RIFA Class Y Capacitor remedy
  • presario425
    • May 2020
    Hi all!
    I have a piece of gear with a Power-one SPL130 power supply in it. On the primary side, there is a very tiny (about the size of your thumb nail) RIFA Class Y capacitor, 2.2 nF. I'm not too sure about the condition (whether or not it's cracking) but I do know that it's there.
    I'm aggregating information as to how I should remedy this. It hasn't exploded yet, but that's what I'm trying to avoid.
    I've never seen a RIFA class Y safety cap self destruct (or at least it hasn't been documented in the past). However, it's not worth the risk to leave it in there. It's different from the class X (across-the-line) capacitors in that it's line-to-ground. It's worth noting that the gear in question is encased in a metal chassis.
    I've heard in various videos and forum posts online that in most cases, these caps can just be omitted, but the context always seems to involve a Class X rather than a Class Y cap. If I just remove it for now, and temporarily leave nothing in its place with the understanding that I will be more prone to RFI (which isn't too much of an issue in this application), is that OK for the time being? Class Y caps are designed to fail open, so by removing it and therefore creating an open circuit, it should be fine and not pose a shock hazard, right? If I go this route, I will replace it with a suitable capacitor at a later date.
    Thanks for any input!
  • R_J
    • Jun 2012
    • 9610
    Re: RIFA Class Y Capacitor remedy
    Will this work? WYO222MCMBF0KR
    • presario425
      • May 2020
      That is indeed a suitable replacement - thanks for the recommendation! However, I am unable to replace it at this time (and the lockdown definitely isn't helping that). What I'm wondering is if anyone knows if just desoldering that RIFA class Y will work for now, provided it doesn't pose a hazard of any kind.
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8705
        These are all noise suppressing capacitors and it may introduce interference to radio/tv devices which may cause unwanted behavior.
        The theory is that as a Y-class capacitor it should not fail short, and thus you don't have to worry about it else it's a recall...
        • presario425
          • May 2020
          Sorry about the delayed response, all, been a bit busy as of late. I appreciate all the advice, thanks!
          While it's true that Y caps shouldn't fail short, the same cannot be said about these RIFAs (I believe this one is a PME 271 Y) unfortunately. They tend to fail rather spectacularly due to the casing cracking and letting moisture in over the years. I also learned recently that these caps were not supposed to be yellow originally, they were actually clear. Why there wasn't a recall on these, I'm not sure - I guess these failures happened well after the cap's guaranteed useful life was over. Cheap, nasty plastic casing strikes again
          For now, I will just remove it and not worry about it, and should I experience any RFI problems, I will order a suitable Class Y replacement and install it. There are other Class Y capacitors surrounding it (which are not RIFAs, they are decent quality ceramic disc capacitors and therefore should not explode ) so I don't expect many issues anyway. Again, if I do notice any interference troubles, I will solder in a replacement, but for now I won't worry about it.
          • MORETTIGIAN
            by MORETTIGIAN
            Title:
            Description:
            Procedure performed:
            - Removed backplate
            - Reapplied thermal compound
            - Reassembled card
            09-18-2025, 12:14 PM
          • Lee Majors
            Snubber Capacitor Vs Class X2 Capacitor
            by Lee Majors
            Is a snubbing capacitor fine to use in place of an X2 suppression safety? The only real difference I see is that the dV/dt is around 3 times higher than the recommended Class X2. Is this a positive or negative issue in this turntable audio device? See C601...
            10-30-2023, 03:32 AM
          • Prolog
            by Prolog
            12-01-2024, 08:27 PM
          • Agent24
            Dick Smith Q-1760 linear power supply filter capacitor question
            by Agent24
            I have acquired a used Dick Smith Q-1760 power supply - although the OEM is Manson Industrial
            It has at least one problem.
            The voltage control potentiometer VR2, 50K is faulty - going high resistance / open circuit in the CCW end and leading to the output voltage jumping around.
            I have already ordered a replacement potentiometer, so that's not an issue.
            Now, I want to replace all three electrolytics on the PCB as they are CapXon and I don't trust them so much, I will replace them with something better while I've got the thing apart anyway.
            All are CapXon...
            10-21-2025, 05:39 PM
          • chth96
            by chth96
            12-22-2023, 04:34 AM
