LG 50UH5530 LED TV suddenly won't power up
  • kr00
    • Aug 2020
    • 10
    The TV was working properly, then after powering off for about 2 hours, the TV will not power up. The standby light is on, and solid as usual. When powering on, the screen will light up for about 1 second, then shuts off, and the standby light comes back on. When attempting to power on a second time, the screen does not flash, but the standby light flashes 3 times, then goes back to solid. Unplugging the TV for about 30 seconds will allow the replication of these events exactly.
    When testing the Power board, the standby output lead shows zero voltage rounded to a hundredth. All capacitors look normal, and all fuses are good. The power board model is L5L01F.
    Is there any hope of repairing this power board?
    Re: LG 50UH5530 LED TV suddenly won't power up
    Please attach good clear pictures of the whole backside of the TV showing all the boards, and good clear straight shots of the whole power supply board so we can see what we are dealing with.
    • kr00
      • Aug 2020
      • 10
      I included a closer view of the power board halved in two separate photos in addition to a photo depicting the entire board.
      • Diah
        • Feb 2013
        • 6440
        screen will light up for about 1 second mean you have ONE LED shorted at the back light
          You need steadier hand when taking pictures, the pictures are blurry.
          Any how, lest start by check the Voltages on the black connector, all connectors must be back in place, of the power supply board to see if the power supply Voltages or control Voltages are still present or not.
          The connector pins are arranged in EVEN and ODD column as shown on the chart printed on the circuit board, the ODD column you can make the measurement by probing the pins on the exposed pins on the top side of the board, for the EVEN number pins you will need skinny probe to probe from the connector wire entrance side.
          You will leave the Black probe of the meter on the chassis, then read probe on each pin.
          You MUST report the readings when the power switch is activated, do not worry what condition of the TV is in after the power switch is activated.
          Odd column pins:
          Pin 1 STB = xxx V
          Pin 3 GND = xxx V
          Pin 5 13.2V = xxx V
          Pin 7 13.2v = xxx V
          Pin 9 .................
          so on and on for other pins.
          https://www.badcaps.net/forum/attach...2&d=1596323041
          You do have and know how to use Digital meter, correct?
          The problem can be bad LED also, we can check the Voltages on the LED connector next. The set has 3 LED strings.
          • kr00
            • Aug 2020
            • 10
            I attached a more clear photo near the main board connector. This one seems less blurry. The values of the 12 pins are below. All 13.2 V pins gave values among the range listed by each.
            ODD
            ENA => 0 V
            GND => 0 V
            13.2V => 7.4 -10.11 V
            13.2V => 7.4 - 10.11 V
            GND => 0 V
            STB => 0 V
            EVEN
            ADJ => 0 V
            GND => 0 V
            13.2V => 9.5 - 10.7 V
            NC => 0 V
            After testing this, I disconnected the main board again, and values remained the same on all pins. I also heard a distinct "ticking" sound about every 1.5 seconds after attempting to power on which had not been present before.
              ODD
              ENA => 0 V
              GND => 0 V
              GND => 0 V
              STB => 0 V
              EVEN
              ADJ => 0 V
              GND => 0 V
              NC => 0 V
              So those readings are done without the cable between power supply board and the main board connected?
              What do Voltages on those same pins if you do NOT have LED connector in place also?
              Ticking sound from power supply board?
              BTW, I am still having hard time reading the P/N as printed on the bar code and on the board so I can locate good clear pictures of the whole top and bottom side of the board, i need then to be really clear so I can trace out the schematic.
              Can you provide me with good clear pictures of the whole top and bottom side of the board?
              • kr00
                • Aug 2020
                • 10
                Those readings were taken with all connectors in place. After testing, I unplugged the TV, then disconnected the main board connector, and tested all pins again. When testing with the main board disconnected, the 13.2V pins gave a reading of about 9.9V, and all other pins remained the same. Getting 0V on the STB pin seems odd.
                After removing the LED connector, the pins did not appear to change voltage at all.
                The ticking sound is coming from the power board.
                I took one close up photo of the bar code number.
                When you say "top and bottom" of the board, do you mean the under side of the board which lies near the TV chassis when referring to the "bottom" of the board?
                  1) In standby, the 13.2V power supply may only put out about 10V, but when it is turned on then it will jump up to 13.2V. So right now is it sitting steady at 9.9V?
                  2) STB pin is the PS-ON pin, it receive the on command from main board.
                  3) So is the power supply still ticking when nothing connected to the board but just the AC power?
                  4) We will force on the power supply (nothing connect to the board except the AC power) by using 1 ~ 2K resistor between STB pin and 13.2V pin, you should see steady 13.2V at 13.2V pin.
                  5) The pictures I need are the straight shots of whole top side of the circuit board and then the whole bottom side of the board where copper traces and the surface mounted components are.
                  6) Do you have LED tester? This TV uses 3 LED strings.
                  • kr00
                    • Aug 2020
                    • 10
                    1) In standby, the 13.2V pins have been sitting steady at 9.9V.
                    3) In the last power up, I heard no ticking sound coming from the power board as before.
                    4) I do not know how to perform what you are requesting in step 4.
                    5) I will upload pictures of the face and backside of the board as soon as I am able. It seems as though the pictures previously have not been of sufficient quality, and so, I am afraid that the future pictures will be no better.
                    6) I do not have an LED tester.
                      1) That 9.9V in standby is normal then, it is enough to keep the main board alive..
                      • kr00
                        • Aug 2020
                        • 10
                        However, in standby, the STB pin gives 0V. I was under the impression that it should be around 3.3V or 5V, depending on the board. Does this mean the issue is with the power board and that it simply needs to be replaced?
                        • neilc6
                          • Nov 2015
                          • 1550
                          The STB pin is a logic signal from the main board to the power supply to turn the power supply on (sometimes labelled PS-ON). It should go high when the TV is turned on. By using a pull up resistor in step 4, this will force the power supply on with the main board not connected so you can test the output voltage.
                            See my post 9 about STB pin.
                            • kr00
                              • Aug 2020
                              • 10
                              I apologize for my ignorance, but I am still unclear on what I need to do to "force on" the power supply with the main board disconnected.
                              • kr00
                                • Aug 2020
                                • 10
                                After connecting the STB and 13.2 pin with all connections to the power board unlogged except the the AC power, every 13.2V pin reads 12.96V.
                                • kr00
                                  • Aug 2020
                                  • 10
                                  After more attempts of trying to find fault with the power board or main board, I decided to dismantle the TV further to test the LED strips. This seemed to be a possible point of failure since the screen would power up for less than a second then go black.
                                  Upon testing the strips, one LED strip would light up then fade out completely. I replaced this strip, and now the TV is working properly again.
                                  Thanks for the assistance.
                                  • AFVet
                                    • Aug 2022
                                    • 4
                                    Guys,
                                    I have same problem as KR00, I tested all LED strips, they seemed to test all good with LED tester. After putting the TV back together, it came up once and I hit the power off button, which went to the red standby light, after attempting to power back up to verify, it went back into fault and blinking two red lights. I went down the same rabbit hole thinking the STB should be 3-5 Volts, now after reading your responses, I see it was in vain. All LED strips lit up, do you think I still have and LED problem?
                                    • nomoresonys
                                      • 12276
                                      • U.S.
                                      yep, most cases of one flash then off, means a backlight issue.
                                      • AFVet
                                        • Aug 2022
                                        • 4
                                        Not sure what brought it back on line, checked PS capacitors and transistors, rechecked backlights. All tested good. put it all back together and the darn thing started working. Not sure what it was maybe bad solder joint, or just the josling caused it to come back online. We'll see how long it lasts. Bein on all day, turned on and off with remote just fine.
                                        • AleMonti
                                          LG 55EG910V - no power and no standby light
                                          by AleMonti
                                          Hi everyone,
                                          I'm trying to troubleshoot and repair this old LG OLED curved TV, model 55EG910V.
                                          I did some basic troubleshooting and reviewed most related posts here, but I wasn't able to isolate the issue.
                                          The TV shut itself off during playback and never came back to life - the standby light remains off. My dad claims that it has happened a few times in the past but the issue resolved itself after some time. Not this one.
                                          After checking the basics I did the following:
                                          • I measured all voltages and as expected the only active supply is the 3.5V standby. It
                                          11-04-2024, 05:02 PM
                                        • SkishyIshy
                                          Sony Bravia XBR-65x900f: No Power, No Standby-light - however 3.3v STBY is present
                                          by SkishyIshy
                                          Hey All,
                                          I have a Sony 65x900f that I purchased cheap because of a no-power issue.
                                          I assumed that because there is no standby light visible, it would be an easy fix - however upon opening up of the unit I can confirm that the 3v3 standby voltage is making it's way from the power supply to the main board. I'm a little confused as to why there is no standby light.
                                          I am firstly wondering if anyone has this model of TV, or has worked on one and can give me some insight. I have tried to find a service manual for this model, to no avail - and would really appreciate...
                                          03-17-2021, 11:44 AM
                                        • noinimod
                                          Sony 55X900E no standby light, no power. Replaced mainboard already
                                          by noinimod
                                          No standby red light, nothing
                                          This Sony has a separate AC->DC power adapter supplying 19.5V to the TV power board (JK3)
                                          Disconnected JK3 power board from main board, checked voltages on all the pin outs
                                          At a few pins I can see the power supply providing 19.5V to the main board
                                          Based on the service manual triage.. it seems to be pointing towards the power board (JK3) being the most possible culprit
                                          LED light turns on when I disconnect LED driver board ribbon from mainboard (so i thought it is the mainboard,...
                                          12-22-2021, 12:58 AM
                                        • x_orange90_x
                                          Vizio E550i-A0 no power, no standby light
                                          by x_orange90_x
                                          I have a Vizio E550i-A0 that will not power on. It also does not display the standby light in the corner. I disconnected the main board cable to see if the backlights would light but they did not (maybe this is normal for this set?). I checked the voltages on the plug and they all read in mV or 0, so there's no voltage there. The fuses are ok, and the voltages of the 450v caps read about 160v. I see no visual damage on either the power supply or main board. I have read online that the main board is usually the culprit in this model, but not getting backlights with the main disconnected makes me...
                                          11-20-2023, 09:49 AM
                                        • ipatch
                                          troubleshooting microsoft surface pro 4 no power no led charge light
                                          by ipatch
                                          hello, �� i have been sitting on some microsoft surface pro 4 tablets for a while now. i was originally tasked with replacing the battery in one of the tablets, and ended breaking the screen and logic board in the process. decided to buy another tablet with the same specs. got that screen off successfully of the second tablet. the logic board appeared good, but i guess i shorted something out in the installation process of the logic which i've read is a common issue if there is no barrier between the logic board and battery pins. all that said, i ate costs of the repair and have...
                                          10-05-2023, 11:59 AM
