since the day I purchased it. LG support sent a technician to my house that replaced the mainboard. This didn't fix the issue and created other problems.
                    After months of back and forth, LG has refunded the TV and I am now wondering if this is something that I could address myself. I have successfully replaced the power board causing the...
                    11-19-2023, 10:20 AM
