The two Lelon brand filter caps in the power supply section of my stereo amplifier have very slightly (and unevenly) - but definitely - rounded tops. I see on this site that Lelon is a known bad brand. This amp is only like 10 years old, and is a typical solid state class B design; for this type of circuit, from what I've read online, this shouldn't typically be expected, so I just wanted to throw this ultra noob question to the experts and see whether I should recap, or if I'm just making up problems. Thanks.
Just a little bulge = bad caps?
Re: Just a little bulge = bad caps?
"but definitely - rounded tops. I see on this site that Lelon is a known bad brand. This amp is only like 10 years old, and is a typical solid state class B design;" Yes, recap, its 10 years old, by the way its Class A/B, Class B will sound real bad.Never stop learning
Pictures would help.Never stop learning
Originally posted by BenMcClure View PostThanks for your replies. The tops are thin black plastic, so I don't know exactly what is going on underneath the plastic. I'll get some photos this evening to show what they look like.Please Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
I pressed on the plastic tops and they didn't give, so I removed them to see what's underneath. As you can (hopefully) see, the metal tops are slightly bulged. I think the schmutz is maybe adhesive to adhere the plastic tops to the metal, but I can't tell...I couldn't see any actual break inthe metal.
They are failed alright :LPlease Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
yup, goners.<--- Badcaps.net Founder
Badcaps.net Services:
Motherboard Repair Services
http://folding.stanford.edu/
Team : 49813
Join in!!
Team Stats
The curiosity is: what made you look into this problem?
Usually amplifiers, to get rid of any noise, do not use switching PSUs and use heavy linear filtering supplies. That's why those caps are huge 0.01F units, but at least they usually are under lower stress.
Not to say they can't fail or are unaffected by the electrolyte problems, but are you getting 60/120 cycle hum in your speakers or something? Or does it sound OK, but you just look at them and appear odd?
eccerr0r:
I started noticing that I was getting light buzzing out of the speakers when the input attenuation pot was turned to about 6 or 7. I searched high and low for the cause, but couldn't find anything in terms of grounding or anything. I'm new to a lot of this, so it wasn't until reading about bad power supply caps that I realized they could even be a source of excessive hum (not to say that's necessarily the cause of my issue).
So long story short I was just kind of digging around and noticed they looked suspect.
Well, the other thing is that most audio/linear amplifiers have a specification to reject power supply noise too, so hum can be attenuated through this as well.
I still kind of find it weird that if the caps really did rupture, why didn't at least one rupture at the vent lines' weakest point - where the two lines meet...
What's the voltage?Less jewellery, more gold into electrotech industry!Half of the computer problems is caused by bad contacts
Exclusive caps, meters and more!Hardware Insights - power supply reviews and more!
There was and is about +/-53v across the capacitors under power. The old Lelon caps I asked about originally were 50v, 85C devices. I replaced them with Vishay/BC Components 63v, 105C units, so I guess even if the old ones were still "OK" by some measure, it's better to have 10-year-newer ones from a better brand with higher ratings.
(I assume it's a better brand; I see Lelon on the bad caps thread but don't see anything about BC in the good or bad brand threads, but the ones I got were the only ones I could find with those specs that would fit in the case).
