JVC-32C675 Backlights on but blank screen
  • 4thommo
    • Nov 2014
    • 8
    • united kingdom
    Hi all,i have this problem and so far I have visually checked the main board and flashed the main board with the files in the first picture. The flash seemed to go ok,first the front red LED flashed quickly and then slowed up before the TV turned itself off and on but it is still the same. I see there are exact matching main boards available but I don't want to commit to that incase it's something else. Any help would be greatly appreciated.
    PSU 17IPS62
    MB 17MB110P
    Panel VES315WNDS-2D-N14
  • nomoresonys
    • 12331
    • U.S.
    Can you post good straight on focused pictures of each whole board and one of the whole back as to see how everything is connected.
    • 4thommo
      • Nov 2014
      • 8
      • united kingdom
      Thanks for replying, hopefully these are good enough
      • nomoresonys
        • 12331
        • U.S.
        Ok, I thought it was a vestel from the description in first post, to me it seems like a mainboard issue but honestly I very seldom even see vestel tvs here. Best to let the vestel guys help, wish I knew more about them.
        • yokoono
          • Apr 2010
          • 515
          You rewrote software for another type of screen and you no longer have an image. You have an HD panel and I think you wrote software for FHD. I have software for what is on the TV but it is for a different TV model. You try at your own risk. If the remote control no longer works, you can use a programmable one. There are 2 software in the archive. If the OK key on the remote control is no longer active, you cannot rewrite the software.​
          https://files.fm/u/xeejn9df6c
          • 4thommo
            • Nov 2014
            • 8
            • united kingdom
            Ok no problem, thanks for getting back to me 👍🏻
            • 4thommo
              • Nov 2014
              • 8
              • united kingdom
              Hi,thanks for getting back to me.
              I have never had an image on this TV since it was given to me,just the backlights on and a blank screen.
              Thanks for those files,I have tried them both on different USB drives but the TV just acts as if I'm turning it on.
              I went back to the file that I flashed originally to make sure the ok button was still working,the front led flashes fast then slower without the backlights on,it seems like it's taking the firmware but there is nothing on the screen.
              I guess it may not be a firmware issue and could be an issue with the board, maybe.
              • Chrissygizmo
                Panasonic TX-48CX350B backlights but white screen , blank screen
                by Chrissygizmo
                Hi all, I’ve got a problem I hope someone can help me fixi.
                I have a Panasonic TX-48CX350B tv , it powers up ok but the screen is blank, the backlights are working, there’s nothing else though, no picture or sound. I’m not sure what the fault is called whether it’s BLANK/ BLACK/ or WHITE SCREEN I’ve actually came across this before on a similar tv but just ended up scrapping it, I will upload pictures of the boards etc , if anyone could help me I would really appreciate it...
                01-11-2025, 03:18 PM
              • mecha1166
                KDL-60EX500. Comes on fine, sound is fine, backlights come on. Blank screen.
                by mecha1166
                KDL-60EX500. Comes on fine, sound is fine, backlights come on. Blank screen. Already tried reset POWER/VOL-. Anyone else have this problem? Possibly bad T-Con RUNTK4244ZZ or panel? Could main or power supply cause this? There were 2 blown 560u 35v on power going to backlights but they were still working fine. Thanks for your help.
                11-25-2024, 05:22 PM
              • dicky96
                HP Elitebook Screen blank - backlights but no image
                by dicky96
                Hi guys
                I'm trying to fix this laptop screen
                Basically the owner is a computer shop and they brought it to me with two screens. They said the repair shop they use could not fix it, so I thought i would try to see if I am better than their current repairer!
                OK so I have the original screen which works but has lines across the bottom quarter of the screen
                I have the replacement screen, which they fitted and it worked. They then put the laptop on one side for a couple of weeks until they found a buyer. When they showed it to the buyer, the screen would...
                04-28-2021, 07:30 AM
              • Ryan.man
                by Ryan.man
                02-04-2025, 12:23 PM
              • kotel studios
                Funai 32FL553P/10 - squealing from PSU, dies after 10 seconds, blank screen after logo, bootloops
                by kotel studios
                Found an Funai 32FL553P/10 TV on sale for cheap listed as broken, so I decided to give a shot at reparing this.
                State I got it in:
                Squealing from the PSU
                After logo I get a blank screen
                After 10 seconds of having a blank display w/ backlight the TV dies
                Give it 7-10ish seconds again and it starts to bootloop.
                What I did so far:
                Replaced all the caps on the PSU (apart from primaries, they were fine and none at hand)
                Checked all voltage rails:
                5VSB - 4.8V
                AMP+13V - 14.4V
                13V - 12.98V (in manual 12V)...
                09-21-2025, 02:00 AM
