Sharp LC60C6400U - 2 long binks, 5 short blinks error code
  • R_J
    • Jun 2012
    • 9579
    Re: Sharp LC60C6400U - 2 long binks, 5 short blinks error code
    Originally posted by Noobwithamultimeter
    How would you account for me being able to use it for 206 hours on and off without issue then all of the sudden panel is bad? I will try the t-con trick and let you know. As for the values of the regulator, it is
    (1) 13.19V
    (2) 12.14
    (3) 0V (ground)
    (4) 2.68V
    Same goes for the power supply, or the main board, correct? Why should they fail. It is likely that one of the panel driver ic's is failing, not the backlight.
    • Noobwithamultimeter
      • Apr 2021
      • 94
      If a light breaks in your home - is it time to buy a new home?
        • Apr 2021
        • 94
        What should I test next? I have my multimeter handy.
        • R_J
          • Jun 2012
          • 9579
          Buy a new house with a working tv.
            • Apr 2021
            • 94
            Alright.
              • Apr 2021
              • 94
              What are the steps to determine failing panel drivers ICs?
              • rievax_60
                • May 2012
                • 897
                • australia
                #27
                Many LED LCD TVs are left to run at their default backlight setting of 100%.
                This must be shortening LED lifespan.
                • RJARRRPCGP
                  • Jul 2004
                  • 6304
                  You likely have a bad panel, Disconnect the T-Con from the panel (Flat cables) and see if the tv comes on with backlight.
                  QFT, likely a bad panel driver, based on Budwich's posts, IIRC.
                  https://www.badcaps.net/forum/showthread.php?t=48477
                  ASRock B550 PG Velocita
                  Ryzen 9 "Vermeer" 5900X
                  Arc A770 16 GB
                  eVGA Supernova G3 750W
                  Alienware AW3423DWF OLED
                    • Apr 2021
                    • 94
                    That's bad news. I did the removal of the tcon cables a couple of times, but no backlight will come on. So after sifting through the thread I've come to the conclusion that the 2 - 5 blink pattern seems to be a catch all for whatever issue ranging from power board to panel failure. Now I was able to get mine to work after replacing the KIA378R12PI regulator, then have it fail, re-do it and succeed for over 100 hours. When watching the set I noticed no lines, and the image was good. I will try to get it back on to take a picture.
                      • Apr 2021
                      • 94
                      After looking up repair kits for this model that solve the 2 - 5 blink code, I saw some 100k ohm resistors for the kit as well as the KIA378R12PI regulator. Should I be checking these next. Also which ones do I check and what value should they be at?
                        • Apr 2021
                        • 94
                        I'm just going to start testing and posting the values
                        R7305:
                        Top 4.99V
                        Bottom: 0V
                        • RJARRRPCGP
                          • Jul 2004
                          • 6304
                          The LCLExxxxxx, is the series that apparently led to Sharp selling their TV business to Hisense!
                          Arc A770 16 GB
                            • Apr 2021
                            • 94
                            Oh man. Hisense is hot trash. The picture on this set is great. Most Hisense models get lines after a year.
                            • RJARRRPCGP
                              • Jul 2004
                              • 6304
                              That was before Hisense bought the Sharp TV division, IIHC.
                              And lines after one year? Ooofff! That's worse than that LG 49UH6100 upstairs in my sister's bedroom, which seems to have a writing on the wall that there's at least shitty LEDs!
                              Arc A770 16 GB
                                • Apr 2021
                                • 94
                                In this thread https://www.badcaps.net/forum/showthread.php?t=63390
                                BUDM suggests that the regulator is fine, but something is not letting it turn on normally, so Redrebel puts a resistor on one of the leads and attaches to a ground screw. Would this be worth attempting?
                                • RJARRRPCGP
                                  • Jul 2004
                                  • 6304
                                  I dunno.
                                  Arc A770 16 GB
                                    • Apr 2021
                                    • 94
                                    Looks like my next option is to follow https://www.badcaps.net/forum/showthread.php?t=48477
                                    I'm going to remove the outer frame and take a look CAREFULLY at all the flex tabs, if I see a burn mark on one, I assume I will have to cut all the tabs from that side. freaafter8 had success with a 70" doing this.
                                    • RJARRRPCGP
                                      • Jul 2004
                                      • 6304
                                      Most likely, with 2010s' Sharp, especially a mid/middish-2010s' Sharp!
                                      Arc A770 16 GB
                                        • Apr 2021
                                        • 94
                                        Yes that's the year I think. So I just inspected all the tabs on the left side, then the right side I saw no burned IC on either of them, so I'm ruling that out for now. My suspicion now is that it is indeed one or two burned out LEDS.
                                        https://www.youtube.com/watch?v=c0Kv5ZTuGb0
                                        This video shows led strip with the 2-5 error code which is possible after all.
                                          • Apr 2021
                                          • 94
                                          I've got the tv totally apart now and can see all the leds. They all look perfect. All I have to test them with is 2 AAA batteries but I'm not having luck. Does anyone have any other ideas?
                                          • Superbee_dad
                                            Sharp 80” long short flash backlight error - Help
                                            by Superbee_dad
                                            Hello Sharp TV experts
                                            Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
                                            > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
                                            > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
                                            01-24-2025, 11:51 PM
                                          • cm0002
                                            Sharp LC-55N7000U 1 long 5 short blinking, no display
                                            by cm0002
                                            I've got a Sharp LC-55N7000U. It has a standbuy LED when plugged in, but powering it on causes it to blink 1 LONG and 5 FAST. Theres no display and no backlight.
                                            Nothing I checked has that blink pattern for Sharp TVs and there's only one multi-button on the TV itself so that service menu trick involving the input button doesn't work either. Its a post-Hisense buyout TV so that probably makes sense lol
                                            I've tried disconnecting the panel sides from the TCON alternating sides, but no change in behaviour even when the whole TCON is disconnected,...
                                            06-19-2023, 06:21 PM
                                          • joblo37pam
                                            Sharp LC-80LE844U Blinks 2 slow, 5 fast
                                            by joblo37pam
                                            It's been a while since I've checked in here or needed input on narrowing down what to replace on a TV repair, but I've got one on my bench now that has me wondering. The lack of part (board) availability means I may need to do some component-level diagnostics, and a second opinion is always good when it comes to that.
                                            The issue - Sharp LC-80LE844U does not display. Power light comes on for a while, then you can hear a relay click off and the light blinks twice slow, then five times fast. Service manual points to 'Panel Power Supply Error' with this code, but isn't much more help...
                                            10-26-2023, 02:17 PM
                                          • Charrlie
                                            Sharp Lc-70le734u blinking 2 long 5 short
                                            by Charrlie
                                            Just picked up this sharp tv not too long ago and it started not wanting to start the other day, giving me the notorious 2 long-5 short blink pattern indicating a power issue. I was able to force start it a handful of times (once the tv has fired up it has no issue running for 5+ hours). But now as of yesterday, no matter what I try to do button combination wise, I just receive the same blinking code.
                                            So I busted into it and have done the following:
                                            -Removed the power board and inspected for any bad caps, burn spots etc. Do not see any instances of such ...
                                            07-07-2022, 02:02 PM
                                          • klassic
                                            Sharp Aquos LC-60LE635E three blinks
                                            by klassic
                                            Hi community,
                                            I will describe my problem with a TV in those short following terms to be the most precise :
                                            What i have :
                                            power board DPS-162KP-1
                                            main logic board QPWBXF733WJN2
                                            symptoms :
                                            white led light logo at startup,
                                            after 2 minutes, blinking 3 times a row, repeating
                                            no backlight (and apparently no picture, checked panel with flashlight)
                                            no startup sound
                                            powerboard investigations :
                                            1-2 PNL : 0v
                                            3-4 GND
                                            5-6-7-8 UR : 13.15v
                                            9-10-11-12...
                                            10-24-2023, 01:39 PM
