LG 55UK6950PLB backlight but no picture
  • notallbad
    • Oct 2012
    • 1190
    On power up the backlight comes on but no picture
    Power on - 3.4v
    13.2v - 13.2v
    Drv_on - 3.25v
    V-Sync - 0.04v
    SIN - 0.02v
    SClk - 0.01v
    P-dim - 1.4v
    P-dim2 - 1.3v
    With the left tcon ribbon removed just backlight still on fulscreen, no change.
    With the right tcon ribbon removed that half of the screen is considerably darker.
    Any advise please.
    thanks
  • notallbad
    • Oct 2012
    • 1190
    Re: LG 55UK6950PLB backlight but no picture
    in stby the 13.2v line is jumping around between 8.2v and 8.6v
    Also dont seem to be able to get any sound.
    • chopdre
      • Jul 2012
      • 8
      • barbados
      seems like a panel issue, you need to block the ckv lines on the faulty side of screen
      • William1967
        • Nov 2017
        • 203
        • Netherlands
        The panel has a problem, it's a common fault with these models and several other models from LG. The AVDD must be around 17v and is only present on one side when you disconnect one of the LVDS cables.
        • notallbad
          • Oct 2012
          • 1190
          thanks william
          shall check that out
          is it a fault within the actual panel or the boards attached to the panel? fixable or just scrap?
          thanks
          • notallbad
            • Oct 2012
            • 1190
            Both ribbon cables connected theres no volts on AVDD, left or right.
            With the right ribbon cable disconnected the AVDD on the left is 17v.
            With the left ribbon cable disconnected theres 0v on AVDD on the right.
            There is 17v on both ribbon cables when disconnected.
            • William1967
              • Nov 2017
              • 203
              • Netherlands
              I have 4 over here with the same problem, I only had a little time to investigate where it comes from and until now I have to say it's inside the panel...
              • notallbad
                • Oct 2012
                • 1190
                ok may as well strip it down and trash the screen then.
                Anything you want me to check or do before its scrapped? Might help with your investigations later.
                • William1967
                  • Nov 2017
                  • 203
                  • Netherlands
                  I've gone a little further with one of the displays and by cutting some lines there was picture, unfortunately there were black flashing lines on the left side of the display.
                  On the second display I could not get any picture at all. I'm not going to open both other tv's, they will go back to the owners. In one word said these tv's are garbage!
                  • dskall
                    • Oct 2016
                    • 2905
                    • usa
                    You can run down the short if you are interested. Maybe able to bypass shorted area and go directly to COF with wire.
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4318
                      • Italy - Milan
                      The fault may be within the display distribution boards, maybe a shorted cap, needs slow current supplying on avdd line especially, to be safe 1,8/3,3v supply lines must be present.
                      • notallbad
                        • Oct 2012
                        • 1190
                        Found the fault! Burnt out on one of the tab bonds.
                        Not a very good photo, sorry but you get the idea.
                        So this ones toast! Shall strip down for parts.
                        Thanks for the help! Appreciate it!!!
                        • dskall
                          • Oct 2016
                          • 2905
                          • usa
                          Thanks for follow up.
                          • Monty74
                            • Feb 2022
                            Hi notallbad, did you have to trash the screen to get to the burnt out tab bond? I have one of these screens and wanted to attempt a repair as I too have backlight but no picture. Is this a ribbon cable of some kind that has burnt out? I cant really see as the picture is not so clear as mentioned. I just want to know if its repairable on a micro soldering scale? Regards Craig
                              • 12145
                              • U.S.
                              simple things first, try unplugging wifi and speakers, turn tv on see if there's any change.
                              • viewerau
                                • May 2020
                                • 305
                                How is this process done please?
                                Signature:Seemingly hopeless tv fixer
                                  • 12145
                                  • U.S.
                                  tape cutoff method, video there and many more, youtube: https://www.youtube.com/watch?v=pfrRhw7-ZII
                                  • viewerau
                                    • May 2020
                                    • 305
                                    Thank you...
                                    This is my t-con
                                    I see CLK 1-8 on the top right of my t-con, but unlike his board, which shows the lines going to the ribbon area, in mine, I see no lines like his were.
                                    So how do I know which one's to tape?
                                    Thank you.
                                    • lotas
                                      • Jan 2016
                                      • 4589
                                      • Russia
                                      Originally posted by viewerau
                                      thank you...
                                      This is my t-con
                                      i see clk 1-8 on the top right of my t-con, but unlike his board, which shows the lines going to the ribbon area, in mine, i see no lines like his were.
                                      So how do i know which one's to tape?
                                      Thank you.
                                      ckv
                                      • viewerau
                                        • May 2020
                                        • 305
                                        Hi lotas.
                                        I am sorry, I do not understand your reply...my apology.
                                        • Tr0ll
                                          by Tr0ll
                                          Original T-con:
                                          First replacement T-con:
                                          10-07-2023, 07:48 PM
                                        • triplefour
                                          by triplefour
                                          09-13-2023, 10:43 PM
                                        • Mgiffune
                                          by Mgiffune
                                          06-09-2024, 10:28 AM
                                        • Ierwin
                                          by Ierwin
                                          05-13-2025, 03:31 PM
                                        • groomit
                                          Philips 50PUS7363/12 Backlight but no picture
                                          by groomit
                                          I'm having trouble with above mentioned TV. Bought it defect.
                                          Picture was heavily compressed around the horizontal axis. Fiddeled and tried different things (mask clock lines, swap T-Con). But no difference.
                                          Then I identified a heating capacitor on the left hand Signal-PCB (?) below the display. Replaced it by hand soldering. Checked for shorts afterwards. But now the screen stays black.
                                          I can see backlight, but screen stays black.
                                          What I've tried:
                                          - Disconnect right side cable from T-Con -> same (backlight but no pic)
                                          - Disconnect left side...
                                          11-22-2024, 02:43 PM
