samsung ue55nu7021k backlights working but blank screen
  • Chrissygizmo
    • Mar 2021
    • 108
    • United Kingdom
    I have a Samsung ue55nu7021k that has working backlights but has a dark blank screen..
    I've tried a couple of different boards from a friend without success, however, one of the boards produced the Samsung Smart logo on the screen so I'm guessing it's the main board that's at fault, is there anything I could try to repair the board or is it a case of buying a new one ?
    Thanks in advance
  • brucetv
    • May 2015
    • 281
    • united states
    Re: samsung ue55nu7021k backlights working but blank screen
    If you got the Samsung logo to come up does it go any farther after that or just freeze at the logo?
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4318
      • Italy - Milan
      Are you female? Do you hear sound? if you hear maybe there's a fault in the tcon section of your mainboard , but i don't know if you are familiar with electronic inspections..
      • Yoda79
        • Dec 2021
        • 56
        • United Kingdom
        Hi, wondering if anyone can help. I have the same model TV, Samsung UE55NU7021KXXXU. The TV was running fine but then all of a sudden started encountering problems. The sound would work, the remote wouldn't work! Now the TV turns on, although very slow boot up now but when it does it comes with the Samsung Logo then onto a screen showing No Signal. I try pressing Source on the remote but nothing happens. The home button also doesn't work, so I can not get any of the smart apps up. Also, everything is running very slowly.
        However, if I click the actual button at the bottom of the screen and bring up the menu, then I get goto source and manage to select one of the HDMI's and get a signal. However while the picture shows, i keep getting the turning circle (as per the attached photo of the BBC news - you can just see the turning circle in the middle of the screen) and it says it's adjusting the picture. Also there is no sound. Under the settings, the picture test shows fine but sound test fails to work. I should add that this is temperamental as well as sometimes also does not work (the button at bottom of screen)
        Any ideas on how to fix? I've added some photos of the screen and model to help.
        Also, some times when I boot, instead of the normal commands, I get coding on the titles (as per photo)
        • dskall
          • Oct 2016
          • 2905
          • usa
          Sounds like maybe a firmware problem. Does temperature affect problem?
          • vinceroger69
            • Mar 2012
            • 6714
            maybe a faulty nand ic/firmware
            • Yoda79
              • Dec 2021
              • 56
              • United Kingdom
              Hi, thanks for your replies.
              So I don't believe temperature affects it as starting to go wrong in the same room its been in for the past 2 years!
              I try and do an update to the firmware but it just crashes and doesn't do anything and reverts back to the same screen.
              Sorry what do you mean by a faulty nand IC?
              hank you for your help. Its only like 2.5 years old!
              • Yoda79
                • Dec 2021
                • 56
                • United Kingdom
                Sorry but is there a way that you can get an email when someone replies?
                • vinceroger69
                  • Mar 2012
                  • 6714
                  Nand ic or eeprom ic is the chip that stores the firmware etc on samsungs quite common they go faulty.
                  Have you got a good clear picture of the mainboard so that we can see all the numbers on it.
                  • lotas
                    • Jan 2016
                    • 4585
                    • Russia
                    The memory may be full, you can try to do a "factory reset" through the service menu.
                    • vinceroger69
                      • Mar 2012
                      • 6714
                      lotas what type of memory ics do these use nand or eeprom ive not worked on one of these sets yet
                      • lotas
                        • Jan 2016
                        • 4585
                        • Russia
                        EMMc flash has been used in new models for a long time.
                        This model also has SPI Flash and EEPROM, but the software is in EMMc.
                        • vinceroger69
                          • Mar 2012
                          • 6714
                          Thankyou
                          • Yoda79
                            • Dec 2021
                            • 56
                            • United Kingdom
                            I know there was a memory issue with this tv as I could never install any more apps, did see some posts about this too. Bizarre as surely you would put a TV out there with sufficient memory on it!On the factory rest is the the "reset" under support/self diagnosis as per photo?
                            Thank you for your help and time!
                            • Yoda79
                              • Dec 2021
                              • 56
                              • United Kingdom
                              I have opened it yet but let me give this a go tonight and I'll get a clear picture. I'm guessing the mainboard will be the large board at back and not the one where the power goes to?
                              • Yoda79
                                • Dec 2021
                                • 56
                                • United Kingdom
                                Sorry I got lost there but assume opening up the back and exposing the motherboard will provide clarity on whats faulty and needs to be replaced?
                                • Yoda79
                                  • Dec 2021
                                  • 56
                                  • United Kingdom
                                  So I've just tried another software update which is what I assume is a firmware update. I choose as per the photo and then it does something but returns to the main "No Signal" screen again. Checking the software version it's still what it was before.
                                  Also, some options don't seem to be available. Picture attached of some itmes greyed out!
                                  • vinceroger69
                                    • Mar 2012
                                    • 6714
                                    what is in the general menu?
                                    • lotas
                                      • Jan 2016
                                      • 4585
                                      • Russia
                                      If you reset via the "factory reset" service menu, you will get the TV as if it were from a store.
                                      https://www.wikihow.com/Reset-a-Samsung-TV
                                      Method 5
                                      • Yoda79
                                        • Dec 2021
                                        • 56
                                        • United Kingdom
                                        Hi, so just started the tv again and the no signal page is not showing properly. Photo of this attached as well as a photo from before when this page was showing properly. I've also attached a photo of the main settings menu which too isn't showing properly. I'll later to see if it displays correctly.
                                        I'm guessing this doesn't help much?
                                        • dicky96
                                          HP Elitebook Screen blank - backlights but no image
                                          by dicky96
                                          Hi guys
                                          I'm trying to fix this laptop screen
                                          Basically the owner is a computer shop and they brought it to me with two screens. They said the repair shop they use could not fix it, so I thought i would try to see if I am better than their current repairer!
                                          OK so I have the original screen which works but has lines across the bottom quarter of the screen
                                          I have the replacement screen, which they fitted and it worked. They then put the laptop on one side for a couple of weeks until they found a buyer. When they showed it to the buyer, the screen would...
                                          04-28-2021, 07:30 AM
                                        • mrtek
                                          Samsung UN65js8500F, no sound, blank screen and T-Con board with one LED on
                                          by mrtek
                                          Hi I am new to this kind of repairs but I want to learn..I have a Samsung UN65JS8500F. the TV used to work and I tried to fix darker areas in the middle only ( img 1,2,3). I thought the led strip were bad..not the case. I did not research in advance what kind and where the LED were located. In this model they are located vertically on right and left side. Took the TV apart and put it back together. Now the tv shows no welcome screen and no sound is available thru the speakers. ..just a black screen..Backlight LED do turn on...also noticed a 5 blink code , not sure if that was there before. I can...
                                          11-26-2024, 09:58 AM
                                        • Bloopeta
                                          Samsung UE55JU6800K No Picture
                                          by Bloopeta
                                          Samsung UE55JU6800K with no image on screen.
                                          I have had this TV many years without fault, however aprox 6 months ago I fitted a new set of backlights as some of the lens caps had fallen off.
                                          Was working fine, until 3 days ago, when watching TV the screen just went blank (still illuminated)
                                          I turned the TV off and left it around 12 hours, and when turned it on again it seemed to work perfectly again. After around 45 mins the screen went blank again.
                                          Left it off overnight and turned it on, and the Smart TV logo came on as normal, then screen went blank.
                                          05-03-2024, 10:42 AM
                                        • bohaboha
                                          Samsung UE70TU6905 BACKLIGHTS AND SOUND ON NO PICTURES BUT SCREEN NOT DARK
                                          by bohaboha
                                          Hi it looks like everything works don't know where to test except the 390v in the 2 capacitor in the hot side of the power supply and the weird 180v in the diodes in the cold side that should be discharged it is writin on the circuit no more you can read what is written on the circuit quite srrange color mixiing yellow and white
                                          anyhow i couldn't t read anything else
                                          the backlight is on strong and the screen does not get dark or very dark but no pictures
                                          the mainborad feels a bit hott on the black part i test it to 52 degree's against 34 to 40 on the rest of it
                                          01-02-2025, 08:04 PM
                                        • madverkus
                                          Samsung UE50KU6072U - Backlights working, black screen
                                          by madverkus
                                          Hey guys
                                          I got this TV from my friend and he said that one day he was trying to power it on it was just dead.
                                          I did open the back of the TV and check the boards and cable connections and everything seems ok (no popped caps or anything visible).
                                          I tried to turn it on few times and when I plug it in it flashes "Smart TV" logo and goes dark for about 20 seconds (no backlight yet) and after that the backlights are lit but no picture and didn't give any startup sound, sometimes it didn't start up but did show the standby led only and every time I pushed power...
                                          12-23-2021, 09:49 PM
