Sony xbr65x900c sound yes, no backlight or image.
    • 12207
    • U.S.
    Re: Sony xbr65x900c sound yes, no backlight or image.
    Nothing labeled fs that I can see on top of board, there's some labeled fb, should I rip it out and check bottom of board, that's where I have the tiny resistors reading short.
      • 12207
      • U.S.
      I'll rip the board back out and report all shorts.
      • Diah
        • Feb 2013
        • 6376
        yes Fb. my typo. i dont thnk you have short.. its much open circuit at primary because the main fuse didnt blow up since yours Main filter caps blowing out. i think R.J are good at this part to follow. hope he join and help you
          • 12207
          • U.S.
          Looks like about 6 tiny resistors are reading short, one near D950A, D950A reads good. There's 5 tiny resistors around D901 and IC901 reading short, the labels on the resistors that I was able to read were 3R3, 3R6, 4R4Z as far as my eyes can tell, don't have 20/20 vision any more, thanks.
            • 12207
            • U.S.
            Ok, checking fb, thanks.
            • Diah
              • Feb 2013
              • 6376
              3R3, 3R6, 4R4Z are fuseable R low Ohm. they are not short.
                • 12207
                • U.S.
                #27
                All fb on top of board show continuity.
                  • 12207
                  • U.S.
                  #28
                  Oh, ok, thanks.
                    • 12207
                    • U.S.
                    #29
                    Dam that's a relief, I couldn't change those out, too tiny.
                    • Diah
                      • Feb 2013
                      • 6376
                      free the legs of the MOFSET under the heatsink. then test .. it could be one are open.
                        • 12207
                        • U.S.
                        #31
                        Can you see the label on that mosfet, the number, is it Qxx something?
                          • 12207
                          • U.S.
                          #32
                          Oh crap, did you mean all of them? big job.
                          • Diah
                            • Feb 2013
                            • 6376
                            start with the 2 close to the IC and main filter cap place.. by the way which value of filter cap you bridge to the boards?
                              • 12207
                              • U.S.
                              #34
                              two of the 450 v, 220uf.
                              • Diah
                                • Feb 2013
                                • 6376
                                the original was 2x110 uf, it mean 1 x220uf enough
                                  • 12207
                                  • U.S.
                                  #36
                                  dam those mosfets are in deep, can I just clip a leg and check or do I need all the legs out of circuit? if so does it matter which single leg I clip? thanks.
                                    • 12207
                                    • U.S.
                                    #37
                                    Wasn't sure if I needed to put 2 caps back in so I replaced the 2 570v 110uf with the 2 450 220uf, you think that's messing things up?
                                    • Diah
                                      • Feb 2013
                                      • 6376
                                      yes 100%
                                        • 12207
                                        • U.S.
                                        #39
                                        Should I take one out, if so can I just test with the one still in and nothing in the other spot? thats what I wasnt sure about, thanks.
                                        • Diah
                                          • Feb 2013
                                          • 6376
                                          the 2 original caps are connected together at - and + so the value of 2x 110uf = 220uf. so 1x220uf will be enough, take one out and leave the other on correct position of - & +
