Peace capacitors
Re: Peace capacitors
Hmmm. For 50c each with free shipping, it might be worth buying a few. They'll make great firecrackers.I love putting bad caps and flat batteries in fire and watching them explode!!
Office PC: HP ProLiant ML150 G3, 2x Xeon E5335 2GHz, 4GB DDR2 RAM, 120GB Intel 530 SSD, 2x 250GB HDD, 2x 450GB 15K SAS HDD in RAID 1, 1x 2TB HDD, nVidia 8400GS, Delta DPS-650BB 650W PSU, Windows 7 ProComment
Peace of sh*& is all I can say. My old durabrand $10 cd player was full of them and one bulged after 6 months. Then the thing worked great other than the volume couldn't be turned down but if the musics too loud your too old!Comment
I saw a couple of these in an Emerson boombox along with a ton of weird and unknown Chinese cap brands like FU-YU, OIC, WS, and Rulycon. Surprisingly, the caps weren't the reason why it stopped working. Two had low capacitance, but they were running at their maximum rated voltage.
Edit: After looking at the picture in the first post, I noticed that a couple might be leaking around the leads. I've never seen such large caps with such cheap bungs.Last edited by lti; 05-24-2011, 11:02 AM.Comment
...but dude, if you're around when they 'splode they make you feel gewd
lol, why don't they just order some Rulycom heatshrink tubing?
Anything to save some pennies, I suppose. Those bungs do look sad, too. Iti, I take it Emerson boombox not worth a recap?If you voted for Obama in 2008 to prove you weren't a racist, you'd better vote for someone else in 2012 to prove you're not an idiot!Comment
It wasn't worth it. I replaced two filter caps and a bad voltage regulator and left the rest alone. I would have been the only person to hear a difference if the audio caps were bad, and it isn't my boombox.
Also, the first letter of my username is an L.Comment
I've see these before, they weren't bloated but I didn't trust them. I don't think they're for pc componentsCap Datasheet Depot: http://www.paullinebarger.net/DS/
^If you have datasheets not listed PM meComment
This brand along w/ 2 450v Capxon caps are all over the power supply for my Dynex 55in lcd tv. Replacing them all w/ Nichicon caps from Mouser. The tv would turn itself off by itself which got worse as time passed. Great forum btw! You all saved me $$$Comment
Reminds me of these counterfeit Samsing capacitors I once saw in a record player a rip off of Samsung they went very bad almost immideatley after a few months of use and made the speed of the player ripple so much you could hear the difference I still have the player with these Counterfeit caps I will post an image of them.Comment
by dragon3xHi, I have some 32 bits computer motherboards that need repair, as they fail to
power on.
Here are some examples :
switching supply area).
than 6.3 V.)
3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA... -
by slybundahey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
it has inside:
2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
2 x 470uf 16v LZ105c branded as G.Luxon
not heard of these brands are they any good?
iv attached photos of the charger and the board inside for an idea on the type of...-
by sam_sam_samI did not have any 27uf @ 50 volt capacitors but one nice thing is that it has enough room for two capacitors in parallel a 22uf and a 4.7uf @ 50 volts 22 plus 4.7 equals 26.7uf which so very close to 27uf I will show some pictures of it sometime tomorrow
After all of... -
by Ady2017I have a 2007-era Panasonic VHS combo that is full of of Elna RJG capacitors. I am trying to test the capacitors to diagnose the machine and then select replacement capacitors but I can not find any datasheets for them. I did find a Elna catalogue from 2007-2008 but there is no mention of this capacitor series. Where these specially made for Panasonic and so not made available to the public? Any ideas what to find out what the ESR values should be without the datasheets? They are all between 10V and 50V and 47uF and 1800uF. None are leaking or bulged but I know that they need to be tested to be...
by ctroxtellI picked up a 70" Samsung UN70TU7000WXZA. The original owner said they were watching it when the power surged and knocked it out. I pulled the back off the TV and disconnected the main board from the power board, and the LED backlight came on, which I was told meant the power board was good. When everything is plugged in the standby light will not come on, looking at the main board BN94-17775A with a thermal imaging gun I can see one of the chips labeled 3202 is 251 degrees F just sitting idle. I found a replacement board, BN94-16115X; this board has the same symptoms, except it is a different...
- Loading...
