Sony XBR-75X950G seems dead with a black screen but backlight and sound is working and no blinking red lights
  • Audeze
    • Jul 2011
    I have a 2019 75" x950g, and while playing a movie, the screen suddenly went dark in a weird way, where it faded towards one corner into being fully black. Now the TV turns on, and the backlight comes on, but there is nothing displayed except black. Sound still comes through the TV speakers, and i have tried doing a hard reset using the volume - and power buttons while plugging the display back in, but it did not fix it. I can confirm that pressing buttons on my remote is still doing "something" because I'm hearing sound still, even though the screen is black.
    Does anyone know what could be the problem? I slightly proficient with electronics(scope and multimeter and can take measurements) and I'm happy to take a gamble and try purchasing replacement parts off ebay. but not sure what part to get. Based on the problem im describing, does anyone know if I should try getting a LED driver board/t-con board, or main board? I assume that the power supply must be fine because the backlights still all work. Do I need to get an exact matching t-con board? or main board? ie, can I use a 55 inch X950g board in my 75 inch? or can use a t-con board from a x950h? what about if im getting a main board instead of a t-con board, can I mix and match any of these? I have tried googling my issue but I have not found another case like this, everyone seems to get blinking red lights, but my problem seems different... ​
  • EazyBone
    • Jun 2023
    • 1353
    • United states
    Generally on Sony's a main board for a 55/65/75/85 will work for each other. But not mis matching model numbers so a 850g and h wont be interchangeable (someone correct me if I'm wrong here) but for the TCON generally you need the exact board for it. I haven't compared if a 55/65/75 etc are different for a TCON board are different.
    A great way to check what's compatible is go to shopjimmy.com and type in your tv or board and it will show you which boards will go to which TV that's the easiest most reliable way to do that.
    Now for your situation, I can't answer that because I generally don't get to watch the screens go bad, I just get them after they are bad. Maybe someone here can give you better guidance there.
    • m1ch43lzm
      by m1ch43lzm
      05-12-2025, 08:37 PM
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • howardc64
      by howardc64
      07-24-2025, 05:17 PM
    • slimmy182
      [SOLVED] M1 MacBook Pro clicking sound logic board 5V no power on A2338 820-02020
      by slimmy182
      Hello, I bought this Mac from a friend, he said that it simply stop working. The MacBook looks very clean but does not power on, stuck on 5v 0.42A, and sometimes display 5V and 0A (then 0.071A and again 0A).
      I opened it looking for some problem, it was not touched before for sure and the board is very clena, no spot of corrosion at all from what I can see. Voltage on multimeter of the board off the case it's the same, 5V 0.42A. But then I noticed this "clicking sound" come from the board ( I attached here the audio file).
      Looking on google I found this:...
      01-14-2023, 11:55 AM
    • mrtek
      Samsung UN65js8500F, no sound, blank screen and T-Con board with one LED on
      by mrtek
      Hi I am new to this kind of repairs but I want to learn..I have a Samsung UN65JS8500F. the TV used to work and I tried to fix darker areas in the middle only ( img 1,2,3). I thought the led strip were bad..not the case. I did not research in advance what kind and where the LED were located. In this model they are located vertically on right and left side. Took the TV apart and put it back together. Now the tv shows no welcome screen and no sound is available thru the speakers. ..just a black screen..Backlight LED do turn on...also noticed a 5 blink code , not sure if that was there before. I can...
      11-26-2024, 09:58 AM
