Can you dignose from the photo ? . Toshiba 65S2650EV
  • Ancient1
    • Dec 2019
    • 275
    • Israel
    #241
    Re: Can you dignose from the photo ? . Toshiba 65S2650EV
    From what I search , BZX84... variants is Y5 , SOT-23 .
    What minimum wattage ?
    I think Mouser , DigiKey would be a good place to search for candidates ?
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4458
      • Italy - Milan
      #242
      yes in the previous post i told you from my searches BZX84-A16, in the truth by its datasheet of the series the true one in BZx84-C16 tha has same Vz but more tolerance, 250mW, but for a fast test you can avoid filling the place, so we see if the damn thing wants to show us a picture after 240 posts..
      • Ancient1
        • Dec 2019
        • 275
        • Israel
        #243
        So 17-19V, and 250mW preferably. doesn't have to be 3 pin. Now length issue .. 2mm max
        I am thinking what is the best way. The list is only 3 pin SMDs , but with the specs .. oy vei (thats yiddish)
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4458
          • Italy - Milan
          #244
          no 15-17v. Why don't you test the board itself? I'm impatient.. thrust the uncle, it's safe if you do a 1 minute test..
          • Ancient1
            • Dec 2019
            • 275
            • Israel
            #245
            Found a candidate J3 - see photo
            its data sheet https://cdn.badcaps-static.com/pdfs/...4ac533c6dd.pdf
            looks like an 18V Zener
            and 1P - see photo
            Both from a good board. I don't want to this PSU too , So if you confirm, I want to make sure I can buy those 2 in Aliexpress. But delivery time isn't a factor
            I'll use low melt solder to remove them. safer
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4458
              • Italy - Milan
              #246
              i said 15-17v (it has a range) 18v it's too high, why you show me photo? it doesn't matter..
              • Ancient1
                • Dec 2019
                • 275
                • Israel
                #247
                I try to make as if my uncle is looking over my shoulder
                What about H5 : Nominal 15 ( 14.25 - 15.75) , Power dissipation 500mW https://html.alldatasheet.net/html-m...MMSZ5245B.html
                • Ancient1
                  • Dec 2019
                  • 275
                  • Israel
                  #248
                  For now : I replaced the SMD .. not only the output is still missing, but IC2 IC3 are missing Vcc it seems. Main Caps have 308V.
                  I verified that the tracks with the job today are fine.
                  I will check later what happened and inform.
                  unbelievable
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4458
                    • Italy - Milan
                    #249
                    but replaced Smd with what?? H5 is good..
                    • Ancient1
                      • Dec 2019
                      • 275
                      • Israel
                      #250
                      H5 and 1P , taken from a good PSU.
                      Now I need to go back to the measurements I did earlier and see where the V is missing in the path. I assume IC3 , with many pins , is the start ?
                      I am considering putting back the old 1P and Y5 , maybe I damaged the new ? who %!*&# knows. I'll probably buy new 1P and H5 for the donor board.
                      Nested repair : you need to fix A in order to fix B in order to fix C. Thank God for the wonderful experience.
                      And... I got now an LG 47" to deal with. Easy Backlight issue (Menu is seen), hopefully.
                      • Ancient1
                        • Dec 2019
                        • 275
                        • Israel
                        #251
                        This post is outside the subject of this thread
                        No joy with the LG 47" 47LN570Y. Hoping for a quick repair and to get back to the 65".
                        On start : BL blips. Image OK. BL Strips OK. i.e LED Driver issue. All PSU Caps look OK.
                        2 Quick questions :
                        first : With no BL connected , should there be output V on the PSU BL connector ? ( something I finally realized I need to clarify )
                        2nd : I got PSU of 42LN570Y , it is smaller. Main's connector identical EAX64905(3)501 ( 42 has 3 not 5) : I upload photo of the important info with them. Do you think it can be used instead? ( I will repair the board of the 47" later)
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4458
                          • Italy - Milan
                          #252
                          PLEASE! i ask this on the knees to all members, don't misk repair cases.. open one thread for each repair job, there are gigantic threads full of confusion in this forum...
                          Obviously not ic3, check again the previous list of components i made..
                          • Ancient1
                            • Dec 2019
                            • 275
                            • Israel
                            #253
                            I'm sorry. I hoped for a quick yes/no. I don't want the misuse your kindful help.
                            * Can't delete . I'll start another thread
                            • Ancient1
                              • Dec 2019
                              • 275
                              • Israel
                              #254
                              OK. I have a plan.
                              I need to have Vcc on ICs as before the last operation - replacing the 2 SMDs
                              I will restore the 2 old SMDs . measure Vcc to IC2 IC3.
                              No Vcc : Go back in the posts to Re-do the things we did before , like shorting the Opto
                              • Davi.p
                                Hobbist Tech
                                • Sep 2009
                                • 4458
                                • Italy - Milan
                                #255
                                after remounting them remove ic2 and test pin8 ic2 pad on pcb..
                                • Ancient1
                                  • Dec 2019
                                  • 275
                                  • Israel
                                  #256
                                  OK , in order to remove a bad IC2 from influence.
                                  I really am greatful for your exceptional commitment in this long thread
                                  • Ancient1
                                    • Dec 2019
                                    • 275
                                    • Israel
                                    #257
                                    OK.
                                    I replaced the new SMDs H5 and 1P , with the originals
                                    IC2 Voltage ... a joke , fluctuating up to ~3V
                                    I was about to give up and go and order new PSU because I owe it to you.
                                    Decided to continue and remove IC2
                                    16.46V . I wonder if I have this IC in my junk , is there manufacturer to stay away from ? found 2Pcs ~$3 , estimated 07.Mar .
                                    I continued to replace right button in my Roccat Kone [+] . new Omikron F clicker ( forgot the name).
                                    Some positive things today.
                                    • lotas
                                      • Jan 2016
                                      • 4749
                                      • Russia
                                      #258
                                      IC2 immediately had to be changed, the resistor R37 burned out for a reason.
                                      • Davi.p
                                        Hobbist Tech
                                        • Sep 2009
                                        • 4458
                                        • Italy - Milan
                                        #259
                                        Yep... i don't remember, when you was measuring the 5vsby output after the 431 change it was low with the ps jumper or also without? Only a curiosity..
                                        • Ancient1
                                          • Dec 2019
                                          • 275
                                          • Israel
                                          #260
                                          lotas : correct.. in hindsight
                                          Davi.p : you remember details better than me... probably ... 431 ?
                                          I'll jumpstart tomorrow the PSU I took the SMDs from, see if it is fine or I need to order them too
                                            09-06-2024, 05:33 AM
                                            Toshiba Portege R30-C Notebook Specification for Upgrade or Repair
                                            This specification for the Toshiba Portege R30-C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the R30-C boardview and R30-C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba Portege...
                                            09-06-2024, 05:30 AM
                                            Toshiba Satellite Z30t-A-10C Notebook Specification for Upgrade or Repair
                                            This specification for the Toshiba Satellite Z30t-A-10C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Z30t-A-10C boardview and Z30t-A-10C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                            09-06-2024, 05:27 AM
                                            Toshiba Satellite L50D-B-11V Notebook Specification for Upgrade or Repair
                                            This specification for the Toshiba Satellite L50D-B-11V Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the L50D-B-11V boardview and L50D-B-11V schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          • nikokin
                                            NEED help with clear ME image for toshiba A40-G fuz2sy1 a4607a
                                            by nikokin
                                            So i have 2 laptops, both had no image, all voltages are present except for igpu that comes after intel xe drivers installation i flash bios, one of 2 worked but had slow boot, that probably has something to do with management engine, also boot guard is active level 4
                                            on all bios i tried, i attach both original bios, and also the one i flash and worked with slow boot
                                            can someone clean any of them so i can try them
                                            thank you
                                            i tried to do it myself but none of them works
                                            if anyone knows, when i clean the image do i leave bootgaurd on level 4 or put it on level 0...
                                            01-30-2025, 03:02 AM
