Samsung UN43NU6900FXZA 43" 4K - Power Supply Issue
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16956
    This was given to me the other day.... All I was told is the power light blinks. It's a 43" Samsung 4K from ~2018. Geez, this one didn't live long...
    I plugged it in, and as they said, power/standby LED blinking....but not by the firmware/control. The blinking is caused by a PSU not starting up.... I can hear the PSU 'chirp' in unison with the blinking light. There's no voltages present except the pulsing/intermittent standby. I've checked all the usual suspects, can't seem to find anything bad (caps, diodes, etc). The PSU still does this with everything unplugged.....eliminates LED strips, LVDS, and the panel itself. I tested the LED strips with my tester, they lit up nice & pretty....so its down to this one & only board in the set. This board has already pissed me off.....it's lucky it hasn't been smashed with a hammer. Even after discharging the mains cap, it bit me twice....so it apparently doesn't have discharge circuitry!!
    Whatever is wrong with this is apparently a common problem, these boards are nowhere to be found....but I never found any detailed information as to what the actual fault might be.....any of you experts have some input?
    Here's the high res of the top & bottom views of the board:
    https://www.badcaps.net/forum/attach...1&d=1619719005
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
  • Diah
    • Feb 2013
    • 6363
    Re: Samsung UN43NU6900FXZA 43" 4K - Power Supply Issue
    its all in one boards.. i think the blinking are error..
    take out the heat sink and show here focused photo of this part
    BTW: what are yours LED tester voltage reading ?
    • Topcat
      The Boss Stooge
      • Oct 2003
      • 16956
      It's not an error code, it's a pulsing PSU. There's no voltages present anywhere long enough for it to boot.
      LED tester is 140v @ ~100mA, all beads are lighting.
      Under the big sink:
      https://www.badcaps.net/forum/attach...1&d=1619722041
      The switching transistor under the small sink:
      The text on the chip:
      'magna chip'
      6DR360QS
      KE3040DGP
      Team : 49813
      Join in!!
      Team Stats
      • Diah
        • Feb 2013
        • 6363
        did you try measure the spi flash close to the crystal clock i think if it had 3.3V on pin 1?
        of course all cable should be in place
        • Topcat
          The Boss Stooge
          • Oct 2003
          • 16956
          It fluctuates with the pulsing; 0 to 3.3, rinse repeat every second. On a digital meter, it's hard to see...but on my analog, the needle dances nicely from zero to 3.3 every second.
          Team : 49813
          Join in!!
          Team Stats
          • Diah
            • Feb 2013
            • 6363
            ok. so we do have output volts.
            can you check as you have 2 groups of diodes after the transformer ( at cold side ) 2 big diodes and other with 4 diodes.. need to know which one belong to LED feed. so you can terminated the other one which will be main supply feed to the mainboards.. theory the LED sockets will have volts reading or they could lit on in case they are fine.
              Is that standby 3.3V?
              It looks like the power supply is in shutdown/restarting due to overload, I.E. short circuit.
              The board only has one power transformer that is always running, if you looks at the Cathode sies of those two barrel diodes on the cold of the board (with the board has nothing connected to it except the AC cord). Does the Voltage on the Cathode of the diodes fluctuate?
              • Topcat
                The Boss Stooge
                • Oct 2003
                • 16956
                All diodes check good.
                For grins, I removed the cathode end of the two diodes outlined. This stopped the blinking stby LED. There was also no zero~3.3v fluctuation on the SPI flash (pin1) IC; it was zero volts.
                I also tested the LED+ TP, and from chassis ground it had ~360v present with the diodes attached and not attached.
                From LED- to LED+, there were zero volts present. This was the same whether the backlight LED strips were connected or disconnected. I could still hear the 'chirp' no matter if the diodes were disconnected or connected, but it was far quieter (barely noticeable).
                Team : 49813
                Join in!!
                Team Stats
                • Diah
                  • Feb 2013
                  • 6363
                  did you take the screen apart to tell all beads lighting? in case yes or no 100mA to 140V not good reading.. tester will never tell you if the LED unit zener shorted even its lighting on.
                  U series as i know used Concave Lens over LEDs so the distances between LEDs will increase resulting the amount of LED unit at one strip will reduced..
                    Those two diodes are the main DC output power supply.
                    The other 4 smaller diodes are for the backlights power supply.
                    • Topcat
                      The Boss Stooge
                      • Oct 2003
                      • 16956
                      If you're referring to the ones outlined above (DM851C and DM852C), the cathode has a steady +14v, chassis ground as reference; nothing connected except the AC cord. +3.3v still fluctuates from 0 to 3.3; chassis ground as reference.
                      Yes Diah, all beads lit....I did check.
                      Team : 49813
                      Join in!!
                      Team Stats
                      • Diah
                        • Feb 2013
                        • 6363
                        test each LED of its zener diode if in tact. with meter diode mode
                          That power supply is not going into cycle then, 14V is an always on output of this power supply, it is then fed to switched MOSFETs to provide various switched power supply and regulators.
                          • Topcat
                            The Boss Stooge
                            • Oct 2003
                            • 16956
                            ...but with the fluctuating stby 3.3v, logical deductions would tell me it's not bad strips, as it does this with or without them connected.....inspite of the steady +14v?
                            It does this with nothing but line connected....Even if the backlights are dead shorted (They're not), standby should not be fluctuating like this.
                            Team : 49813
                            Join in!!
                            Team Stats
                              That is correct, otherwise the LED power supply Voltage would be fluctuating too since it comes from the same power supply transformer, the main key right now is that the 14V and the high Voltage for the LED are stable with no LED connected but the 3.3V is fluctuating.
                              Can you check the resistance between circuit ground and the 3.3V test point?
                              Can you zoom in to that red dot of the diode that you marked?
                              Also that white connector next to that diode, what is connected to that plug?
                              • Diah
                                • Feb 2013
                                • 6363
                                as all of you know every transformer had layout out of coils in side. some had at secondary coils as feed back to primary ( called in circuit protection ) unfortunately no one looking after the transformer coils direction which its key to know how it work when there are only ONE transformer between HOT & COLD and how to build the protection circuit.
                                • R_J
                                  • 9535
                                  It could be a bad electrolytic in the primary side for the standby vcc, this vcc voltage usually supplies the pfc ic and the main power supply ic (if used)
                                  The two small elec. caps across from your white clips are what I would check/replace or it could be the one near the bottom of the board (CM813), next to the right of the main filter
                                  • Topcat
                                    The Boss Stooge
                                    • Oct 2003
                                    • 16956
                                    It's reading ~37k
                                    That connects to the backlight LED's.
                                    All of those capacitors were spot-on.
                                    Team : 49813
                                    Join in!!
                                    Team Stats
                                      OK, that is Boost converter section (you can see the black inductor and the SMD MOSFET).
                                      Where is the 3.3V test point?
                                      • Topcat
                                        The Boss Stooge
                                        • Oct 2003
                                        • 16956
                                        Pin 1 of IC503 next to the crystal, as per Diah's advice.
                                        Team : 49813
                                        Join in!!
                                        Team Stats
                                        • Cookybaby
                                          Samsung UN60ES6500FXZA Power Supply Issue
                                          by Cookybaby
                                          Hello Everyone, this is my first post and I am excited to be a part of such a great community. I've been reading these forums for awhile and there really is some good friendly people here. No bashing and being rude like 90% of other forums Ive been to. Lets get to the good stuff.
                                          I have two years of college in Electronics Engineering Technology. Ive been tinkering with electronics sine about 1990. I know enough just to be dangerous, so be gentle.
                                          Make: Samsung
                                          Model: UN60ES6500FXZA
                                          Power Supply P/N: BN44-00525A
                                          Symptoms: The TV was...
                                          08-20-2023, 12:26 PM
                                        • lp20th
                                          Samsung Plasma TV Power Supply Issue
                                          by lp20th
                                          I have a vintage 2008 Samsung 50” Plasma TV, Model code PN50A550S1FXZA with a power supply part number BN44-00222A. I repaired the power supply board several years ago finding a couple of cold solder joints on the back side of the board and it's worked great up until now. Recently a fried sound occurred with the smell of burnt electronics and the TV shut down. Trying to turn it back on yielded the typical relay clicking with no TV boot up. Upon investigation, removing feeds to the other boards within the TV it was found that disconnecting the logic board from the power supply allowed the...
                                          11-28-2023, 10:28 AM
                                        • captainKKK
                                          Samsung Bn4400612b Power Supply issue on Samsung UN50F6300
                                          by captainKKK
                                          Samsung Bn4400612b Power Supply issue takes out a new 5A fuse on my Samsung UN50F6300, without any the BL or main board cables connected. Please advise if this board has known issues and fixes. There are no evident fried components and the caps look ok. Nothing unusal on the bottom side of the board under magnification. Is the ICM801CS under that heat sink a known issue? SJ (https://www.shopjimmy.com/samsung-bn...-1473373576096) out of stock, so component level repair may be my best shot. Thanks.
                                          02-17-2022, 08:59 PM
                                          09-07-2024, 05:50 AM
                                        • cheeky2
                                          Samsung BN44-00262A H37F1-9SS power supply help finding blown value components!
                                          by cheeky2
                                          This Samsung combined power supply and inverter was replaced a while ago from a Samsung 37inch LE37B530P7W TV. However I would like to repair this one.
                                          I have replaced the Mosfets Q1820 and Q1821 ( FDPF7N50U) which were both blown and the fuse FM802S. The schematic for this power supply that is attached doesn't relate to this power supply as the driving transistors and diodes are D1830, D1831, D1832, D1833, Q1811 & Q1810 are nowhere on the schematic!
                                          Does anyone know what the components for D1830, D1831, D1832, D1833, Q1811 & Q1810 should be? I ask as I did change the Mosfets...
                                          06-15-2025, 05:12 AM
