Remove rear panel Sony Bravia KD-65X7500F
    • 12284
    • U.S.
    #61
    Re: Remove rear panel Sony Bravia KD-65X7500F
    Did you try Dick's suggestion in post #33?
    • viewerau
      • May 2020
      • 305
      Sort of....I can lift the right side next to the RF in area, look with a led torch, but still not see release points.
      I dearly want to open it, and will try all suggestions again.
      Signature:Seemingly hopeless tv fixer
      • budwich
        • Jul 2015
        • 3097
        take a thin piece of plastic (ie. old credit card, guitar pick, etc) and use it to slide under the area along edges that are shown in your post 26 pictures and the "exploded view" of things posted earlier.
        Related to your other question about the "dimples" on the back cover. To me, those indicate some sort of "standoff peg" or "pin" that may go into a female receiver to "lock" the back down.... but they could equally be just "free standing pegs" that sit against some base material to prevent the back from being compressed against the electronics.
        • viewerau
          • May 2020
          • 305
          Thanks...will give that a try in the morning.
          • viewerau
            • May 2020
            • 305
            SUCCESS...
            The back is now off.
            The method was what everyone was telling me, ala, seperate the two halves by using a guitar type plectrum.
            I actually used an old plastic VISA card, and worhed from where the leg opening was, inserting the card and popping off the first clip, and then inserting the card in that opened area, and slid it around the same way you separate the screen from a tablet or taking the edge off a mobile phone.
            The top was secured via some clips, which required me to loosed the whole bottom of the panel off, hold it up about 2", and then give the back panel a short sharp jab to lift it off the top clip retainers.
            I hope these pictures make sense.
            Thank you to all that have helped, as I appreciate your efforts enormously, and would not have got here without you.
            This weekend I will swap out the part and hope I selected the right one?
            I will report back.
            • petehall347
              • Jan 2015
              • 4440
              • United Kingdom
              #66
              bravo . yippee
                • 12284
                • U.S.
                #67
                Nice, it's really too bad they didn't bother to focus on building the rest of the tv with quality in mind, INSTEAD of just building the back cover like Fort Knox. DAMN I lost the pool had 99 but you got it in only 65
                • viewerau
                  • May 2020
                  • 305
                  I take it that you are not keen on Sony one bit 💣
                  If I do no good with this one, I'm indecisive of whether to get another Sony I have liked them as they are fully android, and the only other choice over here for full android seems to be Hisense.
                  I have some android boxes and am also considering just to get a better panel without android built in, and let the box do the android on it's own
                  It all depends on how/if this one works when trying a new power supply board, and hoping that was the culprit...
                    • 12284
                    • U.S.
                    #69
                    Well I have a sony kdl from 2009 that gets used quite a bit every day and all it ever needed was a firmware update, from what I see here and other forums, looks like lately sony beat samsung for reliability hands down no contest, can't speak about oled tvs as I don't trust them, too many panel issues, some call it the "panel lotto" hit or miss, looks like mostly miss is my take on it.
                      • 12284
                      • U.S.
                      #70
                      I think i would put a good effort into fixing it, looks like some pretty solid reviews on it:
                      https://www.amazon.com/Sony-KD65X750...ustomerReviews
                      • viewerau
                        • May 2020
                        • 305
                        Oh shoot.
                        I replaced the power board but cannot get it to work...same symptoms...no lights, no nothing.
                        I have pressed the power button on the remote for 5 seconds...nothing. Tried pressing power/ home together...nothing. Tried using the power switch on the back ..nothing.
                        Stuck again. Grrrr
                          1) So what Voltage testing have you done before replacing the power supply board?
                          2) Can we see good clear pictures of the whole backside of the TV showing all the boards so we can see how they are connected together?
                          • viewerau
                            • May 2020
                            • 305
                            Cannot seem to send images via mobile... Will try again
                            • viewerau
                              • May 2020
                              • 305
                              Here are from photo's from today.
                              No I haven't used a multimeter to test, as a little scared of electricity.
                                I hate in-line pictures. You cannot use the 'Go Advanced' attachment function?
                                • viewerau
                                  • May 2020
                                  • 305
                                  Does this method work for you budm?.This is the image link way
                                  https://imgur.com/wndkvOW
                                  https://imgur.com/M3OcVYJ
                                  https://imgur.com/gxHjOyA
                                  https://imgur.com/3Ti9qub
                                  https://imgur.com/2QPxCfD
                                    • 31214
                                    put the original parts back in, or you may find yourself looking for more than 1 fault.
                                    a lot of boards sold online are untested from broken tv's
                                    • viewerau
                                      • May 2020
                                      • 305
                                      Yes, I guess I may as well put the old power board back in it now.....so demoralised at the moment....
                                        • 12284
                                        • U.S.
                                        #79
                                        Maybe try the usb update: https://www.sony.com.au/electronics/...loads/00016672
                                          • 12284
                                          • U.S.
                                          #80
                                          So you have no indicator light on the front of the tv when you try to power on or when tv is just plugged in but off, which is standby with either board??
                                          • guidodroid
                                            Bad Panel in Sony Bravia X850G
                                            by guidodroid
                                            Hello all,
                                            I'm trying to understand what is the issue with my 26 months old Sony Bravia KD-65XG8505 (XBR65X850G).
                                            It is just few months out of warranty, so Sony doesn't want to do anything, and the local replacement shop also tells me that it's not worth repairing (alhtough this model costed almost 1000 euros just 2 years ago...).
                                            Few nights ago the TV started showing some horizontal lines and distorted colors/geometries in the bottom part of the screen (see attached photos).
                                            The issue is not as bad as others that I've seen around, but is indeed noticeable...
                                            03-19-2022, 12:08 PM
                                          • howardc64
                                            Best method to remove Samsung screwless rear panel
                                            by howardc64
                                            I've done a few of these. Using Samsung Service Manul method always result in some broken bits and the snap lock metal wire always gets bent and not reinstall as nice as original. After reinstall often have some pops and clicks. This is the best method I found so far. Pull the wire out instead
                                            https://youtu.be/paYZAc1rcWs?si=GHdTOv5ySIJgjZOC&t=82
                                            Here is a pic of how the hook on the wire locks
                                            Stil ended up with a couple of small broken bits on the bottom haha. But the wire stayed perfectly straight and seems easier/less forceful. Fishing...
                                            10-12-2025, 07:52 PM
                                          • m4a2t0t
                                            Sony Bravia 75X850C panel
                                            by m4a2t0t
                                            After changing out the backlights I have a single green vertical line on the left side of the screen. Is there any way to fix it? I tried putting pressure on all the tabs and on the top of the panel but neither helped.
                                            Does Sony epoxy all their panels or just the expensive ones?
                                            12-07-2023, 05:43 PM
                                          • swrb898
                                            Sony KD-70X690E Bravia; Bad TCON? Bad panel?
                                            by swrb898
                                            What's wrong with my TV: the TCON, the panel, or something else? I'm stuck.
                                            Problem:
                                            Last week, my Sony KD-70X690E 70" stopped displaying a picture. The TV powers on, and the back lights power on. However, the TV doesn't seem to boot up. I say this because the SONY splash-screen logo does not display, nor does any picture display, nor can I invoke a menu by pressing "Menu" on the remote. Other than back-light bleed, the screen is black.
                                            My troubleshooting got me this far:
                                            With the left-hand TCON to bottom-board ribbon cable...
                                            12-28-2021, 08:12 PM
                                          • iglitare
                                            by iglitare
                                            09-04-2025, 07:13 AM
