Samsung LN32D403e2DXZA
  • dprit
    • Jul 2015
    • 49
    Customer brought this 32" in. Set will come on and you will have sound but the picture is only on for half a second. Sound is still there. Shut it off and same thing - sound always but picture for half a second. There is 12v on inverter board all the time. I replaced the main but same problem. What am I missing? When the picture is on, it looks a little dark. I see no lights behind the panel when it goes dark.
  • anupkg1985
    • Sep 2020
    • 180
    Re: Samsung LN32D403e2DXZA
    Do you have backlights on any time? Could you check with flashlight if picture is still there on screen?
      Please attach pictures of the whole backside of the TV showing all the boards using 'GO ADVANCED' function so we can see what we are dealing with.
        • 12323
        • U.S.
        Unplug tv from power, unhook cable from powerboard to mainboard, leave unhooked, plug power cord back in to powerboard, do backlights come on and stay on?
        • dprit
          • Jul 2015
          • 49
          Backlights come on for half of a second then go out and stay out.
            • 12323
            • U.S.
            And THAT happens when you do the test in post #4 or did you not do the test?
            • dprit
              • Jul 2015
              • 49
              The answer to post #4 is the back lights come on for a half a second then go off. And with a flashlight , I can see the picture. I have replaced the Inverter and the main and still have no back lights.
                • 12323
                • U.S.
                Ok, You could check the voltage between the main filter cap think it's CP803s, meter set to 600 vdc, black neg. probe on neg. leg, red pos. probe on pos. leg, check it in standby/tv plugged in but turned off, take note then hit power take note, be VERY CAREFUL not to touch anything with your hands, HIGH DEADLY VOLTAGE on this hot side of powerboard.
                • dick_barton
                  • Aug 2015
                  • 6643
                  • Wales
                  What voltages do you have at CON001 on the inverter board?
                  Pin 9 OVP =
                  Pin 10 CNT_PRT =
                  Pin 11 VCC =
                  Pin 12 LD =
                  And also CN802
                  • dprit
                    • Jul 2015
                    • 49
                    The voltage across CP803s is 166v SB and 393v when the set is on. Voltages at CON001 on the inverter board when on are: pin 9- 0 volts, pin 10-8.4volts, pin 11-12.7volts, pin 12-0volts.
                    • dick_barton
                      • Aug 2015
                      • 6643
                      • Wales
                      Pin 12 LD must initially be taken high at power on because you say the backlights flash and then either due to, for example, a lamp or transformer fault, it is being switched off.
                        • 12323
                        • U.S.
                        There's a bunch of inverter boards on ebay for 11 bucks and up, electroparts has one but if it's a lamp issue then a new inverter won't fix it of course.
                        • dprit
                          • Jul 2015
                          • 49
                          I have replaced the main and the inverter boards with no change. I'm leaning towards a lamp problem. Asking the customer a few more questions, I find this tv is in a bathroom. Maybe the moisture caused a issue with the lamps. Thanks for the help!
                          • TVAddict
                            • Jan 2022
                            • 76
                            • Caribbean
                            I have the same exact TV with the same exact problem.
                            My readings on connector CN1801 are as follows - LD - 0volts / Vcc - 12.6v / CNT_PRT - 8.4v / OVP - 1.8v
                            Readings Taken with TV on.
                            The other pins with Low (fet) and high (fet) i'm not sure how to measure those?
                            at turn on High reads about upwards of 140v AC then dies off to around 19v AC
                            Low starts at 19v AC goes up to just 20v AC and drops back to 19v AC - i get no readings using the DC scale.
                            i tried another inverter board same problem, could it be power supply related or maybe i have a light failure/issue as well?
                            Any ideas help is appreciated.​
                            • TVAddict
                              • Jan 2022
                              • 76
                              • Caribbean
                              Forgot to ask, if it is some light issue as this thread is mostly suggesting, is there a way one could force the lights to stay on?
                                • 12323
                                • U.S.
                                Unhook all connectors from the powerboard, plug the power cord into powerboard, plug into power, check voltage on all the pins of CN802 connector, meter set to vdc, neg. probe on chassis ground, pos. probe on each pin, take care to only touch one pin at a time, report results. If you don't have an auto ranging meter, set meter to 20 vdc.
                                • TVAddict
                                  • Jan 2022
                                  • 76
                                  • Caribbean
                                  i did measure voltages at CN802 but with ALL connectors hooked up and TV on - pins 1 - 7 = 12.6v pin 11 and 13 = 5.6v pin2 = 0.76v pin12 = 5.2v pin14 = 3.5v pin6 = 5.1v - but all voltages were steady, tv remains on with sound just the light cuts off after a few seconds of the tv turning on. Also voltage at the main cap is steady at 394v
                                  But i'll try what you suggested and see what readings i get...
                                  • TVAddict
                                    • Jan 2022
                                    • 76
                                    • Caribbean
                                    with all connectors off readings on CN802 are :
                                    pins 1 - 7 = 13v
                                    11,13 = 5.2v
                                    14 = 3.3v
                                    12 = 5.2v
                                    2+6 = 0v
                                    Tried the light test in post#4 - the light flashed for a second and turned off
                                    Tried leaving the OPV pin disconnected = same problem
                                    tested the 474j cap it read 460, i figure that's still workable..?
                                    • TVAddict
                                      • Jan 2022
                                      • 76
                                      • Caribbean
                                      hey guys i decided to take the TV apart and have a look at the lights, turns out it is the problem as suspected, as you will see in the pictures, one of them ( the middle light ) is literally busted, so that's it for me, it's the garbage for this tv, thanks to this thread and everyone for your help..
                                      • TR103
                                        by TR103
                                        - it keeps rebooting
                                        01-22-2025, 04:12 PM
                                      • Mgiffune
                                        by Mgiffune
                                        06-09-2024, 10:28 AM
                                      • Dodgethis
                                        Samsung QN75Q6DRA, No Picture, Has BL, and Sound
                                        by Dodgethis
                                        Hello all,
                                        This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
                                        09-11-2024, 07:39 AM
                                      • JohnML1975
                                        Samsung UA50TU8000W no picture and no sound
                                        by JohnML1975
                                        Hello All
                                        have seen posts on this model in here but my problem sounded different so thought i would create a thread
                                        TV will not turn on
                                        There is no standby light
                                        When I press ON button for remote the red standby light does flash but no picture and no sound
                                        From the back of the TV I can see the red light on the back of the mother board
                                        Holding torch to the screen I cannot see a picture
                                        I removed the back cover
                                        Observing the boards I cannot see any damage
                                        I disconnected the main board from the power supply
                                        the back...
                                        08-30-2025, 09:40 PM
                                      • marekk
                                        Samsung QE55Q67RAT no sound and bad picture when streaming
                                        by marekk
                                        I got Samsung 55 inch QLED QE55Q67RAT where there is no sound at all and when using youtube for example picture is not clear and noisy.
                                        I have swapped Burr-brown 88002A chip on the mainboard but didn't help, different set of speakers didn't help either
                                        Mainboard is based on pcb BN41-02695A BN94-14007B
                                        I will appreciate any help
                                        Many thanks
                                        Marek...
                                        05-29-2025, 02:23 AM
