Vizio M502i-B1 Power Supply Issue
  • nomoresonys
    • 12330
    • U.S.
    Re: Vizio M502i-B1 Power Supply Issue
    The 20-30 seconds to turn on makes me think a weak capacitor somewhere, probably on powerboard, the startup caps maybe.
    • JunkmanJimbo
      • Mar 2017
      • 194
      R_J posted earlier in the thread to replace C9805, C9308 and C9112 and also C9305 to hopefully fix the problem.
      • nomoresonys
        • 12330
        • U.S.
        Indeed, if you had one of those 4 or 5 dollar esr meters from ebay you could take m off the board n check m.
        • JunkmanJimbo
          • Mar 2017
          • 194
          I actually do have a meter to check caps. I have an assortment of caps arriving tomorrow and I was going to check them then so I would have a replacement. I will update tomorrow or Monday with the outcome. Thanks to all you guys for your help.
          • nomoresonys
            • 12330
            • U.S.
            Lol, ok, I assumed that you didn't have one, a good example to never assume, especially when troubleshooting.
            • JunkmanJimbo
              • Mar 2017
              • 194
              My capacitors came a day early. I replaced C9805, C9308 and C9122 and also C9305 that R_J mentioned but unfortunately that didn't fix the problem. Does anybody have any other suggestions?
              • nomoresonys
                • 12330
                • U.S.
                #27
                So what are those voltages now, still getting the 1.1?
                • JunkmanJimbo
                  • Mar 2017
                  • 194
                  No change. Everything is still the same as it was before I replaced the capacitors.
                  • CapLeaker
                    Leaking Member
                    • Dec 2014
                    • 8352
                    I figured that would be the case. BLon is created on the main board not on the PSU and the STBY voltage was good while the on / off pin is low. BLon goes from the main board to one connector of the psu, through jumpers, then one SMD resistor and then out the other connector to the LED driver board. The LED driver board can't load the BLon pin down, because of this SMD resistor on the back. It has to be a main board problem or a chaffed wire grounding out or something stupid.
                    • JunkmanJimbo
                      • Mar 2017
                      • 194
                      I've changed the mainboard 3 or 4 times and get the same result. I will check the wiring a little closer. So, you don't think there could be another problem on the power supply?
                      • nomoresonys
                        • 12330
                        • U.S.
                        #31
                        Get the resistor and do the test in CapLeaker's post #16, it's not a hard test and it will tell you if the powerboard is doing as it should.
                        • JunkmanJimbo
                          • Mar 2017
                          • 194
                          I would need more detailed instructions and abbreviation meanings to even consider doing that. Can you help me with that?
                            Did you check the DC Voltage between the two legs of the main filter cap to see if the PFC Boosted Voltage (380 ~ 400VDC) is present or not when PS-ON is present?
                            • JunkmanJimbo
                              • Mar 2017
                              • 194
                              BudM, I'm not sure how to do what you're saying. Can you give specific instructions on how to do that? Sorry but I'm not very good at board level testing.
                              • nomoresonys
                                • 12330
                                • U.S.
                                #35
                                Good testing tutorial there, might help: https://www.youtube.com/watch?v=ocqnqmBxiqY
                                • JunkmanJimbo
                                  • Mar 2017
                                  • 194
                                  I will definitely take a look at that. Thank you nomoresonys.
                                  • nomoresonys
                                    • 12330
                                    • U.S.
                                    #37
                                    As always be careful working on the DEADLY HOT/PRIMARY side of the powerboard, watch out what you touch with your hands, use the meter probes, keep hands back.
                                      At least plug what ever you are working on into GFCI outlet.
                                      • JunkmanJimbo
                                        • Mar 2017
                                        • 194
                                        Well guys, I finally decided to replace the power supply and that fixed the TV. I still wish I could figure out what's wrong with the defective board so I could repair it and sell it to offset some of the cost of the replacement board. I've been looking for repair kit for this board but can't find one other than one on ebay and they won't sell to me for some reason. Does anybody know where I can get a repair kit for this board? Thanks for all the help and sorry for the long post.
                                        • JunkmanJimbo
                                          • Mar 2017
                                          • 194
                                          Still trying to repair this power supply. I ordered a kit off Ebay and installed those components but that didn't fix the problem. Another problem I noticed could be the whole problem. When I install the old power supply, if I unplug the power cord and hold in the power button on the TV for 30 seconds, and plug it back in, the TV won't do anything. No standby light, nothing. As if there is no power. Could that be a voltage regulator issue? If not does anyone have any ideas? The only way I can get power back is unplug the cable from the main board and plug it back in, then I have power again. This was mentioned in an earlier post. Thanks in advance for any help you can offer.
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                          • Soulzink
                                            Samsug washing machine. Power supply DC41-00189a board issue
                                            by Soulzink
                                            I am trying to fix a samsung washinmachine power supply main board.
                                            I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
                                            Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
                                            The power supply board reference is the following: DC41-00189a
                                            I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
                                            04-19-2025, 06:26 AM
                                          • GLISIT
                                            by GLISIT
                                            01-16-2025, 02:29 PM
                                            07-01-2024, 06:34 AM
                                          • JimBanville
                                            Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                                            by JimBanville
                                            The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                                            I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                                            09-13-2023, 07:21 AM
