Remove rear panel Sony Bravia KD-65X7500F
  • viewerau
    • May 2020
    • 305
    Re: Remove rear panel Sony Bravia KD-65X7500F
    yes I did see your posts on other forums, makes it even funnnier. 39.
    Signature:Seemingly hopeless tv fixer
    • viewerau
      • May 2020
      • 305
      [QUOTE=diif;965909]It's called a spudger, they a few generally used for prying.
      QUOTE]
      • budwich
        • Jul 2015
        • 3097
        Originally posted by viewerau
        Is there a chance that the vesa mounting area needs unscrewing before the back will come off. Even though I have never wall mounted it, the threaded 4 mounting holes are still there. .Do you have to remove the unused female threaded screw holes first? If so, what tool does this, or is these spots permanently attached to the chassis and not need removing at all to take off the cover. As you can see, I am just getting nowhere.... thanks in
        can you post a closeup of the vesa mount point so we can see what up there. From your other pictures and the "nick's tv video", it doesn't look like the same "issue" as his "threading points" appear to have "raised heads" on the bolt head which he "slots into with" a wide piece of thin metal.
        Are you seeing a "slotted bolt head" down in the vesa mount hole?
        • nomoresonys
          • 12284
          • U.S.
          #44
          You have got to see the hilarity here, the ENTIRE world can not figure out how to get the back off of this tv.
          • viewerau
            • May 2020
            • 305
            The tv is at our other place at the moment, not back there until Sunday. I am only leading the blind saying the vesa mounting spots need removing, as I am clutching at straws. My head tells me the vesa area has nothing to do with it, but for some reason the bloke in the video removed his.
            It appears any service guide doesn't match with this tv, as a continued search brings me up no reference material from a service point of view.
            Seems more and more likely I'll have to pay a tv tech
            • budwich
              • Jul 2015
              • 3097
              I would take a chance on doing a "pay for manual service"... one day access for $5.00 and up to X manuals. Its got to be worth it to try.
              something like https://servicemanuals.us/sony/tv/kd...scription.html
              might be worth a gamble. there are a few other sites with similar setups.
              • viewerau
                • May 2020
                • 305
                Yes, that seems a logical option.
                When I go to many of the tv manual sites, I cannot actually even find they have the model number listed anyway...that is a problem, but I will look again....thanks for the tip.
                Has anyone here actually worked/seen, one of the tv's I am talking about here?
                • budwich
                  • Jul 2015
                  • 3097
                  yes but for $5 take the chance that perhaps some other model some clues that will help you.
                  • mmartell
                    • Oct 2013
                    • 3189
                    Did you determine if this Australian model was the same as the x750 in the US ? I see Shopjimmy has parts listed for the x750 which means they know how to get the back off, maybe drop them an email and ask.
                    • viewerau
                      • May 2020
                      • 305
                      Thank you....I did email them some time ago, asking for assistance, but unfortunately I never received a reply.....
                      • petehall347
                        • Jan 2015
                        • 4440
                        #51
                        • viewerau
                          • May 2020
                          • 305
                          Looks like the right tool so far.....
                          • nomoresonys
                            • 12284
                            • U.S.
                            #53
                            EUREKA you have finally found the right tool
                            • brucetv
                              • May 2015
                              • 281
                              • united states
                              #54
                              Here is another picture of one of many ways Sony engineers like to make your life miserable as a Tv technician. The first picture is a Sony XBR-65x930D and on it it has plastic clips that slide under that top metal vent to release so on it after all the screws are off you push the back cover DOWN after the bottom comes out. Fairly easy on this model. On Sony's some time there will be a slider release on the left and right you slide up and THAT releases the cover after all the screws are out. And then there is the nightmare flat head sliders that wreak havoc on your day and you just want to go out and take a sledge hammer to a customers tv that hasn't paid for his repair for 3 months. Here is a excellent artist rendition of what these look like and on these types you have to push the back cover up to slide those slots off those tight ass screw heads. Never a dull day with a Sony. Next time I see one with the "slots from hell" type covers I'll take a picture and add it to this forum. ====> Sony engineers
                              • viewerau
                                • May 2020
                                • 305
                                Thanks brucetv....I really do appreciate your effort, and will try again tomorrow.
                                You wouldn't happen to know if there is any release method to do with where the legs fit as well?
                                • brucetv
                                  • May 2015
                                  • 281
                                  • united states
                                  #56
                                  Here is another example of Sony's over engineering. On this type you have to pull the bottom out and then the back cover pulls down. These clips stubbornly fit into the slots in that metal vent. I wish all manufactures would just stick with screws only, no friggin clips and crap like this guys tv. Who gives a shit what the back of the tv looks like.
                                  • viewerau
                                    • May 2020
                                    • 305
                                    CI think I'll have to attack this with a Dremel tool...
                                    • viewerau
                                      • May 2020
                                      • 305
                                      Don't know if this will help/work, but tried to do a video of the back of the tv ..maybe someone can help?
                                      http://www.mediafire.com/file/hqfina...1732.mp4/filea
                                      • budwich
                                        • Jul 2015
                                        • 3097
                                        You likely need to focus on the area between the "main portion" of the "lower half cover" that is above the portion where the speakers are housed. In the start of the video, you can see a "dimple" where there is a "push fastener anchor".... this likely represents where the "peg head's base" (ie. the male stud) which is then pushed down / seated into a female receiver in the body of the back of the panel. Looking at the "lines of flow" at the "joint", at this point, seems to indicate a "difference" at that point.... assuming the video is showing a uniform perspective but it is hard to tell if indeed that line / point between the two back plates is a actual boundary or a change in the molding.
                                        edit... I think now I see that the "boundary" is nothing more than a changing in the "skin" of the plastic (rough to smooth) and is therefore not a point of removal / seperation. That means the you need to move down towards the speaker housing "cover". Look at the metal tab, does it flip up to reveal a screw underneath maybe?
                                        • viewerau
                                          • May 2020
                                          • 305
                                          • guidodroid
                                            Bad Panel in Sony Bravia X850G
                                            by guidodroid
                                            Hello all,
                                            I'm trying to understand what is the issue with my 26 months old Sony Bravia KD-65XG8505 (XBR65X850G).
                                            It is just few months out of warranty, so Sony doesn't want to do anything, and the local replacement shop also tells me that it's not worth repairing (alhtough this model costed almost 1000 euros just 2 years ago...).
                                            Few nights ago the TV started showing some horizontal lines and distorted colors/geometries in the bottom part of the screen (see attached photos).
                                            The issue is not as bad as others that I've seen around, but is indeed noticeable...
                                            03-19-2022, 12:08 PM
                                          • howardc64
                                            Best method to remove Samsung screwless rear panel
                                            by howardc64
                                            I've done a few of these. Using Samsung Service Manul method always result in some broken bits and the snap lock metal wire always gets bent and not reinstall as nice as original. After reinstall often have some pops and clicks. This is the best method I found so far. Pull the wire out instead
                                            https://youtu.be/paYZAc1rcWs?si=GHdTOv5ySIJgjZOC&t=82
                                            Here is a pic of how the hook on the wire locks
                                            Stil ended up with a couple of small broken bits on the bottom haha. But the wire stayed perfectly straight and seems easier/less forceful. Fishing...
                                            10-12-2025, 07:52 PM
                                          • m4a2t0t
                                            Sony Bravia 75X850C panel
                                            by m4a2t0t
                                            After changing out the backlights I have a single green vertical line on the left side of the screen. Is there any way to fix it? I tried putting pressure on all the tabs and on the top of the panel but neither helped.
                                            Does Sony epoxy all their panels or just the expensive ones?
                                            12-07-2023, 05:43 PM
                                          • swrb898
                                            Sony KD-70X690E Bravia; Bad TCON? Bad panel?
                                            by swrb898
                                            What's wrong with my TV: the TCON, the panel, or something else? I'm stuck.
                                            Problem:
                                            Last week, my Sony KD-70X690E 70" stopped displaying a picture. The TV powers on, and the back lights power on. However, the TV doesn't seem to boot up. I say this because the SONY splash-screen logo does not display, nor does any picture display, nor can I invoke a menu by pressing "Menu" on the remote. Other than back-light bleed, the screen is black.
                                            My troubleshooting got me this far:
                                            With the left-hand TCON to bottom-board ribbon cable...
                                            12-28-2021, 08:12 PM
                                          • iglitare
                                            Sony KD-75XF9005 grey Picture but Sound. TCON or panel?
                                            by iglitare
                                            i want to repair a Sony KD-75XF9005 TV that initially only showed a grey picture.
                                            Backlight seems to work, Sound (Setup menu after reset) works.
                                            If i dissconnect the left FFC cable from TCON to panel i have half a screen on the right. If left cable is connected always only the grey screen.
                                            Interchanged the cables, its always only the right side that is working. Always grey if left side is connected.
                                            With my small knowledge i would think at least the cables are good.
                                            Can this happen because of a bad tcon board?
                                            Or is it always a bad/shorted...
                                            09-04-2025, 07:13 AM
