No back light on Samsung UN65MU6290, Need help modifying Power Supply Board.
  • brucetv
    • May 2015
    • 281
    • united states
    Re: No back light on Samsung UN65MU6290, Need help modifying Power Supply Board.
    Can't say I didn't warn you. I've done thousands of backlight repairs and this model by far is one of the sorriest POS I've ever had the mis fortune to have to repair and we just turn them down. The 6290F version is fine but if you see the POS 6290V version run as fast as you can because it's almost a fire hazard. Samsung should have some of the finest electrical engineers in South Korea and the MU series is the biggest failure money can buy. When you have to do a mod on the power supply every time you do a backlight replacement somebody didn't do their job right. And I refuse to fix your JUNK.
      • 12199
      • U.S.
      Hate samsung.
      • Chillin014
        • Jun 2020
        • 14
        A somewhat good update: I went ahead and replaced the MOSFET transistors (or whatever they are). This was unchartered territory for me and I ripped off part of the trace on one of them but I think I cobbled it back together alright. I did one at a time, and tested the TV after each. It wasn't until I replaced the second one that the flickering stopped and the TV began to function normally. I now have a steady backlight and a picture.
        My excitement was quickly squashed once I noticed very thin horizontal lines across the entire screen. I'm thinking this is unrelated to the repair and replacements I performed and possibly something wrong with the LCD panel.... I really don't know what to do at this point. Maybe I damaged it during removal. I think I'm going to slap it back together and just use it or sell it to someone who wants a nice garage TV.
        Agree. It's been a good learning experience for me but this is too much hassle.
        Originally posted by budm
        Part designator: Example
        R1 means the desigantor of that particular resistor is assigned as R1, so that 1.7 Ohms resistor must have designator so you can put in the correct resistor at the correct location.
        Oh! Yes I put them in the right places - R9211 and R9111. I forget the transistor locations.
        • Chillin014
          • Jun 2020
          • 14
          Okay this saga has finally come to an end. I fiddled with the ribbon cables and the lines on the screen disappeared. That was all I needed to claim a victory and start putting it back together. Well I guess I manhandled it or maybe I wasn't gentle enough snapping the back case on. I turned the TV around to appreciate the fruits of my labor only to reveal a F!#king black spot where the screen had cracked in the corner.
          I guess I'll be breaking it down and selling the parts.
            • 12199
            • U.S.
            Damn that sucks, that's another thing I hate about sammys, they just break too damn easily.
            • BiondicTV
              • Jan 2021
              • 3
              I'm looking for the IC9101, the two switching transistors, Q9101C and Q6201C part numbers. Shop Jimmy doesn't have the repair kit in stock. Your help is appreciated.
                • 12199
                • U.S.
                #27
                whats the rest of your model number UN65MU6290XXXX what letters go where the x's are?
                  • 12199
                  • U.S.
                  #28
                  they don't seem to be including IC9101 in the kits that I'm seeing, maybe test IC9101, check each pin, neg. probe on a board ground one of the metal parts that slide in place when you take it off the tv, pos. probe on each pin, I believe three pins should show continuity to ground, the other 13 should not.
                  • BiondicTV
                    • Jan 2021
                    • 3
                    The model number of the TV is UN65MU6290VXZA. Thank you.
                      • 12199
                      • U.S.
                      #30
                      I'm not seeing part numbers of the kit, if there's no markings on the IC, transistors, so you can look up the datasheets, I guess just email shop jimmy and ask them since the kit is out of stock, can they tell you which IC and transistors you need to get, the resistors are 4.7 ohms, theyre out of stock kit is there: https://www.shopjimmy.com/samsung-bn...nt-repair-kit/
                      • BiondicTV
                        • Jan 2021
                        • 3
                        Thanks, but Shop Jimmy is not willing to provide the part numbers. I think the IC part number may be SEM4082A.
                        • diif
                          • Feb 2014
                          • 6978
                          • England
                          #32
                          Yes it is https://www.ebay.com/itm/160633490803
                          • Nicktronic
                            Samsung Power Supply Board BN44-00874F
                            by Nicktronic
                            Hey everyone,
                            This power supply board is hard to find but there are repair kits available. This board had a blown fuse, FP801S, blown PFC MOSFET, QP802CS and ceramic cap, CP809. I replaced them with parts I already had and tested the rest of the parts that would've come in the repair kit and they were fine. I powered the board up on the bench expecting, in typical Samsung power supply board fashion, to see all my output voltages but, nothing. 0 volts on CNL801, CNM801 and CNT801. The only thing I have is 170vdc on the filter caps. No standby voltage either.
                            Anybody...
                            03-17-2025, 06:20 AM
                            by sam_sam_sam
                            After all of...
                            07-13-2024, 08:14 PM
                          • repair-it
                            Need advice testing a samsung power supply board with scope
                            by repair-it
                            I am attempting to test a samsung power supply board to verify the pfc ic is working. I am powering up the board with my isolation transformer. The board turns on fine but when I attempt to connect the ground for the scope probe, it trips out the isolator. I was taught not to 'float my scope' so I am wondering if I should test without connecting the ground lead or would that be asking for trouble? Not sure how else to test, I don't have a portable scope. I could plug direct to mains power but that would bypass the safety factor.
                            07-12-2025, 11:00 AM
                          • m1ch43lzm
                            by m1ch43lzm
                            05-12-2025, 08:37 PM
