75pfl5604/f7 Main board replacement RGB issue
  • EazyBone
    • Jun 2023
    • 1362
    • United states
    Hey y'all, got a 75pfl5604/f7 that was DOA and I diagnosed this to be a main board issue. There was no indicator light, etc etc.
    Ordered a new one (maybe used) from torres TV parts and installed it. Now the screen cycles the RGB colors only. Hit power and that's only thing that happens. Which is good/bad because it shows the panel/PSU/tcon are running well lol.
    Anyone know what the deal is and how to get it out of this loop??
  • Diah
    • Feb 2013
    • 6504
    you may have defect LVDS pin contact.. inspect it under good loop
    • EazyBone
      • Jun 2023
      • 1362
      • United states
      What does under good loop mean. But yes I will check and reseat all ribbons.
      • EazyBone
        • Jun 2023
        • 1362
        • United states
        Interestingly enough this was the solution. For some reason I had to jam the thing in there, I took some needlenose and grabbed the ribbon as tight as I could and use a screwdriver to push in the ribbon and voila it was done.
        Also I'm just kidding lol, but it was not seated fully and did require a little maneuvering, thanks again diah
        • Diah
          • Feb 2013
          • 6504
          well let explain this issue to whom read this threat,,
          in General the Issue of only RGB Pattern displaying on the screen... are 99% the LVDS between MB & T-CON or LVDS between MB & Panel in case tV had no external T-CON... the reason one or more of the Silver contact pins during Sitting get cut or lost connection... those PINs are for V, Signals P+ P- could be... so in this case the T-CON or Panel ( no t-con set ) will have only 12V .. so it will run in test of T-CON / Panel stand alone mode.
          second reason 1% and this less ,issue at the SPI on MB
          thanks for following.
          • Asraf Atb
            Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
            by Asraf Atb
            Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
            Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
            I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
            01-27-2025, 05:02 PM
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
          • tuner2000i
            Philips 65PUS8518/12 distorted image after main board replacement
            by tuner2000i
            hello everyone,
            I don't normally do tv repairs but this is a case with my personal TV which got fried together with many other electronics in my house after a thunderstorm.
            The TV is a Philips 65PUS8518/12 which had no power. I measured and concluded that the main board was probably fried through ethernet or hdmi. I found a board with same number 715GD328-M0F-B00-005Y (I had G) but from a 55PUS8518. The TV starts but the image is doubled, distorted. I need to set the panel code which is 016 according to the sticker on the back but I can not seem to do it.
            07-15-2025, 01:15 PM
          • cheeky2
            by cheeky2
            05-25-2024, 03:27 AM
          • mrautom8
            Samsung TV UN75H6350AFXZC main board schematics?
            by mrautom8
            Schematics for the main board needed please. Sticker on board states BN94-07517A but the silkscreen says BN41-02157B. Cant find here or anywhere on the web.
            Backlights work when main boards disconnected. When connected and power button switched, the relay on the PSU board turns on for one second then back off.
            While relay is on, all voltage rails are present and steady (scoped) on main board.
            I love a good logic puzzle but getting lost without any schematics.
            No shorts on ANY capacitor main board.
            Thermal camera shows 3.3V inductor getting warm instantly but...
            10-19-2025, 06:32 PM
