Sharp LC60C6400U - 2 long binks, 5 short blinks error code
  • R_J
    • Jun 2012
    • 9581
    Re: Sharp LC60C6400U - 2 long binks, 5 short blinks error code
    Originally posted by Noobwithamultimeter
    Yes pin 4 on KIA378R12PI is still 13.19V
    Bad news for you and me - that's how I've been discharging both main caps every time I remove the main board. Across the leads one at a time with a screwdriver until I see sparks.
    Not bad news for me, it's your tv. in most case the caps will discharge on there own after a couple minutes, Just don't touch that circuit if you are doing tests on other parts of the board. and don't lay the board across the metal of the tv . When you short the caps with a screwdriver, the large current and the large spike created can at a minimum blow the pfc drive ic.
    It is best to check the voltage across the main caps and see what the voltage is when it is disconnected. You should use an appropriate resistor to discharge the caps.
    • Noobwithamultimeter
      • Apr 2021
      • 94
      Oh.
        • Apr 2021
        • 94
        I think the maximum voltage for my multimeter is 300V.
          What kind of meter do you have? Pictures of it?
          • RJARRRPCGP
            • Jul 2004
            • 6304
            Originally posted by R_J
            People don't want longer lasting TV's they want CHEAP! That's all I heard when 42" plasma's were $9,000, "I'll wait till the price comes down before I buy one" Well you get what you wish for.
            TV's should be like the auto industry, You could by a really good car for $5,000, now they are 50,000
            A 60" lcd tv should be the same, price should be $20,000 that way they could use better components.
            That kind of pricing encourages scalpers, including scalping econo-boxes! No thank you!
            ASRock B550 PG Velocita
            Ryzen 9 "Vermeer" 5900X
            Arc A770 16 GB
            eVGA Supernova G3 750W
            Alienware AW3423DWF OLED
              • Apr 2021
              • 94
              Here is my multimeter. Maybe it can handle it, I am a noob remember. I'm leaning towards powerboard failure, just need to figure out the components that need replacing. If the ICs on the flex cables fail is it always obvious? I inspected them all and they look very clean or new without and melting or burning on them. Also LED strip is 100% clean looking (now I know when they die sometimes they look the same) but I saw a youtube video of a couple burned ones on a strip out of a similar 60" Sharp where one looked black and another brown. Also I know that an LED strip problem has it's own blink code.
                Get a new meter so you find out if the PFC Voltage booster is working or not.
                  • Apr 2021
                  • 94
                  Are those the two 450V caps you refer to?
                    Yes, if PFC Voltage is working then you should have about 380 ~ 400VDC (when TV is turned on) when measure between the Positive leg and the Negative leg of the caps.
                      • Apr 2021
                      • 94
                      I see.
                        • Apr 2021
                        • 94
                        If pin 1 on PL connector on the t-con board reads 3.5V does that mean it's bad? Should it always be 12V when the tv powers on?
                        • Diah
                          • Feb 2013
                          • 6424
                          the story written at post #1 make me remember an issue at CRT from philips , when the one regulator got defect after replace it it work for short time then get defect again... electronic shops start to sell repair kits to all component related to this regulator to replace at once then it done for ever.. yours story very close to this.. dont trust test parts with meter... find the value of them and replace all.
                          • nomoresonys
                            • 12229
                            • U.S.
                            #73
                            Just carefully measure the voltage of the big caps as mentioned, with tv powered on, don't touch them with anything but the meter leads because it is DEADLY VOLTAGE. If you're not comfortable doing it, you certainly don't have to.
                              • Apr 2021
                              • 94
                              Yeah that's too scary for me, plus my meter only goes to 300V. I don't want to buy another multimeter. Looks like I'm stuck at a dead end for now. The only thing it may very well be is the flex tabs, but removing them from one side would be a foolish 50/50 gamble especially when I see no signs of damage on any of the ICs. Also want to mention again that I was able to watch movies, tv shows with no signs of horizontal lines or banding issues which is a telltale sign of the gate drivers failing according to others. It just suddenly stopped working mid-movie and didn't want to come back on again. 2 -5 code.
                              I think it is wisest to keep the TV in the back of the room and wait for the same model to come along again with a smashed screen and harvest the boards to play around with.
                              • nomoresonys
                                • 12229
                                • U.S.
                                #75
                                Your meter might not be ideal for some measurements, you can pick up a digital one at a big box store for around 10 bucks.
                                  • Apr 2021
                                  • 94
                                  I'm going to remove R7305 and test it with my multimeter since it's a component that can be fried in similar models IE: LC-70 series
                                  Since there is a repair kit including the KIA378R12PI I think I'm on the right track now.
                                    • Apr 2021
                                    • 94
                                    Looks like 100 ohm resistor with the writing 2WJ on the side.
                                      • Apr 2021
                                      • 94
                                      Hello R_J
                                      I don't know exactly which board you have but Sharp did have a problem with D7805 shorting. might be worth checking. original diode is NUR460, change to MUR460
                                      Can you give some guidance how to test this diode with my multimeter?
                                      • R_J
                                        • Jun 2012
                                        • 9581
                                        Hello R_J
                                        It's a diode, Use diode test, it should read open one way and .5xx or .6xx the other way. If it reads shorted then it needs to be replaced with the newer version.
                                          • Apr 2021
                                          • 94
                                          Thanks. It's reading .500
                                          • Superbee_dad
                                            Sharp 80” long short flash backlight error - Help
                                            by Superbee_dad
                                            Hello Sharp TV experts
                                            Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
                                            > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
                                            > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
                                            01-24-2025, 11:51 PM
                                          • cm0002
                                            Sharp LC-55N7000U 1 long 5 short blinking, no display
                                            by cm0002
                                            I've got a Sharp LC-55N7000U. It has a standbuy LED when plugged in, but powering it on causes it to blink 1 LONG and 5 FAST. Theres no display and no backlight.
                                            Nothing I checked has that blink pattern for Sharp TVs and there's only one multi-button on the TV itself so that service menu trick involving the input button doesn't work either. Its a post-Hisense buyout TV so that probably makes sense lol
                                            I've tried disconnecting the panel sides from the TCON alternating sides, but no change in behaviour even when the whole TCON is disconnected,...
                                            06-19-2023, 06:21 PM
                                          • joblo37pam
                                            Sharp LC-80LE844U Blinks 2 slow, 5 fast
                                            by joblo37pam
                                            It's been a while since I've checked in here or needed input on narrowing down what to replace on a TV repair, but I've got one on my bench now that has me wondering. The lack of part (board) availability means I may need to do some component-level diagnostics, and a second opinion is always good when it comes to that.
                                            The issue - Sharp LC-80LE844U does not display. Power light comes on for a while, then you can hear a relay click off and the light blinks twice slow, then five times fast. Service manual points to 'Panel Power Supply Error' with this code, but isn't much more help...
                                            10-26-2023, 02:17 PM
                                          • Charrlie
                                            Sharp Lc-70le734u blinking 2 long 5 short
                                            by Charrlie
                                            Just picked up this sharp tv not too long ago and it started not wanting to start the other day, giving me the notorious 2 long-5 short blink pattern indicating a power issue. I was able to force start it a handful of times (once the tv has fired up it has no issue running for 5+ hours). But now as of yesterday, no matter what I try to do button combination wise, I just receive the same blinking code.
                                            So I busted into it and have done the following:
                                            -Removed the power board and inspected for any bad caps, burn spots etc. Do not see any instances of such ...
                                            07-07-2022, 02:02 PM
                                          • klassic
                                            Sharp Aquos LC-60LE635E three blinks
                                            by klassic
                                            Hi community,
                                            I will describe my problem with a TV in those short following terms to be the most precise :
                                            What i have :
                                            power board DPS-162KP-1
                                            main logic board QPWBXF733WJN2
                                            symptoms :
                                            white led light logo at startup,
                                            after 2 minutes, blinking 3 times a row, repeating
                                            no backlight (and apparently no picture, checked panel with flashlight)
                                            no startup sound
                                            powerboard investigations :
                                            1-2 PNL : 0v
                                            3-4 GND
                                            5-6-7-8 UR : 13.15v
                                            9-10-11-12...
                                            10-24-2023, 01:39 PM
