LE37B530 Backlight Blinking
  • alepol
    • Mar 2020
    • 8
    • france
    I m french so excuse me for my english.
    Power board BN44-00301
    My tv started 1 time /10, i fuse solder in power board and now it start all time but the backlight blinking.
    I check the inverter with a CFL ligh is lighting for 5 secondes and stop.
    I connected the CFL light and the backligh, all blinking 2-3 s and stop.
    Only backligh, all the CFL on the panel blinking, i checked all the connections are
    If you have any idea, solution ?
    Thanks a lot and STAY AT HOME.
    Regards
    • 12206
    • U.S.
    Re: LE37B530 Backlight Blinking
    See if you can turn the backlight NOT brightness way down in the picture settings, then see if there's any change in symptoms.
    • alepol
      • Mar 2020
      • 8
      • france
      Thnaks for you reply, When i change the backlight setting, is ok for 5-10 secondes end backlight Off.
      Regards
        • 12206
        • U.S.
        Ok, thinking probably bad/weak led/s in backlights if it stayed on longer.
        • CapLeaker
          Leaking Member
          • 8218
          that unit has ccfls as back light. Check the secondary on each transformer on the inverter board and compare them to each other. Look for cracked solder joints, evidence of one transformer running hotter than the other, resolder the blue capacitors.
          • alepol
            • Mar 2020
            • 8
            • france
            Hi, all thanks for you reply, there is only 2 inverter transfo, white and black i don't know what is mean, i already resolde all on this 2 transfo, i solder all the cfl to the clips to be sure, so i mean is not a bad contact, do you know is a old CFL can use more courant and pass the PFC down ?
            Regards
            • alepol
              • Mar 2020
              • 8
              • france
              I already resolder the capacitor and check with other.
              • ngth82
                • Jul 2015
                • 541
                Can you post some clear pictures of the boards on your TV and the inverter board?
                What's the complete model number of your TV? LE37B530****** **** ?
                I've seen a few with transformers that has a "sense" winding on the same as the primary side. When the induced voltage is higher than a threshold, it'll shut the CCFL's down. For testing, you can pull the sense circuit to GND and see if that works longer -- that'll indicate a problem with the CCFL's themselves.
                There's a video that 12voltvids on YouTube did for this a couple of years ago: https://www.youtube.com/watch?v=Dh01ZepjDp0
                -Thomas
                I'm a hardware engineer focused on networking equipment for my day job. I void warranties and fix consumer electronics for fun.
                  • 12206
                  • U.S.
                  Oops my bad, forgot to check what backlighting was used.
                  • diif
                    • Feb 2014
                    • 6978
                    • England
                    It's a B series and the OP mentions CFL three times in his post.
                      • 12206
                      • U.S.
                      STUFF it dif boy.
                      • alepol
                        • Mar 2020
                        • 8
                        • france
                        Hi, i posted a picture off power supply and the exact model
                          Can we see the whole backside of the TV showing all the boards?
                          • alepol
                            • Mar 2020
                            • 8
                            • france
                              Where are those two set of high Voltage wires (Pink and Black, Brown and Black) with connector go to, they are on the right side of your picture?
                              Any one work on this TV before you?
                              What happen to the two High Voltage connectors (CNI801/802) in the inverter section?
                              • alepol
                                • Mar 2020
                                • 8
                                • france
                                Yes of course i solded directy brown and black cable to the main bord and connector to the black and ping cable to the backlight, so i m sure the connection is good.
                                • triplefour
                                  by triplefour
                                  09-13-2023, 10:43 PM
                                • Audeze
                                  Sony XBR-75X950G seems dead with a black screen but backlight and sound is working and no blinking red lights
                                  by Audeze
                                  I have a 2019 75" x950g, and while playing a movie, the screen suddenly went dark in a weird way, where it faded towards one corner into being fully black. Now the TV turns on, and the backlight comes on, but there is nothing displayed except black. Sound still comes through the TV speakers, and i have tried doing a hard reset using the volume - and power buttons while plugging the display back in, but it did not fix it. I can confirm that pressing buttons on my remote is still doing "something" because I'm hearing sound still, even though the screen is black.
                                  Does...
                                  10-06-2024, 08:54 PM
                                • Davi.p
                                  Samsung UE49MU6120 no boot, no spy led, blinking backlight...
                                  by Davi.p
                                  Hi folks, the set is from my brother house, unfortunately i'm repairing 1 tv, 1 pc, 1 tablet, 1 Stereo receiver at the same time, all house's bench/table busy, i eat like an horse, and i'd like to know sure experience from other techs about this, i don't like to transport it to my house and it ends it is bad backlight waiting months for parts and so on..
                                  The blinking is only on the left side, no answers from remote, right after plugging in, back story of tv it had some slight B.L. problem, some shadowing in the bottom of image, maybe burnt sheets.. i really hope it's the same old spi flash...
                                  08-27-2024, 08:07 AM
                                • DanPoka
                                  Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
                                  by DanPoka
                                  I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
                                  Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
                                  This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
                                  02-15-2025, 05:05 AM
                                • Comp_Pro
                                  No Backlight Macbook A1990 820-01041
                                  by Comp_Pro
                                  Hello all,
                                  Am trying to figure out this backlight issue with this A1990 Macbook Pro.
                                  Tests performed:
                                  There is no backlight even with a good screen.
                                  Backlight IC is receiving the correct support voltages.
                                  Fuse F8400 ok
                                  Current sense resistor R8400 ok
                                  Backlight IC is receiving 3.3V on enable pin.
                                  Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
                                  Backlight IC receiving 5V from PP5V_G3S
                                  Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
                                  I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
                                  05-06-2024, 10:23 PM
