Can you dignose from the photo ? . Toshiba 65S2650EV
  • vinceroger69
    • Mar 2012
    • 6714
    • uk
    #121
    Re: Can you dignose from the photo ? . Toshiba 65S2650EV
    I have just read the whole thread again i think realistically without you wasting more money you have done all you can with this set, i hate lcd panel issues at this point i will usually strip the tv and sell all the boards etc etc and make some cash back im only a hobbiest though plus i would never sell a tv on with a known lcd panel issue but thats just me.
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4462
      • Italy - Milan
      #122
      i was asking to Ancient1 if is an hobbyist, i would sell a tv like this anyway if it works well without a cof, but with a less price..
      • Ancient1
        • 275
        • Israel
        #123
        I am a hobbiest. I'm pretty good at diagnosing TVs but less so with electronics.
        I can buy on Aliexpress a new PSU for 28+10 ..
        I would love to know if taking the COF out actually works. For now, I need to recover from that nasty ZAP that burnt a hole , with the shape of this wire resistor in the blanket.
        I might just bridge the fuse and solder the R44 wire. I doubt it will work but its an easy job, which I don't think will cause any damage since I can't believe nothing else was damaged.
        I'll upload and update here.
        • vinceroger69
          • Mar 2012
          • 6714
          • uk
          #124
          you can use a light bulb instead of a fuse (google dim bulb tester) maybe check the obvious on the psu like the bridge rectifier etc before trying the psu.
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4462
            • Italy - Milan
            #125
            Stop please, without offend but replacing fuse with a wire is one activity of the most scarce technician, if i guess well that strange resistor is a replacement for the current sense resistor for mosfet sensing, and i guess it'not even original, some one have already mal-serviced this tv, never seen this object in a tv... must use a non flammable carbon resistor... i think that you have a failed main mosfet and the previous technician is a comedian..
            • vinceroger69
              • Mar 2012
              • 6714
              • uk
              #126
              can you link the ali express psu
              • budwich
                • Jul 2015
                • 3097
                you might try totally disconnecting the power supply from the boards (and backlights), then plug in and check things at the PSU. Then potentially, try some work around for the "wire fuse" and do the checks again. Then if nothing seems bad there in, you can then jumper the psu to fake it into turning on, still with nothing connected and do your checks again. At this point, you should see voltages as labelled at the power supply. Go from the results there after.
                • Ancient1
                  • 275
                  • Israel
                  #128
                  Thanks for the response guys :
                  The PSU model is LYP02832A0 .
                  Aliexpress #item 1005001870771741 : Confirmed Identical. I just clicked in Google search results to get an idea.
                  I know a Fuse is a protection device. I was talking about that very thin, found in watches, copper wire that I doubt can handle 1A i.e The replacement Fuse should not allow any damaging power surge.
                  I have spare fuses, didn't check if same.
                  Davi.P : the R44 resistor is Original. All I want is to see if RIPPING THE TAB was successful , 3 seconds are enough.
                  Troubleshooting the PSU : Outside the TV :
                  Temporary: Fix Fuse, Fix R44.
                  Check Main Cap for 310V or higher.
                  No ? - Check Bridge. Check Mosfets ( under HeatSink) , Diodes etc
                  Yes ? - Check V further on Hot Side .
                  Standby V present ?
                  Yes : Auto-Start PSU by connecting StBy Pin and PSU-ON Pin on the Main-Side Braid Connector and Check for High V ( 24V, 12V )
                  No ? : go back and find the fault.
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    • uk
                    #129
                    Standby V present ?
                    Just looked at that ali express picture so r44 is like that from factory
                    • Ancient1
                      • 275
                      • Israel
                      #130
                      R44 measured ~0.5 Ohm
                      • Ancient1
                        • 275
                        • Israel
                        #131
                        Soldered and tested powering up , at the Apt.'s relevant Fuse ( for safety ) . blew up .
                        Soldered back R44 - undamaged
                        Must be a short there
                        • Ancient1
                          • 275
                          • Israel
                          #132
                          Update : Shorted Bridge
                          Big Problem : No markings whatsoever ! working on it
                          • lotas
                            • Jan 2016
                            • 4753
                            • Russia
                            #133
                            Bet any on 600-800V, 6-8A (KBJ608G).
                            • Davi.p
                              Hobbist Tech
                              • Sep 2009
                              • 4462
                              • Italy - Milan
                              #134
                              take one of the same size
                              • Ancient1
                                • 275
                                • Israel
                                #135
                                I actually managed to see the marking using the thermal paste trick. Markings were VERY, VERY faint !
                                Damaged KBJ1006 : 10A 600V
                                Found and installed KBJ68G : 6A 600V .
                                I think it'll be fine for the short test wish to make. Especially since my current sense is a wire I soldered back.
                                I'll do a safe Power Connect ( using the Apt Fuse )
                                Auto-Start and check High V , hopefully its good now
                                Put back and try the TV
                                • Davi.p
                                  Hobbist Tech
                                  • Sep 2009
                                  • 4462
                                  • Italy - Milan
                                  #136
                                  Something doesn't comes back to me, how much is your line? if is 240vac then 340vdc x 10A = 3,4kW, this has no sense.. maybe them are 2,5Ax4 so 850W, which is the power consumption of the set?... which is the thermal paste trick? Check the NTC resistance at cold..
                                  • Ancient1
                                    • 275
                                    • Israel
                                    #137
                                    The Thermistor measures 4.5 Ohm , in circuit.
                                    Specifications say 2.5 Ohm at 25C. I think at 14C thats fine ?
                                    I have 220V at the Wall. I don't understand the calculations, 10A or 6A are MAX
                                    The Thermal Paste trick is to lightly spread the basic, white, thermal paste over the chip, and rub it OFF slowly with your finger/s : there will be more white left in the markings than the surface, so its clearer to read
                                    After the Fuse didn't blow, I connected Pins PS and 5VSB :
                                    I assumed this will autostart the PSU , BUT :
                                    I did measure 5V , But 12V was 1.2V only. 24V also N/A
                                    Do I miss something ? PS<->5VSB Pins should Auto-Start, Right ?
                                    I am considering putting the PSU board back in the TV, perhaps the system works other than what I thought ?
                                    • Davi.p
                                      Hobbist Tech
                                      • Sep 2009
                                      • 4462
                                      • Italy - Milan
                                      #138
                                      That PS nomenclature is not clear, usually there's a PS-ON, but probably the pfc section is not working... check diodes and mosfets on the dismounted heatsink. NTC is good.. the calculation= 310vdc rectified ac, 6A so 310x6=1860W max consumption, it's not realistic, 310x10 even more, so if bridge is 1,5Ax4 then 310x1,5=465w, how much is the tv? Also, if NTC max I is 6A then also the bridge ok the same.. after this i don't know which is the effect of the empty cap at the start.. but the initial peak must return in the Non rip. peak of 170A..
                                      • Ancient1
                                        • 275
                                        • Israel
                                        #139
                                        The TV is 140W
                                        I admit I don't understand your calculations.
                                        The new Bridge KBJ068G is "weaker" than the original KBJ1006 : 6A vs 10A
                                        I didn't see any short on the Mosfets etc under the heatsink.
                                        I have another 2 under aluminium heatsink: 11N60E Power Mosfets. I will check now.
                                        I will try the TV with the board tomorrow morning ( I don't want blowen fuses after dark , now)
                                        • Davi.p
                                          Hobbist Tech
                                          • Sep 2009
                                          • 4462
                                          • Italy - Milan
                                          #140
                                          I don't want to run the risk of following the same old board repair that ends in a board replacement, since the spare board is ultra cheap i suggest you to buy a new one, i know you're a bulldog but you already spent much time..
                                            Toshiba Portege Z30-C Notebook Specification for Upgrade or Repair
                                            This specification for the Toshiba Portege Z30-C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Z30-C boardview and Z30-C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba Portege...
                                            09-06-2024, 05:33 AM
                                            Toshiba Portege R30-C Notebook Specification for Upgrade or Repair
                                            This specification for the Toshiba Portege R30-C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the R30-C boardview and R30-C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba Portege...
                                            09-06-2024, 05:30 AM
                                            Toshiba Satellite Z30t-A-10C Notebook Specification for Upgrade or Repair
                                            This specification for the Toshiba Satellite Z30t-A-10C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Z30t-A-10C boardview and Z30t-A-10C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                            09-06-2024, 05:27 AM
                                            Toshiba Satellite L50D-B-11V Notebook Specification for Upgrade or Repair
                                            This specification for the Toshiba Satellite L50D-B-11V Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the L50D-B-11V boardview and L50D-B-11V schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          • nikokin
                                            NEED help with clear ME image for toshiba A40-G fuz2sy1 a4607a
                                            by nikokin
                                            So i have 2 laptops, both had no image, all voltages are present except for igpu that comes after intel xe drivers installation i flash bios, one of 2 worked but had slow boot, that probably has something to do with management engine, also boot guard is active level 4
                                            on all bios i tried, i attach both original bios, and also the one i flash and worked with slow boot
                                            can someone clean any of them so i can try them
                                            thank you
                                            i tried to do it myself but none of them works
                                            if anyone knows, when i clean the image do i leave bootgaurd on level 4 or put it on level 0...
                                            01-30-2025, 03:02 AM
