NEED help with clear ME image for toshiba A40-G fuz2sy1 a4607a
  • nikokin
    • Mar 2013
    • 20
    • greece
    So i have 2 laptops, both had no image, all voltages are present except for igpu that comes after intel xe drivers installation i flash bios, one of 2 worked but had slow boot, that probably has something to do with management engine, also boot guard is active level 4
    on all bios i tried, i attach both original bios, and also the one i flash and worked with slow boot
    can someone clean any of them so i can try them
    thank you
    i tried to do it myself but none of them works
    if anyone knows, when i clean the image do i leave bootgaurd on level 4 or put it on level 0
    it also says that intel ppt is disabled
    and also all images have the same bootguad hex key, is that correct?
    [URL]https://li*******************************
    • 22293
    RULES UPDATE for BIOS requests/offers AVOID BANNING, READ BEFORE POSTING
    You MUST NOT:
    • Hijack threads unrelated to your request
    • Post a request in multiple threads
    • Post a request multiple times
    • Post in foreign (non-English) languages
    • Share private contact information
    • Offer payment of any kind whatsoever
    • Bump your thread or post more than once every 48 hours. If you do so
      you will receive an infraction
    • Post "clean me", "clear bios", "clean bios", "bios need", "clear me" or other such terms
    You MUST:
    • Read BIOS guides, methods, resources and tools
    • Try the method at BIOS guides, methods, resources and tools before requesting help
    • Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
    • Use search function in case someone already answered your request
    • Post under a related thread if it exists
    • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
    • Name your thread with model numbers and request
    • Provide a BIOS/EC dump if possible
    • Attach files directly to your post instead of linking to external websites
    • Post what the problem is, be specific, - black screen, no boot, running slow, password.Do NOT post "clean me", "clear bios", "clean bios", "bios need" or other such terms
    • Avinitlarge
      Toshiba Tecra A40-G-138 (FUZ2SY1 A4607A) schematic request
      by Avinitlarge
      I am after a schematic for a Toshiba Tecra A40-G-138 (FUZ2SY1 A4607A)
      can anyone help me out please
      thanks
      12-16-2024, 02:55 AM
    • Avinitlarge
      Toshiba Tecra A40-G-138 (FUZ2SY1 A4607A) not charging
      by Avinitlarge
      Does anyone have a schematic for a Toshiba Tecra A40-G-138 (FUZ2SY1 A4607A motherboard)?
      It's not charging through USB C, the mosfet was dead, I've replaced it but still not working. The charger is putting 20v out and the laptop is showing it's charging so it's partially working.
      The original mosfet was a AON7422G, I’ve replaced it with a AON7430 which is a similar spec
      12-15-2024, 11:53 AM
    • Jaime Morillo
      Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
      by Jaime Morillo
      Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
      The TV was stuck on the logo and I couldn't access the update menu.
      I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
      The image result was good, but the image is inverted.
      The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
      Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
      08-18-2025, 11:38 AM
    • vv7
      a2251 820-01949 need clear image of board
      by vv7
      A2251 board no 820-01949 need clear image of board as I have board with missing components with water damage stuck on 5v I cleaned and replaced missing components with same value around CD3217(U3100_R) and UB260 now it switched to 20v and stuck on apple logo no bar also power button not working restored in DFU but no luck I have some doubt that I soldered some no stuff components also so if I get a clear image of board it may help me particularly this part...
      04-24-2022, 06:15 AM
      HP ProBook 430 G6 + Image Load, Asset Tag & Testntag Notebook 400 Specification for Upgrade or Repair
      This specification for the HP ProBook 430 G6 + Image Load, Asset Tag & Testntag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G6 + Image Load, Asset Tag & Testntag boardview and 430 G6 + Image Load, Asset Tag & Testntag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
      09-06-2024, 10:56 AM
