MTFC2GMDEA-0MWT MTFC4GLDEA-0MWT MTFC4GMDEA-1MWT MTFC8GLDEA-1MWT MTFC16GJDEC-2MWT MTFC32GJDED-3MWT MTFC64GJDDN-3MWT Datasheet
    Micron MTFC2GMDEA-0MWT, MTFC4GLDEA-0MWT, MTFC4GMDEA-1MWT, MTFC8GLDEA-1MWT, MTFC16GJDEC-2MWT, MTFC32GJDED-3MWT, MTFC64GJDDN-3MWT are a communication and mass data storage device that includes a Multi Media Card (MMC) interface, a NAND Flash component, and a controller on an advanced 11-signal bus, which is compliant with the MMC system specification. Its low cost, small size, Flash technology independence, and high data throughput make eMMC ideal for embedded applications like set-top boxes, digital cameras/camcorders, digital TVs, and a variety other consumer products.
    The nonvolatile eMMC draws no power to maintain stored data, delivers high performance across a wide range of operating temperatures, and resists shock and vibration disruption.
    Features
    • Multi Media Card (MMC) controller and NAND Flash
    • 153-ball or 169-ball WFBGA/VFBGA/LFBGA (RoHS 6/6-compliant)
    • VCC: 2.7–3.6V
    • VCCQ (dual voltage): 1.65–1.95V; 2.7–3.6V
    • Temperature ranges
    – Operating temperature: –25˚C to +85˚C
    – Storage temperature: –40˚C to +85˚C
    • Typical current consumption
    – Standby current: 110µA for 2GB, 120µA for 4GB, 8GB, 16GB; 140µA for 32G; 160µA for 64GB
    – Active current (RMS): 70mA (2GB); 80mA (4GB, 8GB, 16GB, 32GB, 64GB)
    MMC-Specific Features
    • JEDEC/MMC standard version 4.41-compliant (JEDEC Standard No. 84-A441) – SPI mode not supported)
    – Advanced 11-signal interface
    – x1, x4, and x8 I/Os, selectable by host
    – MMC mode operation
    – Command classes: class 0 (basic); class 2 (block read); class 4 (block write); class 5 (erase); class 6 (write protection); class 7 (lock card)
    – MMCplus and MMCmobile protocols
    – Temporary write protection
    – 52 MHz clock speed (MAX)
    – Boot operation (high-speed boot)
    – Sleep mode
    – Replay-protected memory block (RPMB)
    – Secure erase and trim
    – Hardware reset signal
    – Multiple partitions with enhanced attribute
    – Permanent and power-on write protection
    – Double data rate (DDR) function
    – High-priority interrupt (HPI)
    – Enhanced reliable write
    – Configurable reliability settings
    – Background operation
    – Fully enhanced configurable
    – Backward-compatible with previous MMC modes
    • ECC and block management implemented​
  • ahmedtou
    HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
    by ahmedtou
    help me please
    I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
    When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
    I will share all the details with you, including the disc information.
    Code:
    HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
    Current Profile: BD-R
    Disc Information:
    Status: Empty
    State of Last Session: Empty
    Erasable: No
    Free Sectors: 12,219,392
    Free Space: 25,025,314,816 bytes
    Free Time: 2715:27:17 (MM:SS:FF)
    Next
    08-27-2025, 08:49 AM
  • madan1
    DALI SUB E-12F class D, fluctuating power rail
    by madan1
    Good day everyone.
    I have on the bench an amp board from DALI SUB E-12F. It is class D amp with a smps on the same board.
    The issue is that it powers off way before the rated power is reached (the protection circuit kicks in). It has an independent standby power supply, which stays on after the main power supply is turned off via a relay on the primary side (thus there is no reason to believe that the protection is triggered from the smps IC on the primary side).
    The normal value of the positive and negative power rails is +/- 43V.
    The positive rail stays...
    10-15-2025, 10:33 AM
  • ChaosLegionnaire
    bug of the month: write caching setting for the hard drive in device manager
    by ChaosLegionnaire
    i recently bought a new wd re4 2tb with 2014 datecodes. when i got around to testing it tho in victoria hd tester, the write speed was very slow at 14 mb/s with a 256 sector transfer size. when i increased the transfer size to 1024 sectors, the write speed increased slightly to 44 mb/s. read speeds and sector verify speeds were fine and at normal speeds.
    so i just ass-u-med the drive's poor performance was due to it being an advanced format drive and i was using it on winxp. when i tried cloning my system disk to this wd re4 2tb drive and writing to it in linux, the write speed...
    10-06-2019, 01:39 PM
    Alcor AU6368 USB 2.0 Flash Memory Card Reader Datasheet
    The AU6368 is an integrated single chip memory card reader controller specially designed for notebook, hand-held and other PC peripheral devices, which require fewer components for small PCB area. It supports a widely used flash memory card such as CF, MD, SMC, xD Picture Card, MS, MS Pro, MS Duo, SD and MMC. It can be used as removable storage disks in enormous data exchange applications between PC and PC or PC and various consumer electronic appliances.
    The AU6368 reads digital content saved on memory card that user captured with the portable device such as notebook, digital camera,...
    10-23-2024, 03:26 AM
  • vbogoev
    Lenovo S6000 won't turn on. Data recovery needed.
    by vbogoev
    Here I have the mentioned tablet with motherboard s6000-mb-h401. The tablet won't turn on, no display, charging normally. I manage to connect to UART port and got this output when I try to start it:
    Code:
    [PWRAP] pwrap_init_preloader
    [PWRAP] pwrap_init
    [PWRAP] _pwrap_init_sidly [Read Test] pass,SIDLY=0 rdata=5AA5
    [PWRAP] _pwrap_init_sidly [Read Test] pass,SIDLY=1 rdata=5AA5
    [PWRAP] _pwrap_init_sidly [Read Test] pass,SIDLY=2 rdata=5AA5
    [PWRAP] _pwrap_init_sidly [Read Test] pass,SIDLY=3 rdata=5AA5
    [PMIC_WRAP]wrap_init pass,the return
    06-20-2023, 06:36 AM
