Remove rear panel Sony Bravia KD-65X7500F
  • viewerau
    • May 2020
    • 305
    Re: Remove rear panel Sony Bravia KD-65X7500F
    I cannot get any indication of power in any way.
    The last time the tv worked, it would have been in standby mode, however, as it is now, there is no sign at all of life. It doesn't seem to respond to the power being turned on, a press of the power button on the back, or any presses of the remote control. It responds in no way whatsover....no flicker, no clicks.
    Signature:Seemingly hopeless tv fixer
      • 31214
      did you try a differrent power cable?
      i know it sounds stupid, but you always assume nothing works till proven otherwise
      • viewerau
        • May 2020
        • 305
        No I didn't, as the power cable is directly attached to the power supply board.
        • nomoresonys
          • 12284
          • U.S.
          #84
          Well see if you have the proper voltage where it attaches, if you can't get a measurement from the top, unplug everything from the powerboard, flip it over make sure you have the top part insulated from any metal, I just rest it on a piece of cardboard, plug the power cord in and check at solder joints.
            1) What DCV do you have on the main filter cap (yellow) C6524, measure right at the two legs of the cap?
            Be real careful since you are making measurement in the HOT DEADLY side of the circuit.
            2) You can also test the 3.3V standby Voltage by checking at the Cathodes of D6201 and chassis GND.
            3) Connector CN6401: You can test Voltages of the EVEN number pins on the top side of the board. the ODD number pin can be probed from the wire entrance side of the connector using skinny probe.
            • viewerau
              • May 2020
              • 305
              Thanks for the advice of where to check for power etc, but as I am not savvy enough to use the multimeter without killing myself, I am to scared to play with power on my own without supervision.
              I'll have to try to find someone local somehow to try your suggestions.
              Is it normally just either one of these two boards that end up being faulty, or do similar malfunction show up in other different parts of this telly too, to stop it from operating?
              I'd just once again like to thank all of you that are trying to assist me...
              • mmartell
                • Oct 2013
                • 3189
                You can test those voltages as indicated in #2 and #3 of budm's post without fear of killing yourself. Black probe on chassis (metal back or screw holding board down) red probe on each pin one at a time. Write them down.
                • viewerau
                  • May 2020
                  • 305
                  Thanks very much for the added information.
                  I am going to try get a friend to help in the measurements, as I am too worried.
                  It may be a day or two to do so, as such, please standby for an additional post in due course.
                  If there is any other testings he should do, please let me know before I try get the help.
                  Many thanks as usual...
                  • nomoresonys
                    • 12284
                    • U.S.
                    #89
                    To be clear MUST BE VERY CAREFUL if testing the main filter cap they have high voltage and can KILL easily, NEVER touch them with your hands, even when tv has been off a while they can still have a deadly charge, they can carefully be discharged with a resistor, definitely get help, better safe than sorry.
                    • viewerau
                      • May 2020
                      • 305
                      Thanks for the warning...this is why I choose not to try....I thank you for the reminder...CHEERS
                        At least plug t he TV into the GFCI outlet, these outlets are used in the bath room and kitchen.
                        • viewerau
                          • May 2020
                          • 305
                          If the power board checks out as ok, then where is the next checks to be conducted please? My helper is hoping to come on Sunday to help me out.
                          Thanks again.
                          • nomoresonys
                            • 12284
                            • U.S.
                            #93
                            Maybe check the diodes on powerboard see if any read bad, if so you can look closer at that part of the circuit to see if any other components might be giving the different reading while in circuit.
                              Right now we need to find out if all the control Voltages and Voltages (switched Voltages and standby Voltage) are present or not then we will go from there.
                              May be you and your helper should also read the Basic LCD TV troubleshooting just to understand basic concept as to what TV needs to operate.
                              • viewerau
                                • May 2020
                                • 305
                                Ok.. budm...will do...many thanks again!!!!!!
                                • chrismurphy
                                  • May 2014
                                  • 251
                                  • australia
                                  #96
                                  sorry to say you have a faulty main board
                                  Have done heaps of these and its always the main board , power supply's rarely fail
                                  • viewerau
                                    • May 2020
                                    • 305
                                    My helper (Mick) came today to help out
                                    On the power board, there is no 3.3v on standby. This was measured with power supplied pressing the power on button on the back, as well as trying to turn it on via the remote.
                                    Will it give 3.3v simply connected to the power outlet, but not responding to the on off button or remote.?
                                    The rest of the 12 v pins on the main connector all were perfect.
                                    The big yellow cap had power, as did the 2 X caps at the bottom right of the board.
                                    So, still wondering why it will not show the 3.3 standby?
                                    Grrr
                                    • nomoresonys
                                      • 12284
                                      • U.S.
                                      #98
                                      Is 12 volt even possible without standby voltage??
                                        My post #85:
                                        "2) You can also test the 3.3V standby Voltage by checking at the Cathodes of D6201 and chassis GND."
                                        Did you do that test as requested?
                                        • viewerau
                                          • May 2020
                                          • 305
                                          Will try for that again.
                                          • guidodroid
                                            Bad Panel in Sony Bravia X850G
                                            by guidodroid
                                            Hello all,
                                            I'm trying to understand what is the issue with my 26 months old Sony Bravia KD-65XG8505 (XBR65X850G).
                                            It is just few months out of warranty, so Sony doesn't want to do anything, and the local replacement shop also tells me that it's not worth repairing (alhtough this model costed almost 1000 euros just 2 years ago...).
                                            Few nights ago the TV started showing some horizontal lines and distorted colors/geometries in the bottom part of the screen (see attached photos).
                                            The issue is not as bad as others that I've seen around, but is indeed noticeable...
                                            03-19-2022, 12:08 PM
                                          • howardc64
                                            Best method to remove Samsung screwless rear panel
                                            by howardc64
                                            I've done a few of these. Using Samsung Service Manul method always result in some broken bits and the snap lock metal wire always gets bent and not reinstall as nice as original. After reinstall often have some pops and clicks. This is the best method I found so far. Pull the wire out instead
                                            https://youtu.be/paYZAc1rcWs?si=GHdTOv5ySIJgjZOC&t=82
                                            Here is a pic of how the hook on the wire locks
                                            Stil ended up with a couple of small broken bits on the bottom haha. But the wire stayed perfectly straight and seems easier/less forceful. Fishing...
                                            10-12-2025, 07:52 PM
                                          • m4a2t0t
                                            Sony Bravia 75X850C panel
                                            by m4a2t0t
                                            After changing out the backlights I have a single green vertical line on the left side of the screen. Is there any way to fix it? I tried putting pressure on all the tabs and on the top of the panel but neither helped.
                                            Does Sony epoxy all their panels or just the expensive ones?
                                            12-07-2023, 05:43 PM
                                          • swrb898
                                            Sony KD-70X690E Bravia; Bad TCON? Bad panel?
                                            by swrb898
                                            What's wrong with my TV: the TCON, the panel, or something else? I'm stuck.
                                            Problem:
                                            Last week, my Sony KD-70X690E 70" stopped displaying a picture. The TV powers on, and the back lights power on. However, the TV doesn't seem to boot up. I say this because the SONY splash-screen logo does not display, nor does any picture display, nor can I invoke a menu by pressing "Menu" on the remote. Other than back-light bleed, the screen is black.
                                            My troubleshooting got me this far:
                                            With the left-hand TCON to bottom-board ribbon cable...
                                            12-28-2021, 08:12 PM
                                          • iglitare
                                            Sony KD-75XF9005 grey Picture but Sound. TCON or panel?
                                            by iglitare
                                            i want to repair a Sony KD-75XF9005 TV that initially only showed a grey picture.
                                            Backlight seems to work, Sound (Setup menu after reset) works.
                                            If i dissconnect the left FFC cable from TCON to panel i have half a screen on the right. If left cable is connected always only the grey screen.
                                            Interchanged the cables, its always only the right side that is working. Always grey if left side is connected.
                                            With my small knowledge i would think at least the cables are good.
                                            Can this happen because of a bad tcon board?
                                            Or is it always a bad/shorted...
                                            09-04-2025, 07:13 AM
