Samsung ue49mu6120
This topic is closed.
  • lotas
    • Jan 2016
    • 4598
    • Russia
    #481
    Originally posted by alex39t
    You said that dump i have is good?
    Yes.
    • alex39t
      • Nov 2013
      • 50
      • greece
      #482
      When i push button 1 time to 10 turn on it has the logo and after only backlight
      • lotas
        • Jan 2016
        • 4598
        • Russia
        #483
        Try this clean dump, but the problem may be in something else, maybe in the T-con firmware (25Q80), damaged Hdmi, usb ports, panel...
        • dodo-dk
          • Apr 2024
          • BW
          #484
          Hello Lotas and all.
          I have read here much and this community is very nice. Much to learn.
          But I no longer make any progress and hope of your help.
          I have a UE55KU6170UXZG Curved TV. I have changed the Mainboard BN41-02528A (with a UE55KU6179UXZG) and the PowerSupply but problem exists.
          With the UE55KU6170UXZG M/B:
          The Standby LED goes on and off, stays off for 30 seconds and repeat. No Backlight.
          With the UE55KU6179UXZG M/B:
          The Standby LED is steady on, no Backlight. If I press ON the Power LED goes off and then on, and stays on.
          If I remove the cable between PSU and Mainboard Backlight is on.
          I have jumpered the FB_TRDY 1/3 and removed one LVDS Cable, and than the other but no change.
          Is there a Software Problem?
          I uploaded you the Files from UE55KU6170UXZG and UE55KU6179UXZG, I hope you can look and find something.
          • fanaticgames
            • May 2017
            • 138
            • italy
            #485
            I have this UE55MU6125K TV, it doesn't turn on and doesn't show any red LED (the power board works though and powers the panel and backlight correctly), is it a corrupt eeprom problem?
            • lotas
              • Jan 2016
              • 4598
              • Russia
              #486
              90% of the standby indicator does not light up in the "MU" series; the problem is in the spi flash 25Q40 firmware.
              • fanaticgames
                • May 2017
                • 138
                • italy
                #487
                I don't know how to check and fix it, can you check? That's the dump, thanks
                • lotas
                  • Jan 2016
                  • 4598
                  • Russia
                  #488
                  Dump was, as always, it will damage, I fixed it, try it, don’t forget about the status register...
                  • fanaticgames
                    • May 2017
                    • 138
                    • italy
                    #489
                    Perfect, works
                    • lotas
                      • Jan 2016
                      • 4598
                      • Russia
                      #490
                      Perfect, works
                      Ok!
                      • Salvocchio
                        • Mar 2024
                        • 12
                        • Cagliari
                        #491
                        Hi Lotas
                        I just can't seem to solve the problem.
                        I try to write register 1 to 88 and register 2 to 42.
                        When I click on write everything seems okay.
                        Then I click on read and register 2 reads it to me at 4A.
                        How can I solve it? It doesn't seem to store the second register at 42.​
                        • lotas
                          • Jan 2016
                          • 4598
                          • Russia
                          #492
                          1. First you need to delete all status registers (uncheck all the boxes and click "Write")
                          2. Erase the chip.
                          3. Write down the corrected dump and check what was written down.
                          4. Set the status register (0x88, 0x42), check the boxes and click "Write"
                          5. Everything is ready, solder the chip in place....​
                          • errico68
                            • Oct 2023
                            • Italia
                            #493
                            good evening I have the same problem with the same TV. I attach the dump file. can you help me?
                            • lotas
                              • Jan 2016
                              • 4598
                              • Russia
                              #494
                              This is the wrong dump, the dump you need is not 25Q80, but (IC1604) 25Q40!
                              • maverikdj
                                • Aug 2018
                                • 12
                                • Italy
                                #495
                                Originally posted by Shwed84
                                Re: Samsung ue49mu6120
                                I have the same problem with my
                                SAMSUNG UE40MU6470UXRU .Can you help me ?
                                Thank you
                                MB: BN41-02568B
                                LCD: CY-KK040HGNV3V
                                the number on the sticker: BN94-11958K
                                can you help me with dump of 25q80 for panel LCD: CY-KK040HGNV3V ? thanks a lot
                                • errico68
                                  • Oct 2023
                                  • Italia
                                  #496
                                  buonasera
                                  • lotas
                                    • Jan 2016
                                    • 4598
                                    • Russia
                                    #497
                                    buonasera
                                    Try.
                                    • Martin_CZ
                                      • Jan 2021
                                      • 9
                                      • Czech
                                      #498
                                      please modily firmware. Samsung UE49MU6170. Many thanks. Martin
                                      • lotas
                                        • Jan 2016
                                        • 4598
                                        • Russia
                                        #499
                                        Try.
                                        • Martin_CZ
                                          • Jan 2021
                                          • 9
                                          • Czech
                                          #500
                                          Try.
                                          working. Thank You
                                            09-07-2024, 05:50 AM
                                            09-06-2024, 11:40 PM
                                            09-06-2024, 08:40 PM
                                            Samsung Galaxy Book Ion NP930XCJ-K01DE Notebook Specification for Upgrade or Repair
                                            This specification for the Samsung Galaxy Book Ion NP930XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP930XCJ-K01DE boardview and NP930XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-06-2024, 06:20 PM
