PSU Main Capacitor replacement tips.
  • naichi2
    • Apr 2015
    • Sweden
    I have an Cooler Master m1000 RS A00 ESBA Real power.
    Some caps on the filtering side at the 12v 5v rail has started to bulge (The PSU is over 8 years old) so I am about to change every cap tomorrow. I will go for Panasonic for all (low esr and high ripple res)
    But my two maincaps are 420v 270uf (m) are Nippon Chem-con and can't be found here in my store (Elfa). I was looking into 450v 270uf Panasonic but they cost a lot and are discontinued. Any suggestion what to replace them with ? (those cost around 13 euro each at Elfa in Sweden)
    Best Regards Jonas
    • 31086
    Re: PSU Main Capacitor replacement tips.
    Rubycon and Nichicon are the only other company's making decent high voltage caps.
    Nichi's are cheaper btw, Rubicon cost a fortune for some reason!
    • naichi2
      • Apr 2015
      • Sweden
      Thanks for your reply. I will wait with those and just change all other caps since some starts to be in critical condition and order the others next month.
      • chowder
        • Feb 2016
        • 44
        Unless they've tested as bad, the primary caps are probably fine. They rarely fail in PSUs in my experience, certainly nowhere near as often as the ones on the output side. NCC is a good brand too.
        • coreAngel
          • Oct 2014
          • 124
          What about UCC (united chemicon, nippon chemicon ) i have used them and they are good
          Yes i love Nichicon MUSE Audio Capacitors...they would look awesome all over any motherboard
            • 31086
            UCC are good - if you can get them.
            in Europe there arent many suppliers - maybe the u.s. is different.
            • coreAngel
              • Oct 2014
              • 124
              Best Regards Jonas
              Hi i since you are in sweden i found digikey in switzerland i imagine they ship to sweden since it's closer to you
              I found some United Chemicon caps and they are a good price
              I hope this helps
                • 31086
                LOL
                Digikey has a 50 minimum order value or heavy delivery charges in Europe.
                so a lot of us completely avoid them - RS usually has no minimum and Farnell has a minimum of 20
                • Behemot
                  • 4845
                  • CZ
                  You already have Chemi-Cons in the unit as I understand it, why exactly do you want to replace them??
                  • AJ847.63e
                    LGA 1700 Socket Replacement Tips & Tricks
                    by AJ847.63e
                    Hi All,
                    Just wanted to see if I can get some advice on techniques and equipment I should use to try replace the socket on a Gigabyte H610M h v2ddr4 I have.
                    I was planning on using a heat mat I have that's used for phone, tablet screens, as a base heater than use hot air with a square nozzle on top. Yes I should get a proper preheater but I'm not in the position to go spend 300+ bucks on something I will use every 6 months if I'm lucky. Next expense I need to get is a decent programmer like the RT809H but again it would get used infrequently so hard to justify.
                    07-24-2025, 06:57 PM
                  • tuner2000i
                    Philips 65PUS8518/12 distorted image after main board replacement
                    by tuner2000i
                    hello everyone,
                    I don't normally do tv repairs but this is a case with my personal TV which got fried together with many other electronics in my house after a thunderstorm.
                    The TV is a Philips 65PUS8518/12 which had no power. I measured and concluded that the main board was probably fried through ethernet or hdmi. I found a board with same number 715GD328-M0F-B00-005Y (I had G) but from a 55PUS8518. The TV starts but the image is doubled, distorted. I need to set the panel code which is 016 according to the sticker on the back but I can not seem to do it.
                    07-15-2025, 01:15 PM
                  • cheeky2
                    by cheeky2
                    05-25-2024, 03:27 AM
                  • Dani_2024
                    by Dani_2024
                    10-28-2024, 05:06 PM
                  • EazyBone
                    75pfl5604/f7 Main board replacement RGB issue
                    by EazyBone
                    Hey y'all, got a 75pfl5604/f7 that was DOA and I diagnosed this to be a main board issue. There was no indicator light, etc etc.
                    Ordered a new one (maybe used) from torres TV parts and installed it. Now the screen cycles the RGB colors only. Hit power and that's only thing that happens. Which is good/bad because it shows the panel/PSU/tcon are running well lol.
                    Anyone know what the deal is and how to get it out of this loop??...
                    12-11-2023, 06:30 PM
