Sony Bravia 75X850C panel
  • m4a2t0t
    • Mar 2013
    • 276
    After changing out the backlights I have a single green vertical line on the left side of the screen. Is there any way to fix it? I tried putting pressure on all the tabs and on the top of the panel but neither helped.
    Does Sony epoxy all their panels or just the expensive ones?
  • EazyBone
    • Jun 2023
    • 1306
    • United states
    Yea looks like you are screwed imo. I have done this once before also, but I got a horizontal line. It was either there before I changed the lights or I damaged something. Without super expensive equipment you can't fix it.
    • m4a2t0t
      • Mar 2013
      • 276
      alright thanks
      • nomoresonys
        • 12086
        • U.S.
        Wondering if you had the line before you changed out the backlights or maybe you accidentally damaged it, you probably wouldn't know tho if the backlights were already bad when you got it, anyway, sometimes it's a component that goes bad or develops a bad solder joint on the address/panel driver boards, one possibility there: https://www.youtube.com/watch?v=Jsbw5wroTRM
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4278
          • Italy - Milan
          Check extremely aware the third tab from the left in photo for holes / marks especially near the glass
          • guidodroid
            Bad Panel in Sony Bravia X850G
            by guidodroid
            Hello all,
            I'm trying to understand what is the issue with my 26 months old Sony Bravia KD-65XG8505 (XBR65X850G).
            It is just few months out of warranty, so Sony doesn't want to do anything, and the local replacement shop also tells me that it's not worth repairing (alhtough this model costed almost 1000 euros just 2 years ago...).
            Few nights ago the TV started showing some horizontal lines and distorted colors/geometries in the bottom part of the screen (see attached photos).
            The issue is not as bad as others that I've seen around, but is indeed noticeable...
            03-19-2022, 12:08 PM
          • swrb898
            Sony KD-70X690E Bravia; Bad TCON? Bad panel?
            by swrb898
            What's wrong with my TV: the TCON, the panel, or something else? I'm stuck.
            Problem:
            Last week, my Sony KD-70X690E 70" stopped displaying a picture. The TV powers on, and the back lights power on. However, the TV doesn't seem to boot up. I say this because the SONY splash-screen logo does not display, nor does any picture display, nor can I invoke a menu by pressing "Menu" on the remote. Other than back-light bleed, the screen is black.
            My troubleshooting got me this far:
            With the left-hand TCON to bottom-board ribbon cable...
            12-28-2021, 08:12 PM
          • PopsCaps
            Sony Bravia KDL-40V2500 that will not power on
            by PopsCaps
            I have a Sony Bravia KDL-40V2500 that will not power on. The indicator flashes red 3 times.
            I do not hear any sound and I cannot see any backlight.
            I have tried disconnecting every cable on each board one at a time to see if anything changes.
            The only change is when I disconnect AC-DET cable on the Power Supply board or on the other end if I unplug the CN7009 connection on the B-Board and try to power on the TV the indicator will stay on solid green until I power off.
            My friend ordered another used power supply board but it is also doing the red indicator flash 3 times...
            03-25-2025, 11:23 AM
          • r3vsEngIT
            Sony Panel Swap Experiment 65x900h with the panel from a 65x930d
            by r3vsEngIT
            65x900h with the panel from a 65x930d.
            900H: model yr 2020, Samsung panel
            930D: model yr 2016, Innolux panel
            spec wise the panels are the same. the drivers and tcons are obviously different but what made me want to give this a try is that the wiring diagrams for the data signals going into the tcon for each tv were nearly identical. there are only a couple pins that i am unsure about and that is what brings me here.
            the 930d has the DPS board where the 900h has none, however, if you follow the pins to the BM1 it would appear that the signals...
            07-11-2023, 11:11 AM
          • SLK001
            Sony Bravia KDL-65W850C Panel
            by SLK001
            I picked up a 65" Sony Bravia today for only $50 with clearly bad LEDs (six flashes of the indicator). Of course, I have to remove the panel to get to them. The biggest panel that I have removed to date is a 55". The bigger they get, the more I worry about a panel "incident" that renders the TV useless, except for parts. I really want to make this TV my "new" TV in my living room.
            I have the Sony service manual for this TV, but getting to the LEDs is beyond the scope of even the official Sony manual.
            Does anyone have any tips or suggestions...
            04-19-2019, 03:07 PM
