Just a little bulge = bad caps?
  • Rob Northen
    • Jan 2010
    • 137
    • Denmark
    Re: Just a little bulge = bad caps?
    Philips/Vishay/BC Components is a GOOD brand
      • 31214
      and pretty expensive too!
      • Behemot
        • 4845
        • CZ
        I've seen BC bad.
        Don't use Vishay unless there is no other option - they bought tens of brands (incl. very crappy manufacturers) over the years, manufacturing quality was not constant even before and now when you have no idea who makes what and where under that corporation, I would not buy anything from Vishay anymore. Never seen 500 % overrated schottky rectifiers dying in massive scale as Vishay ones in HP LP2475 (IIRC) displays. That just does not show quality manufacturer!
        I can get new Nichicon GY 105°C long-life snap-in caps being made in up to 10000 uF/63 V (or 15000 uF/50 V) for I think not bad price a piece, BUT the MOQ is not that nice as was (supposedly) at first (200, now 400 pcs) and still it is BIG money. So if anybody is interested, I can manage group buy with a few ppl, but money first and we have to do at least 100 pcs here.
        • dicky96
          What 'class' is this Hill Audio DX3000 Amplifier?
          by dicky96
          Hi guys, this is general query really
          So I have a Hill DX3000 3KW audio amplifier here.
          It has a topology/design like a class A/B but all the banks of output transistors (10 transistors in each 'side' of the channel) are NPN.
          I was wondering what class this is. It doesn't fit the description of class A.
          It also doesn't match class A/B or B amplifiers as all the examples I see have a complimentary output stage desigs (NPN/PNP) and clearly is not G, H or D
          I looked for 'class A push pull' but that didn't tell me anything either
          05-04-2022, 04:20 AM
        • japlytic
          Certain "Class 2" HDMI cables can be marginal at 4K 60 Hz
          by japlytic
          For some time, a "Class 2" HDMI cable (part number BN39-01583B) supplied with a Samsung 4K 60 Hz display sometimes causes the display to overlay a few horizontal lines of flickering pixels of random colours and sometimes drops out, particularly on content requring HDCP.
          Since changing the cable to a thicker Class 2 unit, this problem has not occured again - do you know of other marginal "Class 2" HDMI cables supplied with displays?
          09-06-2023, 08:50 PM
        • presario425
          RIFA Class Y Capacitor remedy
          by presario425
          Hi all!
          I have a piece of gear with a Power-one SPL130 power supply in it. On the primary side, there is a very tiny (about the size of your thumb nail) RIFA Class Y capacitor, 2.2 nF. I'm not too sure about the condition (whether or not it's cracking) but I do know that it's there.
          I'm aggregating information as to how I should remedy this. It hasn't exploded yet, but that's what I'm trying to avoid.
          I've never seen a RIFA class Y safety cap self destruct (or at least it hasn't been documented in the past). However, it's not worth the risk to leave it in there....
          05-19-2020, 06:53 PM
        • Lee Majors
          Snubber Capacitor Vs Class X2 Capacitor
          by Lee Majors
          Is a snubbing capacitor fine to use in place of an X2 suppression safety? The only real difference I see is that the dV/dt is around 3 times higher than the recommended Class X2. Is this a positive or negative issue in this turntable audio device? See C601...
          10-30-2023, 03:32 AM
          MTFC2GMDEA-0MWT MTFC4GLDEA-0MWT MTFC4GMDEA-1MWT MTFC8GLDEA-1MWT MTFC16GJDEC-2MWT MTFC32GJDED-3MWT MTFC64GJDDN-3MWT Datasheet
          Micron MTFC2GMDEA-0MWT, MTFC4GLDEA-0MWT, MTFC4GMDEA-1MWT, MTFC8GLDEA-1MWT, MTFC16GJDEC-2MWT, MTFC32GJDED-3MWT, MTFC64GJDDN-3MWT are a communication and mass data storage device that includes a Multi Media Card (MMC) interface, a NAND Flash component, and a controller on an advanced 11-signal bus, which is compliant with the MMC system specification. Its low cost, small size, Flash technology independence, and high data throughput make eMMC ideal for embedded applications like set-top boxes, digital cameras/camcorders, digital TVs, and a variety other consumer products.
          The nonvolatile...
          10-07-2024, 04:55 AM
