Vizio M502i-B1 Power Supply Issue
  • R_J
    • Jun 2012
    • 9625
    Re: Vizio M502i-B1 Power Supply Issue
    On your original board the +12v was 11.6 and the +24 volts measured 19.7 volts, What do you measure on the replacement board for the +12v and the +24v?
    • nomoresonys
      • 12331
      • U.S.
      #42
      Did you replace everything in the repair kit? maybe re-check your solder work. https://www.shopjimmy.com/vizio-adtv...r-m502i-b1.htm
      • nomoresonys
        • 12331
        • U.S.
        #43
        Maybe check ALL the diodes and the solder joints of CN9101 connector and check all the solder joints on the board, maybe use a magnifying glass.
        • JunkmanJimbo
          • Mar 2017
          • 194
          Thanks R_J and nomoresonys, I will check those things tomorrow and let you know.
          • JunkmanJimbo
            • Mar 2017
            • 194
            R_J, the voltages for both boards are the same....11.6 volts and 19.7 volts. When holding the power button for 30 seconds to drain power on both boards, when plugged back in, the replacement board powers up but the original board does not.
            • JunkmanJimbo
              • Mar 2017
              • 194
              nomoresonys, I did replace everything in the repair kit except the main power fuse. The original fuse checks ok. I checked solder joints also.
              • nomoresonys
                • 12331
                • U.S.
                #47
                With the new powerboard in are you still getting that 1.1v low reading on the ps_on? I think I would be tempted to check every capacitor on that faulty board.
                • JunkmanJimbo
                  • Mar 2017
                  • 194
                  The 1.1 volt reading was only on the old board when it wouldn't power on. So, is there a possibility that the voltage regulator might be defective?
                  • R_J
                    • Jun 2012
                    • 9625
                    What is the pin number on CN9101 that you measure 1.1 volts?
                    • JunkmanJimbo
                      • Mar 2017
                      • 194
                      R_J, that would be pin #2 - on/off.
                      • R_J
                        • Jun 2012
                        • 9625
                        Pin#2 has nothing to do with the operation of the power supply, it simply connets CN9101 pin#2 to CN9102 pin#12 and is the inverter on/off There are a couple mlcc caps on that line and an inline resistor, R9102, check that the resistor does'nt have bad solder connections
                        • JunkmanJimbo
                          • Mar 2017
                          • 194
                          Thanks R_J. The solder joints look ok. What I don't understand is why would disconnecting the cable at the power supply from the main board, and reconnecting it cause the power to return? Could it be a resistor, cap, ic,
                          transistor causing this. Also after reconnecting the cable to the power supply, the standby light flashes twice and then it takes about 15 to 20 seconds to come on. Sorry for all this. But I do appreciate the help.
                          • JunkmanJimbo
                            • Mar 2017
                            • 194
                            If nobody has anymore ideas, I might just give up on it. I was just trying to offset some of the cost of the replacement power supply board.
                            • nomoresonys
                              • 12331
                              • U.S.
                              #54
                              Maybe try heating the caps with a hairdryer, see if tv comes on or comes on any faster.
                              • JunkmanJimbo
                                • Mar 2017
                                • 194
                                I actually replaced some of the caps but I will try that on the others. Thank you nomoresonys.
                                • R_J
                                  • Jun 2012
                                  • 9625
                                  Maybe if you uploaded some pictures of your power supply we might see something that is wrong.
                                  • JunkmanJimbo
                                    • Mar 2017
                                    • 194
                                    I will do that. It will probably be tomorrow. Thanks R_J.
                                    • rohit24
                                      • Apr 2020
                                      Originally posted by JunkmanJimbo
                                      Well guys, I finally decided to replace the power supply and that fixed the TV. I still wish I could figure out what's wrong with the defective board so I could repair it and sell it to offset some of the cost of the replacement board. I've been looking for repair kit for this board but can't find one other than one on ebay and they won't sell to me for some reason. Does anybody know where I can get a repair kit for this board? Thanks for all the help and sorry for the long post.
                                      Can you please share where did you buy the power supply from?
                                      • JunkmanJimbo
                                        • Mar 2017
                                        • 194
                                        Sure rohit24. I bought it from tv parts today.
                                          https://www.tvpartstoday.com/ADTVD36...tvd3613xa7.htm
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                          • Soulzink
                                            Samsug washing machine. Power supply DC41-00189a board issue
                                            by Soulzink
                                            I am trying to fix a samsung washinmachine power supply main board.
                                            I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
                                            Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
                                            The power supply board reference is the following: DC41-00189a
                                            I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
                                            04-19-2025, 06:26 AM
                                          • GLISIT
                                            by GLISIT
                                            01-16-2025, 02:29 PM
                                            07-01-2024, 06:34 AM
                                          • JimBanville
                                            Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                                            by JimBanville
                                            The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                                            I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                                            09-13-2023, 07:21 AM
