Certain "Class 2" HDMI cables can be marginal at 4K 60 Hz
  • japlytic
    • Oct 2005
    • 2086
    For some time, a "Class 2" HDMI cable (part number BN39-01583B) supplied with a Samsung 4K 60 Hz display sometimes causes the display to overlay a few horizontal lines of flickering pixels of random colours and sometimes drops out, particularly on content requring HDCP.
    Since changing the cable to a thicker Class 2 unit, this problem has not occured again - do you know of other marginal "Class 2" HDMI cables supplied with displays?
  • japlytic
    Certain DisplayPort-HDMI cables can disable HDMI CEC communication
    by japlytic
    With a setup including a TV and AV receiver where HDMI Consumer Electronics Control (CEC) and Audio Return Channel (ARC) functions were working, these two functions stopped working after changing some connections (not the one between the AV receiver and TV), so I believed it was a corrupt setting in the AV receiver or TV, but when I disconnected a passive DisplayPort-HDMI cable (which a Multimode DisplayPort connector supports HDMI with a low cost passive cable or adaptor) connected to a home theatre PC, HDMI CEC and ARC functionality was restored.
    An examination of the HDMI CEC wiring...
    07-10-2022, 09:48 PM
  • aliougm
    Marantz SR4003 AVR HDMI board issue, seeking for help
    by aliougm
    I have problem with my AVR(Marantz SR4003) HDMI board issue. I connect to my TV but screen color distorted,see attached picture.
    Connection as below:
    Set-top box HDMI output >AVR 3 HDMI input/one HDMI output>HDTV HDMI port
    If I bypassed AVR then HDTV screen color be good.
    I take out HDMI board from AVR and check services manual the schematic shown the HDMI signals path:
    3 HDMI input port > SIL9185 chip(HDMI switch) > SIL9033 chip(HDMI receiver) > SIL9030 chip(HDMI transmitter) > HDMI output port
    I replaced all...
    04-30-2022, 12:21 PM
  • RossMoodley1967
    LG LCD TV HDMI PORT FAULTY
    by RossMoodley1967
    LG LCD TV picture comes on intermittenly using hdmi port.The sound is on permantly.The hdmi ports looks fine and soldered in securely.The 3.4v coming to the main board is not present(not sure if will affect the hdmi port or where that voltage goes.)The hdmi cable is fine because it works on another tv.The ceramic caps connected to the hdmi controller ic is reading 39 ohms.Could the hdmi controller ic be faulty(feels very warm to touch).The RCA jacks work normally .Thank you in advance for your assistance..
    02-28-2024, 08:38 AM
  • budwich
    ESD Diode on HDMI output of Yamaha a1050 RCVR
    by budwich
    I lost one of the two hdmi outputs on a yamaha rx-a1050 receiver. Of course, it is the hdmi1 which has the arc capability which was useful. The second output hdmi works OK.
    I got an hdmi breakout board which gave me access to the "little guys" in the hdmi. I did some gross DC voltage measurements to ground and found that the Data1 pair (4 and 6) had a lower voltage than the working hdmi.... 1.1v versus 2.9. All others pins seem to be OK. Further when plugged into a display, there is no video but a message on the screen which I assume is the display's status for the...
    09-11-2023, 12:21 PM
  • Wittie
    Philips 55OLED803/12 HDMI ports "half" defective
    by Wittie
    Hello everyone, Please excuse my poor English, but I'm using Google Translate ^^ I'm having a problem with the HDMI and USB ports on my 55OLED803/12. It's no longer possible to connect an HDMI device and see the picture. No matter which port I use, it only recognizes the device as an input source and displays it in the list (BD player, Fire TV, etc.). However, the actual picture doesn't appear in the same state. My home theater system also runs via the BD player - it still receives a signal and plays the sound correctly (e.g., from the TV program or an app like Netflix). This works with both HDMI...
    03-19-2025, 09:38 AM
