LG 50UH5530 Turns Off And Wont Turn On: diagnoses included
  • velorider562
    • Sep 2020
    • 4
    Hoping for some help diagnosing the problem with my TV so I don't just throw parts at it or the land fill. Its an LG 50UH5530, that after being unplugged for a few hours it will turn on and stay on for about 15 seconds, before shutting off. After that, when pressing the power button the red led will blink but the TV will not turn on. I have read the folllowing post that discribe very similar symptoms and followed the steps documented.
    https://www.badcaps.net/forum/showthread.php?t=87284
    Current Status:
    STB pin on power board has 3.4v, always.
    13.2 pin on power board have 6-9v
    When first turning on before TV shuts down, 13.2 pins have 13.1-13.2 volts
    When jumping STB with resistor 13.2v pins have 13.1-13.2 volts
    When testing led strips with tester, all strips light up when viewing from the back of the tv and run at about 66v. I can't see the individual led since I have not remove the panel
    When turning on with the led strip disconnected same thing happens
    When turing on with TCON disconnected same thin happens
    With the flashlight test is appear the LCD is not on, so it's more then just back light
    The OP in the other thread eventaully replaced the led strips and resolved his problem. I have also read on Shop Jimmy that led failures are much more common then power board failures on this model.
    So I can throw led strips at it but I'm hoping to confirm a diagnoses first. My concern is it appears that the main board is instructing the power board to shutdown, so either it's detecting some fault or the main board is faulty and shutting down.
    I'm looking for suggestions to help me diagnoses the failure.
    I have some expereince with hardware so I have good amount of tools, but I am far from an expert.
    TV Background:
    I picked up the TV off Nextdoor app. Two of the three HDMI ports had come off the mainboard, the original owner said it was like that for awhile and still worked. I resoldered one back on, the other the pins where too bent to resolder. If I can get the TV working and find the ports on DigiKey I'll resolder the remaining missing port later. The 3rd HDMI port that wasn't disconnected was loose, upon closer examination there was no solder on the mounting pins of the port, the only thing holding the port where the pins. The pads where not damaged, and I believe the original owner that the TV worked for quite a while like this so I don't think its related to the failure.
    John
  • velorider562
    • Sep 2020
    • 4
    Re: LG 50UH5530 Turns Off And Wont Turn On: diagnoses included
    I may have found the issue. I broke out the cheap usb microscope and was scanning the main board and I think found out burnt out caps. These cap are right in front of the tcon connector.
    Any idea what specs these caps are?
    • velorider562
      • Sep 2020
      • 4
      Gets worse, went to desolder the cap and found another burnt component. Guess it just a new mainboard, but right now everyone is out of stock and they want close to $90 for it. Maybe the hdmi shorted some components.
      John
      • diif
        • Feb 2014
        • 6978
        • England
        Have you checked those caps with a meter, they don't look burnt to me.
        • DXseekerMO
          • Feb 2018
          • 1119
          • US
          I recently had this issue with this exact same model TV. I actually got it to run for a day and a half before the problem reared it's ugly head. After the screen went black with no picture I let it sit for 24hrs, turned the TV on and the picture remained on for about 10-15min.
          When the screen went black the 13.2V pin had unstable voltage from about 7-10V.
          Turns out one LED was breaking down after some time of use. Replacing the backlight strips fixed the problem. This model of TV is known for crap backlights.
          If the backlights are the problem DO NOT, I repeat DO NOT install used LED strips and DO NOT replace the strips individually, replace them all at one time with a set from ShopJimmy.com.
          It seems to me that when one LED goes bad in this model TV the remaining LEDs get stressed. Not replacing them all will very likely mean a repeat backlight repair.
          They call me......."threadkiller"
          • jason123
            • Oct 2015
            • 1068
            Gentlemen, I am having the same exact problem. Standby voltage is very unstable 8-12 V, when I turn the set on, it dips to 0 then 8 volts. You can see the LED on the main board that should remain red, is flashing on, then off. I had both the PFC and LED Driver ICs (bought on previous projects) so I replaced them and no luck. Replaced the backlight, and no change. Finally, I got a used Power Supply board from eBay, and the system is on and happy.
            I'd really like to fix the power supply board if at all possible. Checked Caps, and Diodes, and FETs and nothing has "Failed" but I can't tell if they're weak.
            The TV occasionally would start up for 1/2 hour or so.. then shuts off.
            then, as long as it's plugged in, it is in the Cyclical unstable Standby voltage. Help is much appreciated.
              • 12187
              • U.S.
              seems like bad voltage regulation on powerboard.
                • 12187
                • U.S.
                maybe a weak startup cap near the connector.
                • jason123
                  • Oct 2015
                  • 1068
                  Any idea which cap that is?
                    • 12187
                    • U.S.
                    check c57, see what kind of voltage you have.
                      • 12187
                      • U.S.
                      there's a dirty test to kind of tell if the caps are doing what they should, you put your meter on a high ohm setting then put a probe on each leg, it should rise or fall at a steady even pace, you can reverse the probe leads and should go in the other direction slowly and evenly, it's no replacement for a regular capacitance meter of course. Test is done with tv unplugged.
                      • R_J
                        • 9535
                        I would try replacing C14 and see what happens. another suspect might be C5
                        • dskall
                          • Oct 2016
                          • 2905
                          • usa
                          While you were changing controllers you should have changed your 13v controller. But it may just be bad cap or diode for the controller circuit.
                          • jason123
                            • Oct 2015
                            • 1068
                            Fluctuates just like 13.2 v (or standby)
                            • jason123
                              • Oct 2015
                              • 1068
                              C5 i tried already. No effect. Just changed out c14 and no effect.
                              • jason123
                                • Oct 2015
                                • 1068
                                I replaced both ICs... no change
                                  • 12187
                                  • U.S.
                                  it does seem like the same issue DXseeker had, I think it's a backlight problem.
                                  • jason123
                                    • Oct 2015
                                    • 1068
                                    Replaced backlight already, and backlight works with the replacement power supply board.
                                    • captainKKK
                                      • Sep 2018
                                      • 287
                                      Seems your issue maybe under the silver heat sink.
                                      • R_J
                                        • 9535
                                        What voltage do you have across C5? is it also fluctuating in standby mode?
                                        What is the main filter (C2/C3) voltage? does the pfc turn off in standby and back on when powered on?
                                        • Kingfreddie
                                          LED problem on samsung UE55F6475, 2 strips work. The rest is flashing every second.
                                          by Kingfreddie
                                          Ok.. this is the story:
                                          Have an old Samsung LED 3D TV (UE55F6475). First it started to lose light on the lower 40% of the screen now and then. Like for 10-60 mins and then it would work again. Then a bit later it just got stuck in that position. The lower 40% of the screen is dark, and it gets progressively darker the lower u go so it's obviously that LED strips where not working. I also looked for similar errors online and saw an exact copy and on that one it was faulty LED strips.
                                          This is kinda how it looked, just that mine were at the bottom of the screen:
                                          09-11-2021, 01:57 AM
                                        • Stephen
                                          MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable
                                          by Stephen
                                          MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable to reset the computer. I disconnect the battery fully and then reconnect it and it won't turn back on. After letting it sit for a day I plug the battery back up, and the MagSafe 3 cable and it powers on and stays ons, once I plug in a USB C cable into the port closes to the MagSafe port it turns off and the Amber light turns off and won't turn on. No water damage, nothing, I want to do a DFU restore to wipe the computer since the customer stated they did an update and ever since it just decided to not work...
                                          03-15-2024, 09:37 AM
                                        • www
                                          LG L192WS-BN backlight turns off after 1 second
                                          by www
                                          I am testing an old LG L192WS-BN monitor I have that gives an image, but has a backlight issue. When you turn it on the backlight turns on 1 second and it turns off, turns on again, 1 second and it turns off and stays off. Using a flashlight I can see there's still an image.
                                          I replaced a bulged cap on the main board, but made no difference. I also got another exact same model monitor that has a broken ccfl (the connector got ripped from the panel and the main screen connector is also broken so I can't use this panel to test), tried using the main board from this one, same issue....
                                          03-24-2024, 05:26 PM
                                        • andrhouseolly
                                          Dell Precision 5510, AAM00 LA-C361P Rev:2.0 turns on, no image.
                                          by andrhouseolly
                                          Hi.
                                          I kindly ask you to help me solve the problem.
                                          Dell Precision 5510, motherboard AAM00 LA-C361P Rev:2.0
                                          The board turns on, there is no image.
                                          Read more. When the power supply is connected, the front panel indicators light up briefly.
                                          When you press the power button, the button indicator lights up. The board works
                                          there is no image, there is no matrix initialization, there is no image on HDMI.
                                          When turned on, the fans do not spin, but when they warm up they start spinning.
                                          When you turn off the button, the fans spin up to full speed for a short...
                                          05-11-2024, 03:14 PM
                                        • Egidio85
                                          Samsung UE55F8000SZ Turns on and off immediately
                                          by Egidio85
                                          good morning, I have a samsung UE55F8000SZ tv that turns on, shows the logo and turns off after 1-2 seconds.
                                          This defect happens continuously, hearing the classic click of the relay every time.
                                          Power supply board BN44-00636B
                                          disconnecting the mains and lamps from the power board always causes the same problem.
                                          Is it normal that without anything connected this power supply turns on and off cyclically?
                                          any suggestions on what to check?
                                          thanks in advance
                                          03-11-2025, 12:45 PM
