75pfl5604/f7 Main board replacement RGB issue
  • EazyBone
    • Jun 2023
    • 1350
    • United states
    Hey y'all, got a 75pfl5604/f7 that was DOA and I diagnosed this to be a main board issue. There was no indicator light, etc etc.
    Ordered a new one (maybe used) from torres TV parts and installed it. Now the screen cycles the RGB colors only. Hit power and that's only thing that happens. Which is good/bad because it shows the panel/PSU/tcon are running well lol.
    Anyone know what the deal is and how to get it out of this loop??
  • Diah
    • Feb 2013
    • 6399
    you may have defect LVDS pin contact.. inspect it under good loop
    • EazyBone
      • Jun 2023
      • 1350
      • United states
      What does under good loop mean. But yes I will check and reseat all ribbons.
      • EazyBone
        • Jun 2023
        • 1350
        • United states
        Interestingly enough this was the solution. For some reason I had to jam the thing in there, I took some needlenose and grabbed the ribbon as tight as I could and use a screwdriver to push in the ribbon and voila it was done.
        Also I'm just kidding lol, but it was not seated fully and did require a little maneuvering, thanks again diah
        • Diah
          • Feb 2013
          • 6399
          well let explain this issue to whom read this threat,,
          in General the Issue of only RGB Pattern displaying on the screen... are 99% the LVDS between MB & T-CON or LVDS between MB & Panel in case tV had no external T-CON... the reason one or more of the Silver contact pins during Sitting get cut or lost connection... those PINs are for V, Signals P+ P- could be... so in this case the T-CON or Panel ( no t-con set ) will have only 12V .. so it will run in test of T-CON / Panel stand alone mode.
          second reason 1% and this less ,issue at the SPI on MB
          thanks for following.
          • Asraf Atb
            by Asraf Atb
            01-27-2025, 05:02 PM
          • tuner2000i
            Philips 65PUS8518/12 distorted image after main board replacement
            by tuner2000i
            hello everyone,
            I don't normally do tv repairs but this is a case with my personal TV which got fried together with many other electronics in my house after a thunderstorm.
            The TV is a Philips 65PUS8518/12 which had no power. I measured and concluded that the main board was probably fried through ethernet or hdmi. I found a board with same number 715GD328-M0F-B00-005Y (I had G) but from a 55PUS8518. The TV starts but the image is doubled, distorted. I need to set the panel code which is 016 according to the sticker on the back but I can not seem to do it.
            07-15-2025, 01:15 PM
          • cheeky2
            by cheeky2
            05-25-2024, 03:27 AM
          • cheeky2
            Sony RB2G Chassis KDL-55W815B MAIN BOARD 2 Blink Error issue resolved! Happy days :)
            by cheeky2
            For anyone interested just repaired this Sony Main board TV that had a 2 blink error code, the chassis is a RB2G which is common to quite a few different Sony models. The Ceramic 10uF 25V X7R 1206 capacitor C9114 was shorted which took the smd 2A 0603 fuse out F9101. This was powering the Buck converter TPS54332 which caused no 5V output from it.
            See the attached picture of the locations of both components. I also attach the best service manual I found for this board for anyone else in a similar position of trying to repair this main board. It's not specific to the TV model however it gives...
            01-08-2024, 05:56 AM
